Question about Kingston Technologies 512MB DataTraveler I (DTI512KR) Hard Drive
Window is unable to format my pen drive.
I have a problum with my pen drive, window is unable to fomat my pen drive. i am using Xp. actually when i was formatting my computer then i forgot to remove my pen drive. after this i am facing this problum. so, solve it as quick as pssible .
    President:
  • 281 Answers
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 02, 2010
2 Suggested Answers
vishal 1419
  • 28 Answers
SOURCE: window is unable to format my pen drive.
first insert your pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
Posted on Jul 24, 2009
Windows xp file integrity failed in desktop
Hello Srinivas.
youre pen-drive "MUST" be formatted with " FAT32 " data system.
win XP "can`t read the NTFS format of win7."
(means also HDD`s to connect them with USB)
this works also for DVD and BR - players if they wont read an USB device.
Greet`s
Gue.
Jun 07, 2013 | Computers & Internet
I have hp 520 leptop my cd rom is not working and my win xp is currept then i wants install the win xp with bootable pandrive but how make the tha pandrive is bootable-
You have problems.
It is possible to to use a Pen Drive/ Flash drive to load windows XP, but the process is never 100% reliable. You need to have the actual equivalent of the XP system disk, or boot disk, on your pen drive. Even then your system may not recognise the pen drive as a system disk. It works for some but not not for others. If you have your original XP disks, try loading it on the pen drive via another PC. It works best if the pen drive is formatted to NTFS, but may still work on FAT32 format. 2Gb pen is a general good size. Trial and error.
There is reportedly an XP Lite version that is more suited to this, but I am not clear on the details or legalities..
Your only real sensible option is to replace the CDROM. You may wish to upgrade to DVDRAM Drive for a few cents more.
Jan 08, 2010 | Microsoft Windows XP Professional With...
Pendrive Shows Write Protected
These are the tech specifications of your pen drive which includes write protection micro S/D switch. So search it and make it read and write
USB 1.1 compliant and 2.0 compatible,
True Plug and Play for hot swap function
Maximum Transfer speed of 1.5MB (12M bit) per second at full speed
Powered directly via the USB port.
No external power or battery needed.
Operating Systems Supported: No driver required for Windows Me/2000/XP, Mac OS 9.0 or later, or Linux kernel 2.4 or later.Only Windows 98SE needs the provided drive
Write-Protect Function: Write-protect switch Security Function: Password protection available via supplied software (Windows environment only) Boot-Up
Function: Makes JetFlash a MS-DOS Boot Disk LED: Flashing LED indicates
Data Traffic Specifications : Size: 75mm X 11mm X 25mm (L x W x H)
Weight: 15g Data Retention: Up to 10 years Shock Resistance: 1000G (maximum) Erase Cycles: 1,000,000 times Speed: Read 9.0 Mbyte/s, Write 8.0 Mbyte/s (Max.) Certificate: FCC, CE,
BSMI System Requirements: Win 98/98SE/ME/2000/XP, Linux Kernel 2.4 and above, Mac OS 8.6 or later
Aug 12, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
May 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Unable to format pen drive
XP has a stupid feature like that. If you did format with the XP style, try to do it manually.
My computer > Locate your usb pendrive >Rightclick and Format.
If this don't work, your pendrive might just be malfunctioning. Replace it if you can, or upgrade to external harddrive.
May 20, 2009 | Sony Computers & Internet
Help me
Is the other pcs windows xp or the files could be in a format that the other pc have not got instaled
Mar 18, 2009 | ASUS P5P800-VM Motherboard
Nov 06, 2008 | Kingston Technologies 512MB DataTraveler I...
Computers & Internet Logo
694 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
