Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Oven bakes unevenly and burns food
My oven bakes unevenly and burns food. What do I do to fix it?
Jenn Aire oven is about 5 to 7 % cooler than electronic temperature setting. How may this be re-calibrated?
Posted on Oct 14, 2008
I was ready to replace my heating element in my oven for these reasons. I stumbled across a solution totally by accident. I found an adjustment on the BACK of the knob for the overn temperature. Made the adjustment there and have had no more problems. I have a Kenmore stove and had no idea there were adjustments on the knobs themselves.
Posted on Jan 05, 2008
    Novelist:
  • 74 Answers
When foods are burned, soggy, or baked unevenly, it generally means heat isn't being distributed evenly throughout the oven, its escaping out the door or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven. 2) Check the door gasket and, if necessary, have it replaced. 3) Be sure nothing is obstructing the vent. 4) Reposition the oven racks so baking pans aren't too close to the heat sources. 5) Check your baking pans. If they're dark, they may be burning your food. Reduce temperature by 25 degrees F when baking in dark metal or glass pans. 6) Recalibrate the controls.
Posted on Jan 18, 2006
You wrote- "Recalibrate the controls". How?
Posted on Apr 21, 2008
3 Suggested Answers
  • 3600 Answers
SOURCE: how to patch hold in electric oven?
use some high heat two part epoxy let it set up just a little and then plug the hole. you can use titainum putty at a bering supply store but it's expensive but is a good fix.
Posted on Jul 27, 2009
SOURCE: GE Oven JTP15BW Broil Element on, Bake Element off during baking.
I have the same problem. Just swap the 2 wires that are marked as 'broil' and 'bake' on the controller board. But sometimes it switches back, then I have to swap the wires again.
You might want to leave the 'broil' post unconnected to prevent burning food..
Posted on Jul 27, 2010
When baking when oven gets to temperature, and you open the door to put food in The grill comes on and burns everything. I use the middle of the oven, but it still happens. Any suggestions.
Not sure how your oven works, but older ones had a "pre-heat" setting that you would use to get the oven to temp. This ran both the upper (broiler/grill) and lower elements at the same time to raise the heat quickly to temp. Once the oven is pre-heated, you would switch the selector to "bake" and that would only allow the lower element to work after that. If you failed to remove it from "pre-heat", it would use both and burn the food. Just saying.
Sep 02, 2016 | Ovens
Built in oven won't get hot
hello there
Usually, when an oven won't heat up or bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. Now if the oven It bakes poorly Here are two instances of when food "bakes poorly:" When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem
Hope thisis very helpful for you
Best regards Michael .
Mar 08, 2010 | Ovens
Heat escaping, uneven baking, longer cooking times
Either the seals need to be replaced, or you may have weak oven door hinges, and the door is not closing properly.
Only solution would be to replace both hinges if this is the case.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Neff U1421 Double circotherm Electric Oven
The broiler works but the bake side wont heat up but does warm
Hi There
I have found some stuff for you to read and hope this will help. Let me know how it goes.
It won't bake Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. It bakes poorly Here are two instances of when food "bakes poorly:" When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Best Regards Richard
Dec 30, 2009 | Ovens
My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
Nov 27, 2009 | Kenmore Ovens
Oven will not heat.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
Jun 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Wont heat past 200 degres
May 27, 2009 | Ovens
Kenmore oven lower element sporadically heating.
Concealed oven
consealed bake means that the bake element on the bottom had a metal plate above it to make it easier to clean and to allow you to use the lower racks without burning the bottom of your food. To use, you want to make sure that the oven temperature that you set has been reached before putting in your food to be cooked. You also should put the racks one notch lower than you normally would. If you do this, you should have no problems with your food cooking unevenly.
Jun 28, 2007 | Amana AOCS3040SS Electric Single Oven
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
4,775 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
