Question about Goodman CLQ36AR49 Air Conditioner
5 year old Goodman CKJ48-1A Condenser Unit
The compressor has been burning the wires and contacts at the compressor conection.
The pressures at 95 degrees outside were 70/275 for a long time, but lately they increased on the low side and decreased on the high side at the same 95 degrees outside 83/250.
I am getting 63 degrees inside of the house when the external temperature is 95, but the burning of the conectors is becoming worse.
Can you help.
    Problem Solver:
  • 14 Answers
Do what they said also when those pressures equalizing it might be your compressor going out
Posted on Oct 16, 2008
Check your sources of power all the way back to the meter can. odds are a breaker or wire is loose or burned and starving a line for voltage. check breaker wires for snugness and pull breakers and look at the back side where they clamp on to buss bars. you should see clean copper and silver connections. no black, no gray and no charr. be sure wires are snug in breakers. heat and amps over time cause expansion and contraction of dissimilar metals aka loose wires and poor connections equal high heat and amps and loose wires and burned connections. you may also have a weak start cap run cap or loose compressor terminal. all should be checked.
Posted on Oct 11, 2008
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
The high side psi. should be at least around 100# ps more than the low side psi. The low side psi sounds ok, but the high side tells you the problem is the outside condenser is plugging up! Go to an ac supply house,and buy a gallon of coil cleanner and dilute it and fully clean the outside condenser coils ,after it's cleaned ,check the charge now!
Posted on Sep 07, 2008
Pressure switch 120 volt compressor how to bypass pressure switch
Un-plug the compressor and remove the cover to the pressure switch. Inspect wire connections for burned /discolored wires. If not burned, look for button to manually trip switch (switch has on /off lever, place in on position). Test with ohm meter for continuity. Switch is normally closed and contacts are usually visable to evaluate condition. Some compressors use a very small sealed pressure switch that is also normally closed.
Oct 25, 2012 | Campbell Hausfeld 5HP 20 Gallon Single...
Olds aurora 95 ac -- freon good. starts good in am. runs great. ac blows ice cold 60 degrees ( using a lazer temp gauge) out side temp 77 degrees -- ran for 2 hrs. ice cold. Then outside temp over 85...
About the only thing that it could be is a dirty coil,or some one over charge the system, I have seen just a layer of dust cause the compressor to cycle off to its thermal over load. Clean the coil.
Jul 08, 2011 | Heating & Cooling
2000 Golf gls 4D AC static reading 100 psi, with the engine start and compressor working low reading 35 psi. The A/C blows warm for about 5 to 10 mins after that it can blows cold... problem with...
only 100 psi ,should be around the 200 mark ,i suspect that you could be low on gas ,forget these cans from supermarket and have it checked out with the correct machinery ,have it emptied out and vacumned up then reiflled to the correct weight of gas for this vehicle which i think should be 750 grms R134 then test for pressure and i have a funny feeling it will work correctly ,
Jun 29, 2011 | 2000 Volkswagen Golf
AC blows warm. fan + compressor don't seem to engage.
The system could be low on refrigerant. The A/C pressure switch will not let the compressor run if the system pressure is below 28psi or above 455psi to protect the compressor from damage. At low pressures not enough oil (mixed in with the refrigerant) will circulate, and at high pressures, the compressor seals will likely blow. You can get a set of A/C manifold gauges for R-134a and check the system pressures yourself or get a shop to check it and possibly add some R-134a. If the system pressure checks good, then the A/C pressure switch, the compressor clutch, or some relays will need to be checked.
Feb 05, 2011 | 2003 Honda Odyssey
Dometic Rooftop RV Air Conditioner works as long as outside temps are under 95 degrees then it trips the braker. can the outside fan not ajusted in the shroud right or low refrigerent cause this.
Hi, most all a/c that are on the market are designed for that exact temperature, 95*F. After that they will loose up to 40 % of there efficiency. But tripping the breaker indicates it is working to hard and over ampping so there is a problem up top. It may just be a very dirty condenser coil which will cause this unit to build the high head pressure causing the compressor to draw more amps then normal and will trip this breaker. If you can, go up and remove the cover. Watch it run to see if the condenser fan motor is running good. Look at the coil for dust and dirt build up. Its a good sign that it cools at 95* F, so I believe its just a dirty condenser coil. This will cause your internal pressures to peg out in temperatures at 95 and above!.Even if it looks OK, kill the power and run a water hose up top. Was out this coil and watch the dirt run out of it. I have seen the head pressure on units at 400 P.S.I. with a dirty coil and after washing drop 200 P.S.I!! If the fan is running good, this will be your problem. Before you go up, take a good flat heat screw driver along and when you are done cleaning this check the electrical box, and make sure all of the main connections are good and tight. Check to see if there are any signs of burned wires as this will also trip breakers as when loose they will create heat and burn the ends. This will solve your problem. You may want to check the 2- wires at the breaker also, just be sure it is off and tighten just the wires that go into the breaker as they will be dead at that point. Please use caution!. Doing all of this will take care of your problem, I am sure unless you have a internal compressor problem which I don't believe you do. Please don't forget to rate me as I know you will be kind to me. Please keep me posted and I will be checking up on you also. I wish you the best.
