Question about Nokia N70 Cellular Phone
How to format
I have put a font and when i format my phone, then it wont go and the defult setting won'tcome
Ok a very simple solution to ur prob may be as given below:
switch off ur phone first.
then click the following buttons simultaneously/at the same time:
1.send/call green button
2. the button with the digit 3.
3.Power button
keep these three buttons pressed for a few seconds and ur phone will get formatted
Posted on Sep 11, 2008
Television won;tcome on when usuin remote
Have the remote tested---also make sure set does not have a feature to lock the remote out-----if these are not the case it could have a bad remote receiver but if any remote functions work the receiver is ok.
Aug 31, 2012 | Sceptre X37sv-Naga 37 in. LCD Television
My mobile doesn't get on
full reset and full format
format > set off press boyun *3 yes then on set wil bi format
reset *#7370# securitycod 12345 if not chang defult
May 07, 2010 | Nokia 7610
Incoming email font too small
Just press "ctrl + +" or "ctrl + -" or scroll "ctrl + mouse wheel up" or "ctrl + mouse wheel down" to increase or decrease the font size.
Jun 25, 2009 | Office Equipment & Supplies
How to format s40 mobiles?
please go to phone settings and then to factory settings.then give the password and your mobile gets formated.
Jan 07, 2009 | Nokia 6280 Cellular Phone
Sending msg at my nokia 7610
first you have to call your service center and ask them to send you the messaage setting after when they send you the message setting then save as defult.then try make some messages.
if its wont help you out so its a virus problem you have to format your mobile fone by the following steps:
1. go to the settings.
2. then open the phone folder.
3. then general.
4. in general you will find the option that says ""orig. phone settings"" press on it then it will ask you the password if you put the password on your mobile then put the same one in it or if you dont have password then put 12345 it will totaly restore your phone settings.
NOTE: make the back for all of that files imagers folders which lies on the phone memmory before formating.
thanks,
your friend.
Oct 20, 2008 | Nokia 7610
Format 6280 nokia
go to menu at your mobile screen >select settings > now select "Restore Factory Settings"............that's it you can do in nokia 6280
Apr 03, 2008 | Nokia 6280 Cellular Phone
Samll font size
this should do the trick...press star, call button(the green one), three, and power button all together while powering up your phone..press them until formatting comes out then you release them..note: don't release buttons until formatting does not appear....try and try until you succeed
Dec 15, 2007 | Nokia 3230
Increase font size on Nokia E65 Mobile Phone
NOKIA SAYS THAT THE FONTS ARE NOT CHANGAABLE THEY ARE WRONG!
There is quite a simple way to change system fonts in the Nokia E65 phone.
The following is how I did it in my E65.
First you have to select the memory as phone NOT the memory card.
Then connect the phone to PC through the standard USB cable. When the phone prompts you, select “Data Transfer” NOT PC Suite”. Once the phone is connected you can view it as a removable drive. First check if a directory named “Fonts” exists.
If it does not exist, just create it in the resources folder. If it already exists, just make a backup copy of it.
Now, go to your PC Fonts directory (usually c:\Windows\Fonts) and do the following:
You can use any TT font I used a font called Baveuse.TTF as the bold I used the Baveuse3D.TTF as my normal font. You have to have (3) three fonts and they have to be renamed to what is below or it won’t work.
Copy Any (True Type you want) font file to:\resources\Fonts\NSSB60.ttf
Copy Any Bold (True Type) font file to:\resources\Fonts\NOSNR60.ttf
Copy again the same normal Bold (TT) font file to:\resources\Fonts\NSTSB60.ttf
The (3) Three fonts have to be renamed as above or they wont work!!!
Then just disconnect the phone from USB turn it off. Then restart your phone and put the memory back to the card and you will have the new fonts in place. This is how I did my E65 and it worked ok for me. If the fonts are to big just start over delete the three fonts and use a different font to you find one you like I like the Baveuse.TTF font its personal choice.
Oct 18, 2007 | Cell Phones
Printing differently than what is on screen
TRY PRINTING THROUGH MS WORD. OPEN MS WORD - CLICK ON FORMAT - FONTS - IN FONTS PAGE : SELECT TIMES NEW ROMAN UNDER FONT , REGULAR UNDER FONT STYLE , FONT SIZE AS DESIRED. UNCHECK EVERY OPTION OK CHECK WITH A PRINTOUT OR ELSE CLICK ON TIMES NEW ROMAN UNDER FONT AND CLICK ON DEFAULT, THE SYSTEM WOULD ASK YOU IF IT HAS TO BE SET AS DEFULT-SAY YES.
Sep 18, 2007 | HP DeskJet 5150 InkJet Printer
Nokia N70 Cellular Phone Logo
44 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
