Question about HP Pavilion F1703 17" LCD Monitor
F1703 17" Keeps blinking each 4sec, but I can see the PC scrren
Evry 4 sec the screen lights up, and I can see the PC image for less than 0.25 sec or so. Also whne the PC is not connected. it keeps blinking.. cant get into menu our settings.
  • stacia142 Sep 16, 2008
    I have the exact same problem.. tried a different outlet. nothing worked
It is a stupid moniter I have ever seen...I have 4 monitors with same problem...given many times for repair...no use...
Posted on Sep 07, 2008
Red light flashes 4 times
What is the brand name to your TV? Provide more details please. If you wish to get more details about the blinking codes, check this link. It has http://electronicshelponline.blogspot.com/ blinking codes details to many brand televisions. Pull up older posts there by its left side bar, or, view it in 'Timeslide' option. The posts are not arranged in an alphabetical order.
Jun 19, 2013 | Televison & Video
When i reboot my Zmodo dvr I Can't get menu to come up or mouse to work HDD light keeps flashing,blinking hdd light,HDD indicator light
I had the same problem. Did their online tech support and Patty told me to hold down the "rewind" button on the DVR for 20 secs. You should now be able to right click your mouse to access the on screen menu. You will now want to go under system, and a/v setup and change the device to VGA instead of Vout. Now you can reboot and not have to go thru holding down the buttons anymore. Worked for me.
Oct 02, 2012 | ECHO1USA Zmodo 4 Ch Complete Dvr Kit -...
While my wife was washing, the water was turned off to the washer. She hit the pause/cancel button. Now that the water is turned back on, when we hit the start button, all the lights turn off.
Hello,Select any button except start and hold it 4 seconds let go 4sec hold 4sec let go 4sec hold 4sec see if unit goes in service mode all lights will come on hit same button again unit will go into aut test and run a cycle when its done unplug for 5 minutes plug back in and see if unit works.
Jun 18, 2011 | Maytag EPIC MFW9700S Front Load Washer
My computer scrren is dark i cant barley see how do you fix the screen light?
control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
hope this helps
Nov 17, 2010 | Computers & Internet
Hello I have a hp Pavilion DV3 1075us and recently It has started presenting some problems. I cannot initiate it the screen keeps blinking in an white flash in an interval of 4 sec. And the numlock and...
The blinking lights indicates the problem:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Also, if the computer starts up and nothing is happening, the lights are on and the screen is dark, then the CPU is broken.
Jul 04, 2010 | Computers & Internet
I bought a 2gb memory stick for my psp, once i insterted it in an orage light keeps blinking and while i put it on usb mode it says there is no memory stick insterted when there is
If the MS light keeps blinking continuously, that means that the PSP cannot read the MS you inserted. That happens normally. You just need to take it out, then put it back in. That's the simple fix there.
To pull it out, open the MS slot first. Gently push the exposed part of the MS, inward to pop it out.
When putting it back in, make sure that it's perfectly aligned and that the light blinks fast only for a couple of seconds (2 to 4sec) and then immediately stops. That means, the MS is properly placed and can now be read.
May 15, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
Image for first 3 secs... light still on green
correodemie, Your ACER AL2016 will need to have it's "switch-mode-power-supply/CCFL inverter supply" trouble shooted and repaired. DIY repair cost less than $30. Out of warranty service $35 to $75, more if circuit board replaced. Read my and other techs FIXYA profiles to discover all the options you have for your BLACK screen symptom. Follow the links to other web sites for even more useful info. DO THAT before you do anything else. 12fixlouie
Feb 03, 2010 | Acer AL2016 W 20" TFT LCD Monitor
50in samsung hd tv scrren wont turn on...red lights just keeps blinking
Change bloated caps on power supply pcb. You'll see them clear. That's should be it!
$10,00 for parts+ couple hours of labor and, you good to go!
95%. If you won't find any bloated caps, relax, it's time to get a new signal/main board. Can't fix those! Only replacement. Used one is ok.
My last case was a similar, 50" Samsung lcd panel with 4 1,000.00 mfd/16v.
good luck.!
Jan 23, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
A drop image on screen
hi i have panasonic NV DS 65 initially when i power on the cam it started then after 5 to 10 sec the power light automatically flashes and the buttons on camera doesnt work any more. but now the problem has got worsend the powen light keeps on flashing and no buttons work moreover a drop image is flashed on the screen.
plz have me solve my problem
sam_rav
Jan 24, 2008 | Panasonic NV-DS65 Mini DV Digital...
HP Pavilion F1703 17" LCD Monitor Logo
106 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
