Question about JVC HX-Z1 CD Shelf System
Help I lost the remote I can not get the sound the system plays ok but not sound
Lost remote for a olin ross sound system bougt a rca universal remote need code for the olin
  • Codes don't seem to be online. General consensus is that they are sold out of white vans and are scam bait. I did find remotes advertised though.
  • OLIN ROSS Replacement Remote Control for OR860, DV606 > ... > Remote Controls > TV Remote Controls ... OLIN ROSS Replacement Remote Control ... Systems Speakers Wireless Audio Stereo System Components ... compatible with the following models of OLIN ROSS ...
  • Lost remote for a olin ross sound system bougt a rca ... > Forum > Remote Controls > RCA Lost remote for a olin ross sound system bougt a rca universal remote need code for ... Lost remote for a olin ross sound system bougt a rca universal remote need ...
  • OLIN ROSS Replacement Remote Control for OR860, DV606 ... OLIN ROSS Replacement Remote Control for ... remote made by Redi Remote for the OLIN ROSS part number DV606 This remote control is compatible with the following ...
  • OLIN ROSS OR880 5 1 Surround Sound System Subwoofer 5 ... OLIN ROSS OR880 5 1 Surround Sound System Subwoofer 5 Speakers Bose retail 350 0 results. You may also like
  • RC: Olin Ross remote issue Olin Ross remote issue. Login: Pass: Register . ... I have an Olin Ross or860 got it from a secondhand ... mean it is a actual Olin Ross system, but thats what I ...
  • Oct 02, 2016 | RCA Televison & Video
    Lost sound in left channel?
    I presume you are playing a stereo cd. Plug some other device, like headphones in to see if the computer is putting out stereo. Use the same plug as the speaker system is plugged into.
    I presume you have swapped the speakers to test them.
    If the speakers work, and the headphones work, it's the amp.
    Nov 26, 2013 | Klipsch Promedia 2.1 Thx Computer Speaker...
    Having just setup a SC-BT230 Home Theatre Sound System, the SURROUND and SOUND buttons on the remote have no effect, so we cannot change the sound modes
    Sometimes these buttons only work for certain formats eg. a cd may not play with more than the front 2 speakers.
    Also, when you press these buttons are you viewing the home cinema on your tv? It may require you to press the sound/surround button, navigate a menu to select the setting then press OK (this is how my Philips unit works)
    Hope this helps.
    Apr 05, 2011 | Panasonic SCBT230 Theater System
    Onkyo ht-s5100 lost sound
    Double check that the approtiate speakers (A or B ) are selected.
    Jul 10, 2009 | Onkyo HT-S5100 Theater System
    LG DvD Reciever (LH-T550) issue (Xbox 360/ TV sound)
    I dont know about a universal remote my friend but a remote is defo needed to ajust and alter sound settings , I have the same system and it can not be done with the reciever alone. The AUX button on the remote has to be activated to get sound thru LG speakers providing your game console is connected to your TV, then a set of audio cables from your TV via the (OUT) ports (this is a must) back into you LG reciever. Goodluck
    Feb 18, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
    Won't power up
    contact the customer care.
    Oct 04, 2008 | Sanyo DP32746 32 in. LCD Television
    Samsung HT-Q100 - Changed Battery on TV remote control
    Just try to clean your remote,this the common problem of dirty contacts of remote it plays a certain unit but to the other won't play.Just open it take a toothbrush with an alcohol brush the remote control board,and dry it for 1minute and close it back then check if working..
    hope this may help;
    Aug 17, 2008 | Samsung HT-Q100 System
    Audio problems
    Have you tried playing around with the Audio after pressing DVD Display? May be your answer.
    Jul 05, 2007 | Sony DAV-S300 System
    JVC HX-Z1 CD Shelf System Logo
    21 people viewed this question
    Top JVC Audio Players & Recorders Experts
    Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
