Question about Watches
Battery replacement How do I open a Concord Impresario Watch Cover to replace battery?
  • jvgiordano Sep 07, 2008
    How do I open a Concord Impresario Watch Cover to replace the battery.
    Master:
  • 726 Answers
There is a little lip on the rear of the watch on the cover apply pressure ity will pop off also it may be a turn one but it sounds and by the look of your watch its a pop off one
Posted on Sep 07, 2008
    President:
  • 1,952 Answers
..how much did you pay for your watch?? I know the
brand intimately. They are not inexpensive watches. Let me pose it
this way,
, would you do work on it yourself? Leave it to the
professionals. Remember the price you pay to the person who does the
job properly is because they know what they are doing.
  • 2,071 Answers
I found a "battery" website that had some suggestions that should be typical of any snap back case watch.
http://www.online-batteries.co.uk/whichb...
specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment.
The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even.
Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it.
Hope this may help you;
Could you tell me what battery goes in a police matrix10811j watch please
If you can find the screw in the watch or anything that holds the watch with cover, open it. If you can find the battery, remember how the battery is placed. then, buy a battery that is like the battery to be replaced and replace the battery!
Jun 28, 2012 | Police Patrol 11401JS/02 Watch for Men
How do you remove back cover to replace 296 wrist watch battery
Thank you for contacting FixYa.
  • Place the watch face-down on a clean towel to protect the crystal.
  • 2
    Gently unscrew the backplate from the watch with a small jeweler's screwdriver and set it aside.
  • 3
    Locate the battery compartment and remove the screw holding the cover in place, using the screwdriver. The battery is a small, round silvery button.
  • 4
    Make a note of the battery polarity before you remove it. Is the battery positive (+) side up or negative (-)?
  • 5
    Take the battery with you to a watch shop or electronics store to buy a replacement.
  • 6
    Insert the new battery in the compartment. Replace the battery cover and reverse the above steps to reattach the back cover of your Peugeot watch
  • Sep 14, 2010 | Peugeot Watches
    Battery replacement
    do you mean you want to replace the battery for your watch?
    This isn't a difficult task to carry out. Simply get a small flat screw driver, use the screw driver to open the back cover of the watch, then you will see the battery of your watch. Remove the battery and replace with a new batter, cover back the watch and that's all.
    Note that you will apply force with the screw driver when you are trying to open the back cover of the watch.
    Good luck.
    May 18, 2010 | Casio Atomic Timekeeping Waveceptor Watch...
    Concord mariner sg battery size ?
    Take your watch to your nearest watch shop and ask them to do it for you.
    You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yourself.
    Mar 02, 2010 | Watches
    Dead battery, how do I open?
    I believe a local watch repairer will replace the battery for around 5$ that should include the battery, depends on the person.
    Generally the battery is replaced by opening the back cover of the watch, in some cases special tools might be required.
    the details of the battery read on top the one currently inside it.
    Jan 30, 2010 | Watches
    Battery replacement - Freestyle shark watch
    Jan 30, 2010 | Freestyle Shark X 75036 Wrist Watch
    I have a la scala tonneau women watch, the watch type is 0310702, i need to change a battery, but so many type and size of battery, which type and size watch battery is the right one?
    The battery has its identification number on it, so if you remove the back of the watch you should be able to read the type without stopping the watch.
    Or you could take it to a watch shop, who will have a stock of batteries. Removing and replacing the back of a watch sometimes takes some practice and I advise you to give the job to an expert, especially if it is a water resistant type.
    Jan 13, 2010 | Concord Industries Concord, La Scala...
    I need a new leather band for my Concord watch.Where can I get one?Numbers on back of watch are14 25 1470.1 then under that 1261034.
    Concord is part of the Movado group. They do not sell replacement parts to just anyone. So if you want an original band you will need to take it to an Authorized Movado/Concord retailer. Or if you wanted to save some money you can take it to a watch repair business that sells and replaces watch bands. Speidel makes some really nice watch bands.
    http://www.concord.ch/servicelocator/index.php
    Jan 07, 2010 | Concord Watches
    Concord Impresario battery replacement
    The watch has a tiny screw holding the back of the watch. You must use a very small jeweler's screwdriver to open it carefully and replace the battery.
    Aug 04, 2008 | Watches
    Watches Logo
    358 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
