Crosley CE35100AA Electric Kitchen Range
Problem for Crosley CE35100AA Electric Kitchen Range
New kitchen range
By Guest on Jan 18, 2006
I just go a new kitchen range and would like to know how to keep it woking properly. Any tips would be welcome.
Solution #1
posted on Jan 18, 2006
Somewhat Helpful)
nagev
Rank: Wiz
Rating: 78%, 2426 votes
The key to keeping a kitchen range operating properly is to clean it regularly. Beyond that basic maintenance, only a couple of repair jobs are within the skills of most homeowners because most repairs require a thorough understanding of the appliance. With the help of an owner?s manual, you can replace door gaskets, adjust the feet beneath a range to correct for uneven cooking, and relight a pilot. Of course, you can also reposition racks if foods are cooking unevenly and you can check cords, circuit breakers, and fuses.
Here are a few tips for cleaning your range:
* Clean up spills soon after they occur. Some acidic foods, such as tomato products, can damage the surface of the cooktop or interior of the oven.
* Loosen cooked-on gunk with water or baking soda and water?do not use abrasive materials, which can scratch surfaces.
* Keep the reflector bowls of gas burners clean; it?s not only more pleasing, but the shiny surface makes cooking more efficient.
* Wash burner controls and other knobs with warm water and detergent. Some knobs have markings that can come off, so take care not to soak or scrub them too much.
* Clean gas burners and grates thoroughly.
* Use commercial oven cleaners very cautiously, because they are highly toxic. Follow instructions carefully. As an alternative, fill a glass bowl with half a cup of ammonia and let it stand in the oven overnight. Wipe the walls clean with paper towels or newspapers.
Before doing any work on the stovetop, always unplug the range or turn off the power at the main electrical panel. Do not hesitate to call a professional appliance repair person if you have any doubt about your knowledge or abilities when repairing an electric range.
You rated this solution as "Somewhat Helpful".
Solution #2
posted on Apr 20, 2007
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have a garland 10 ring burner but some of the rings arn't as powerfull as others! I have cleaned all the holes on the burners but the flame on some of the burners is weak! Is there anyway of turning them up or what can i do i had a repair man look at it he took it apart and build it together again and told me that that is the way it is but why are some more powerfull than others?
Cheers Jeffrey
Popular Solutions for Crosley CE35100AA Electric
Questions and Unsolved Problems for Crosley CE35100AA Electric
Do you recommend Crosley CE35100AA Electric Kitchen Range?
Answer
Answer
i just replaced the propane burner assembly and now i get a big yellow flame
Answer
My stove is locked. It's not the "can't open the door" locked. I can't cook in the thing.... (More)
Answer
I cannot figure out how to work the timer. I can get it set for Hours and seconds but not in... (More)
Answer
How do I clean my self cleaning Crosley oven? I cannot find the manuel. I can lock the oven manually... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Crosley CE35100AA Electric...:
Top Kitchen Range Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Kitchen Range Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
