You can test the humidistat fairly easily, using a volt-ohm meter. Just set the meter to RX1 scale and attach its leads to the humidistat's terminals. Rotate the humidistat's knob as far as it will turn in both directions. If the volt-ohm meter registers zero ohms through only part of the humidistat dial's range, the humidistat is working. If it registers zero through the entire range, it's broken and must be replaced.
Dehumidifier Overflow Cutoff Switch Test- Using a volt-ohm meter, you can tell if the overflow switch works or not. Clip the leads to the terminals on the switch. Depress the bar or trip lever on the switch. If the meter's needle doesn't show continuity and no continuity as the switch is clicked back and forth, the switch is probably faulty and will need replacement.
My Fedders Dehumidifier A7DH45B2A*A-R 45Quart, works great but it leaks from the bottom of the unit!...
(More)
My Fedders Dehumidifier A7DH45B2A*A-R 45Quart, works great but it leaks from the bottom of the unit! I've checked for cracks in the bucket but its fine and collects water too but the unit still leaks:( Everything else is fine with the unit but this. What is going on here? It worked without any leaks for a couple of years and now this! And how do I fix this problem?
The dehumidifier powers up and the fan runs, but no moisture is taken out of the air as the...
(More)
The dehumidifier powers up and the fan runs, but no moisture is taken out of the air as the reservoir well stays dry.
fan runs but no water is removed from the air. The room humidity display changes (lowers), but no...
(More)
fan runs but no water is removed from the air. The room humidity display changes (lowers), but no water is accumulating in the tank. I took the back off and no ice is accumulating
I have a Fedders A7DH65B2A dehumidifier and it has worked fine for a couple of years. In the last...
(More)
I have a Fedders A7DH65B2A dehumidifier and it has worked fine for a couple of years. In the last month it shut off and now won't power up. When plugged in, the control panel will not even light up. Seems totally dead. Do you have any adice? Is there a fuse on the unit? Please advise.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
