Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
No show of usb Hdd on my coputer
Hi, i just connect a n usb Hdd to my pc. It appeared in "device manager" but i can not see it in "my computer" therefore i am unable to transfer any file to it? Why? Please help> Thanks
  • Anonymous Sep 07, 2008
    device u
I had the same problem. the wd needs a high speed usb port. try changing it to another port.
Posted on Oct 26, 2008
How to recover data from transcend hdd when not appearing in disk management and not showing under my computer. system detects it first with clicking sound but after sometime error appears as device d
Use hirens boot disc look for programme in hard disc tools called test will check and repair mft which should then allow the drive to be seen and then fix errors.failing that route try and get spin right which will fix bad blocks.
Sep 08, 2014 | Transcend Storejet 25m2 500 Gb External...
How to connect to a pc
Install the software first, then connect the usb and power cables, then turn on the unit.
Here is a section of the installation manual :
Software Installation
1. Do not connect this device to computer yet.
2. Insert the utility CD into computer's optical drive, and then the installation window should
automatically appear on the screen. If the installation window doesn't show up, go to "My
Computer" and browse the CD. By executing the "index.html" file, the installation window
will appear.
3. Click on "Private Folder Manager"/ "Playlist Manager", and then follow the on screen
instructions for installation.
4. After the software had been successfully installed, see [Connecting to USB] for cable
Connecting to USB
1. Connect the plug of AC adapter to the connector marked "DC IN", plug the other end into
an electric outlet.
2. Connect the USB cable to the USB connector. Then connect the other plug to computer's
USB port.
3. Press the Power switch and then the blue LED will light up.
4. The computer will detect this device and you can start accessing the drive.
Jul 13, 2011 | Argosy HV372T Mobile Video HDD Media...
Hy my problem is that whenever I connect my External Hdd in the computer,It doesn't show anything.The device is working beacause it's light flashes when i connect it.When I buyed it it worked.I...
Hi ludovicungur,
If your device is blinking fast then it means the problem could be that your are using an incorrect mode of connection for e.g. a USB extension cord , or a USB hub to connect your external HDD.
I would suggests you to remove any external cable or USB hub and then connect the hdd directly to the port on *********** board ,if possible try changing ports and it should work.
Hope this helps ..:)
May 10, 2011 | Office Equipment & Supplies
My laptop doesn't recognize my 80gb harddisk. The light goes on but it down't show in My Computer or anything. What can I do?
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Mar 18, 2011 | Freecom 80 GB USB 2.0 Hard Drive
Western Digital External hard drive not appearing under my computer or anywere else apart from Device manager (USB mass storage device) and safely remove usb hardware, have tried another comp with no luck...
1st dismantle the hdd and change sata to usb adapter. Get cheap on ebay. Certainly, most wd makes hdd motherboard with usb straight away, but still worth to try. BUT, before all check if your pc usb is working, check with mouse or smth. If so, then try change cable. After cable try dismantle that hdd and change mentioned adapter. If none of these work, you then have a lesson, never western digital, seagate only1
Feb 18, 2018 | Western Digital Passport 320GB External...
Western Digital External HDD not appearing in My Computer
It could be that the OS is not assigning a drive letter to your removable drive. To do this, go to disk management and assign one.
Assuming OS is Win 2000/XP/Vista
Right-click My Computer then Manage
Click on Disk Management
Right-click the removable drive and click on Change Drive Letter
Assign a drive letter and click OK
Your drive should now show up on My Computer
Hope this helps.
Jun 20, 2009 | Western Digital Passport 320GB External...
Ihave purchased a SeagateFreeagent 500 gb USB external HDD.It was working very well till I tried to create partitions by using Paragan Disk Management software. In the middle of formatting the partition...
After plugging ur HDD, verify the device is detected or not in Device manager and Try Partitioning Again GUI mode (means in XP).. or follow the steps..
1- Go to Computer Management, Click Disk Management
2 - You will find you External HDD in the Right side
3 - Just Right Click the Drive, if it asks Initialize HDD, just Initialize and Create Partition as u like.
Have Fun
- Rajkumar
Mar 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
No icon showing in My Computer for slave HDD
On XP computer install your seagate barracuda 400g. start the computer. when xp is already boot right click My Computer then select manage. When Computer Management dialog box appear click disk management. Look for the drive that is unallocated and format the drive and follow the instructions.
Feb 17, 2009 | Acer Computers & Internet
if it runs ok on other computers and if it isn't on yours then it is surely a driver problem... try updating the driver using device manager...
Nov 09, 2008 | ASUS A6U Notebook
Wont load songs
What you have to do is this: 1) The HDD Detection tool Connect the device to the PC, load up Musicmatch. On the left click "Portable Device" tab, wait for the PC to show your device. The device should show as "Philips GoGear" if it's showing as "Philips Nike" go to "Tools" on the right, click "Settings" click drop-down menu & choose GoGear. You need to do this everytime you transfer files. If that doesn't work, you need to do this: 2) Manual Re-Install You can re-install the player manually by doing this : - connect the player to your pc by USB cable - uninstall all Installed software for the player - remove device from Windows Device Manager : - Desktop - right click on "My Computer" - select Properties from the menu a new windows appears: System Properties - click on the tab "Hardware" - click on "Device Manager" a new window appears" The Device Manager navigate to the player (should be shown as Philips Nike) at the USB Devices - right click on the player - select "un-install" from the menu - Windows will unsinstall the device - If the player is not listed, the device has been deleted Now to edit the Windows Registry: (Note: Mistakes cannot be un-done so be VERY careful) 1. Disconnect all usb devices. 2. Go to the registry (Start -> Run -> type "regedit") 3. Make a backup of the registry -click "file" -click "export" -Search/Create a logical location ("C:\REGBACKUP" for example) -choose a filename ("registry backup Date.reg" for example) -Please pay attention if Export range is set to "All" -click on save 4. Click on the + infront of HKEY_LOCAL_MACHINE -Click the + of SYSTEM -Click the + of CurrentControlSet -Click the + of Enum -Click the + of USB Here you can remove all VID``s -Before you remove the VID you have to set the right permissions, this can be done as follows: Right click on the folder USB and click on "Permissions", select in the window that pops-up Everyone and and select "Full control" at the permissions. 5. Reboot PC without ANY USB devices connected - install the software and plugins - connect the device to your pc by usb Check if device works and if still showing as "Philips Nike" try the first step again. Hope this helps, Weedy
Sep 30, 2006 | Philips HDD065 MP3 Player
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
59 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
