FixYa.com
Tags:
Crosley CE35100AA Electric Kitchen Range
Surface element doesn't work
posted by Guest on Jan 18, 2006
I have an electric kitchen range. What do I do if the surface element doesn't work?
Best Solution
posted on Jan 18, 2006
Helpful (85)
nagev
Rank:Wiz Wiz
Rating: 76%, 2346 votes
When an electric element doesn't work, either it isn't receiving electric power or it's likely that the element or receptacle it plugs into is faulty.
Check the other elements. If none work, the circuit breaker has probably tripped. Reset it at the electric panel. If this reoccurs, call an appliance repairperson.
If just one burner isn't working, try to pinpoint the source of the problem-- likely a bad element/burner or a problem with its connection receptacle. In some cases it's the switch or the wiring. To replace a bad switch or repair the wiring or replace the receptacle, call an appliance repairperson.
A burner that plugs into a receptacle is easy to test. After turning off the range's power at the main electrical panel, just unplug the non-heating burner, plug it into another working receptacle, restore the power to the range, and test it. If the burner works, you know its original receptacle is probably faulty. If it doesn't work in the good receptacle, the burner is bad and should be replaced. Buy a replacement and simply plug it into the receptacle.
When you remove the burner, look for burned wires or a charred receptacle. Check the receptacle or terminal block to see if it's cracked, loose or looks burned. If you notice any of the above signs, replace the faulty component, too. If the male burner prongs are corroded, always change the female receptacle it was plugged into.
A flip-up burner requires a little more work. After turning off the power, tilt up the burner, unscrew the small screw that holds it, and then slide it out. Disassemble the insulator block by prying off the clips. Then unscrew the wires from the element, replace with a new burner, and reassemble.
To test a burner with a multi-meter: First remove the burner from its receptacle, as discussed above. Set the multi-meter to the Rx100 setting (or, for a digital meter, to [omega symbol] or k[omega symbol]. With the red lead connected to the positive jack and the black lead to the negative jack, touch the black probe on one of the heating element's terminals and touch the red probe to the other terminal. The needle should jump from the infinity reading to the right, indicating a properly "closed" circuit. If it doesn't, try the probes on a different part of the metal contacts. Still no reading? Touch the two leads together to make sure the meter is working (the needle should jump). If it works, there is an internal break in the element and it will need to be replaced.
When you're finished, turn the power back on.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE Spectra JBP78 Electric Kitchen Range GE Spectra JGBP35 Gas Kitchen Range GE JBP90 Electric Kitchen Range GE JGBC20 Gas Kitchen Range GE JBP69 Electric Kitchen Range GE JBP70BK / JBP70WK Electric Kitchen Range GE JBP72SKSS Stainless Steel Electric Kitchen Range
Can you Help with these Kitchen Ranges problems?
F1 on the display
My display will only read F1, I... Answer This...
Crosley Range
Hello, have a problem with my... Answer This...
elements wont turn off
i have unplugged my stove and... Answer This...
surface burner only goes to...
Hi, one of the surface burners... Answer This...
help
intstructions on connecting a... Answer This...
Repair Service
Find Kitchen Range Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