Sincerely,
Shastalaker7
A/C, Heating Contractor
Aug 28, 2010 | Dometic Rooftop RV Air Conditioner
I am working on a M # GPG13420901AB. This is a 3.5 ton package unit that replaced a 3 ton package unit on 1700sq/ft single level home. Old unit was working fine but was replaced when the home was...
It sounds like you are low on charge. I think you have a thermostatic expansion valve and you need to check the subcooling, you should have 12 to 15 degrees at 95. At 95 degrees your head should be about 280# for a 12 or 13 SEER unit or higher depending on the effeciency. At 78 to 80 degrees indoor depending on the humidity, that is normal. The valve will open to try to fully feed your indoor coil and it sounds like your head pressure is to low to force enough refrigerant thru the coil.
Aug 16, 2010 | Goodman Heating & Cooling
95 Chevy Surburban. Air conditioning issue, front air blows warm, rear unit blows cold. Have replaced orface 3 times, replaced compressor 3 times, replaced accumulator 2 times, flushed condensor,...
they run off of the same compressor if rear is cold and front is hot the hot and cold function in the heater box is not working possible cable problem ? or a vacum line under dash
Aug 04, 2010 | 1995 Chevrolet Suburban
I live in AZ. my RV rooftop AC works as long as outside temps are under 95 degrees then it trips the braker. can low refigerint or outside fan not in the shrowed cause this?
The fan not in the shroud may cause this. Are you sure the condenser fan is even running or running at the right speed? If its not running, the compressor head pressure will build up until it possibly pops the breaker.
Jul 28, 2010 | Dometic Rooftop RV Air Conditioner
UNIT IS ONLY 4 YEARS OLD AND IS ON ITS SECOND COMPRESSOR SUCTION PRESSURE SLOW ABOUT GOING DOWN AND DISCHARGE PRESSURE GOES TO 210 THEN WILL DROP TO 200 .UNIT HAS 10 DEGREES SUBCOOLING BUT SUPERHEAT IS...
Hi, sounds as though for this to be its 2nd compressor for such a newer unit, the superheat was not right when the compressor was installed. I don't know what freon you are using the new R-410A or the regular R-22. There's a big difference in pressure, but now I see your pressure reading and its R-22 for these readings.For a 2 ton unit, you would use the superheat charging method for a unit that doesn't use a thermostatic expansion valve ( T X V ) and not the sub-cooling. A 23 degree super heat at that outdoor ambient temperature is way to high for that unit, you will loose the compressor again!!. Super heat killed the compressor is the saying and that's a fact. Suction pressure should pull down just as quick as the head pressure unless the valves are going and weak, or you have a scroll compressor that has a valve plate that is going, or you are low on charge. With a ambient of 95*, you should be at around 270p.s.i. on your head pressure as 210 to 200 is way low. Suction line temp should be around 68 to 70, with a suction line temperature of 50 to 51 degrees, which would give you a 10 to 12 degree F super heat. I don't know when the second compressor was installed, but it has to be low on charge to be such a low head, and high super heat and you will loose this compressor again, its only a matter of time before you have a burnout. It was either under charged when installed, or has a very small leak at one of the joints. I hope the liquid line drier was replaced also. It shows me you have some knowledge on a/c operation, so you need to get that superheat down to between 8 and 10 degrees for this unit to cool properly, and leak check it also. Did you buy a extended compressor warranty? Lets get the head pressure up and superheat down and you should be OK unless the valves or valve plate is weak. Once you loose the valves, you will have a lower than normal head pressure and a high suction pressure. Compressor just won't pull down anymore. I hope I have been of help to you and ask of you to be kind when rating me. I will be here for you if and when you need me for anything.
Sincerely,
Shastalaker7
A/C & Heating Contractor
Jul 02, 2010 | Weather King 10AJA6001AH Air Conditioner
95 Eldorado, a/c compressor off, low refridgerant
I also recall that you have to disconnect the battery for 30 seconds to clear the error and allow the compressor to kick in while charging.
g'luck
Jul 16, 2009 | Metra 92 95 Cadillac Eldor/Seville
Goodman CLQ36AR49 Air Conditioner Logo
634 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
