Question about Crosley CE35100AA Electric Kitchen Range
Single Burner Doesn't Heat Properly
This is a questiong about electric ranges. Mine has a single burner that doesn't heat properly. Any ideas??
  • Anonymous Mar 28, 2014
    The burners are not heating up properly
    Scholar:
  • 148 Answers
You need a new burner element,if you hear sparking noises the black box the element plugs into has to be replaced
Posted on Jul 07, 2008
Former GE employee said not to unplug coil burners while cleaning. he said it gets worse with each time you unplug. A component can be purchased to reset it but I don't know what that is..sorry. At least this may be helpful in others keeping the coils connected while they clean.
Posted on Jan 05, 2008
Talked to a former GE employee once at an appliance store. He said if you unplug an electrical burner to clean the stove top, it will not work prperly and will get worse each time you do it. There was some component that could be replaced without buying the whole coil gizmo but I don't know what it was. Sorry no too helpful but may prevent some who read from disconnecting the coil while cleaning.
    Novelist:
  • 74 Answers
1. Turn off power. 2. Determine type of burner. If it's a plug-in, test faulty burner in another receptacle * If it works, replace the original receptacle * If it doesn't work, replace the burner. * Replace other faulty components If it's a flip-up burner: * Disassemble and replace the faulty burner and any other faulty parts. 3. Restore power. 4. Test. *If it still doesn't work, call a repairperson.
Posted on Jan 18, 2006
2 Suggested Answers
SOURCE:
mreid542
  • 166 Answers
SOURCE: Crosley oven worked yesterday but today I have no
check the receptacle for 220 volts. also check the connections where the cord goes into the back of the range - make sure you have 220 volts there also.. it sounds like you have only 110volts going to the range. there are no fuses that I am aware of.
you could also have a burned wire somewhere.
Posted on Aug 01, 2010
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
I have KitcheAid KERS 807, electric stove/oven range. Left lower part of ceramic stove top that has single/dual heater sizes is malfunctioning. Single one is still working but from recent dual does not.I...
Either the knob has gone out or the burner element. I would test the knob first to see if there is current when turned to the large zone. If the knob is working, next would be to test the burner to see if the outer ring has burned out. I would guess more likely the control has gone out. Burners have less failure (typically).
Apr 14, 2014 | KitchenAid KERS807SSS Electric Kitchen...
One burner on Kera205pbt won't heat
Just to be clear, the burner does not heat at all? Is this the small or large burner? Swap the burner with another one to see if it is the burner itself or the infinite switch. Post back your results.
Feb 08, 2013 | KitchenAid KERA205P Electric Kitchen Range
When trying to turn on the front right burner it doesn't heat at all what do I need to replace?
Check the wiring to the element, be careful shock hazard. On my electric range the wires were broken where the element plugs in socket. Socket kits are about $9.00 us If you have a volt meter unplug the element and turn the control on if you have voltage then replace the element. Thanks Tom
Nov 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
My electrolux EOB5610 wont heat up....the fan works and the grill works but will not reach any sort of temp !!!!
Thanks for choosing FixYa and welcome. you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defective heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
Jun 02, 2011 | Electrolux EOB5610 Ultrafan Electric...
Hi i have a Samsung oven bf641fst the light and fan come on but the heat side wont work and the led sceen is blank?
May 31, 2011 | Viking VESO176 Stainless Steel Electric...
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Single element in 3-way burner won't work
Hey Janice,
Sorry to hear this.. but, here is a site that will answer your question more completely.. ( I think this is a complete replacement job).. and if your are mechanically inclined, you might be able to do it yourself... good luck,,
as far as costs... that's such a wide range of "prices per hour or by the job", it would not be feasible to put a $$$ figure on here..
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/94552-glass-surface-triple-element-replacement.html
Jun 19, 2017 | Maytag MES5775BAF / MES5775BAN /...
Crosley CE35100AA Electric Kitchen Range Logo
294 people viewed this question
Top Crosley Kitchen Ranges Experts
steve johnson
Level 1 Expert
Vladimir Frolov
Tom Chichester
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
