Question about Toshiba 57H81 57" Rear Projection Television
Help! Toshiba 51H84..Power light flashing, tv picture won't come on!
The picture won't come on..The power indicator is flashing; but no picture. Second time this has occurred in 3 years. I have kids; and the tv is a necessity for home schooling. I have seen solutions on here; but have no idea what the boards etc, look like. I am no electronics repairman! HELP ASAP! The power light is flashing and I can not turn the tv on or off. I unplugged the power and turn it on and it made the sound like it was going to work but when I pressed the power button it still did not work.
  • 1 more comment
  • lwill8f Nov 30, 2008
    yes
  • Anonymous Dec 04, 2008
    I have the same problem , Light flashes and then it cuts out, Light still falshes,
  • stardom Dec 07, 2008
    toshiba rear projection tv-black-power light keeps flashing from green to red-makes sound as if its coming on but doesn't. No picture no sound. Changed remote batteries and chanced plug fuse but to no avail.
  • 3 Answers
You need a new HV transformer. Usually you can just buy the transformer itself. It's a little black tower on the backside of the tv. If it's not that, it's the convergence ic's. There's two of them, given it's a toshiba, the part number is more than likely stk392-110.
Posted on Oct 09, 2008
51h84 tv input jacks do not work
First is unplug power from set and or a box etc an wait a short time--power back and see if units reboot to cure this---
The model indicated MAY use a Hyper board--lots of problems--controls all signal from all inputs and expensive to repair (part no longer sold).
Failing above you have a problem with the circuits that handle inputs on the rear or even with the microprocessor the set uses.
Apr 08, 2012 | Toshiba 51H84 51" Rear Projection...
I have a Toshiba 51h84.I push the power button and I get a solid red power light. There is a click from inside, kind of like a relay clicking on. No picture, no sound. If I leave it on I get an occasional...
Tv have "LAMP" indication LED light blinking?The tv projection lamp is dead,require changing.Hearing alot of clickings sound too?Mean the board,call the Ballast board is dead.Require change the Ballast too.The Ballast board,the board that help to ignite the projection lamp.
Aug 06, 2010 | Toshiba 51H84 51" Rear Projection...
First thing that needs to be checked is the convergence IC's. Those IC's are located in the signal board and are really hard to remove. You need an experience technician to fix it for you :)
May 27, 2009 | Toshiba 51H84 51" Rear Projection...
Screen turns blue then shuts off.
I already replied but once again..
Symptom shows Blue CRT (picture tube) in your TV might defective and need to be replaced. Its high tech repair issue, so contact tv tech person if you don't have enough knowledge about tv repair.
Sep 05, 2008 | Toshiba 51H84 51" Rear Projection...
Tv turns blue the shuts off.
symptom shows Blue CRT (picture tube) in your TV might defective and need to be replaced. Its high tech repair issue, so contact tv tech person if you don't have enough knowledge about tv repair.
Please Help Fix My TV - Toshiba 36" Model No. CF36G55
No, in answer to your question, I have not solved this problem! I am waiting to hear from someone on your site.
Thank you.
Apr 12, 2008 | Televison & Video
The solution is you have to buy a new better tv with a good extended warranty in payments. JZ
Jul 09, 2007 | Toshiba 51H84 51" Rear Projection...
Toshiba 51H84
convergence IC's need to be replaced
Dec 12, 2006 | Toshiba 51H84 51" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
252 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
