Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Oven doesn't maintain temperature
Our oven doesn't maintain temperature. What might be the problem?
  • Anonymous Mar 15, 2014
    does not maintain temperature setting
    doesn't maintain temperature setting
  • 84 Answers
The problem you describe is usually caused the the relay control board. This controls the power to the bake, broil and convection elements. At www.FixYourBoard.com, we commonly get this complaint. The display board and relay boards can be repaired as a set quickly and reliably. Here is a related post http://blog.applianceboards.com/troubleshooting/jenn-air-acb-jew-jjw-mew-sce-svd-and-ww-series-built-in-ovens-cant-keep-time-and-cant-be-calibrated-solution-is-here/
Posted on Apr 04, 2012
Make sure you're oven is vented properly. I had this problem - the oven turned on and reached the proper temperature then didn't maintain it. No one could figure it out until I had them pull out the oven and we realized the cabinet installers had somehow reversed the botton drawer box so there was no venting and the oven is autotmatically set to turn off for safety reasons when it reaches a certain temperature for x-amount of minutes (I can't remember what that is). A quick solution was to open the bottom drawer for venting until the cabinet could be fixed.
Posted on Jan 30, 2007
    Novelist:
  • 74 Answers
When an oven doesn't maintain the set temperature, first make sure no one is allowing the heat to escape by opening its door. If not, the oven control either needs to be re-calibrated or replaced. To have the control replaced, call an appliance service person.
Posted on Jan 18, 2006
5 Suggested Answers
mastatech
  • 478 Answers
SOURCE: GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Posted on Mar 14, 2009
  • 108 Answers
SOURCE: My jenn air single oven does not maintain
this is what you most likely need. Age, or the clean cycle, can cause them to start to malfunction.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-W131B-%3d%3di1364&PartID=1364
It is inside the oven, and comes out/goes in pretty easily, but you have to be careful when removing the old one, not to loose the wires in the hole, because then you have to pull the unit out from the wall and remove the back in order to plug the new one in.
Posted on Jul 28, 2009
SOURCE: my oven does not maintain its temperature. Any
HIRED A SERVICE TECH
Posted on Sep 20, 2009
SOURCE: 5 yr old Jenn Air Electric oven won't maintain oven temperature
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
Posted on Oct 23, 2009
My oven is not maintaining temperature
check the door gasket is in good condition.if the door is closing fully properly.check the ground level.
Apr 13, 2014 | Frigidaire Ovens
We have an electrolux E30EW85GPSS double oven. The lower oven appears to work properly. However, the upper oven will bring itself up to the set temperature but after reaching it, does not stay on and...
Hi
This means a loose/broken wire on the oven temp sensor or the sensor is bad and should be replaced. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control board however, as the issue is only with upper oven it is most likely that the temperature sensor is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jun 17, 2011 | Electrolux E30EW85GSS Oven
Mar 14, 2009 | Ovens
Mar 09, 2009 | Jenn-Air JJW8130D Electric Single Oven
Oven will heat up, but then will not maintain desired temperature.
YOU HAVE A BAD ELECTRONIC RANGE CONTROL OR ERC
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
May 29, 2008 | Magic Chef 9512 Electric Single Oven
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
918 people viewed this question
Top Jenn-Air Ovens Experts
Craig Butler
Craig Butler
Sal De
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
