I need assistance for changing the ink cartridge on my epsom cx5500. I don't seem to be able to get the ink cartridge to stop at a place where it is accesable
    Sergeant:
  • 320 Answers
Go to the below link and follow the steps..
http://www.epson.com.au/products/multifunctional/styluscx5500_specs.asp
Thank you
Posted on Sep 07, 2008
Epsom print EX-200 wont print after l changed the ink cartridge
Did you pull the tape off the top of the ink cartridge?
Oct 17, 2015 | Office Equipment & Supplies
I cannot stop the ink cartridge holder to stop in the correct positioo to replace the cartridges on my epsom cx5500 printer
Hello jgw_cansdale,
Welcome to Fixya.com!
If the Ink light (fon3_66.gif) is flashing that means one or more of your ink cartridge is low on ink, and if it's steady it means one or more is out of ink. For Epson printers, there are lots of ways to identify whether your printer is out or low on ink. For today let's just stick with the printer itself.\
Remember: A flashing fon3_66.gif means LOW ON INK, and a steady fon3_66.gifmeans OUT OF INK.
1. Open the scanner bed by lifting it up just like opening a brief case. By doing this you should now be able to see the carrier area this is the area were the ink carrier or ink holder moves left and right,
2. Press the Ink button. Now remember flashing means LOW and steady means OUT of ink.
If the Ink light is flashing, and you pressed the Ink button the carrier or ink hold will move under a small arrow just right above the carrier to point to you which ink cartridge is low on ink. pressing it again will point to another if you have multiple cartridges that are running low, if not it moves directly to the ink cartridge replacement area were you can pop the carrier's lid open to access the inks.
If the Ink light is steady, and you pressed the Ink button the carrier or ink hold will move under a small arrow just right above the carrier to point to you which ink cartridge is out of ink. pressing it again will point to another if you have multiple cartridges that are out of ink, if not it moves directly to the ink cartridge replacement area were you can pop the carrier's lid open to access the inks.
Regards,
Deathschythe33
Aug 22, 2011 | Office Equipment & Supplies
Replaced all ink cartridges with epsom cartridges. Printer shows ink incompativble- replaced with identical cartidges and printer wont print
the inks u had replaced might not be the compatible with ur printer you need to change another inks which are compatible only
Jan 26, 2011 | Office Equipment & Supplies
How to persuade my epsom stylus DX6050 printer to accept non epsom ink cartridges
i have a continious ink setup on epsom dx5060 system is telling me to change the cartridges they have reset chips in them????
Jan 21, 2011 | Epson Stylus DX6050 All-In-One InkJet...
How do I change a cartridge on an epsom BX310FN using the printer buttons?
You need to open top cover.
Find lock you need to press that lock so upper cover is faced off.
You can find that lock on the front middle side.
You need to press it so uper cover is up then pull ink cartridges from it.
Then reattach new cartridge.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 22, 2010 | Office Equipment & Supplies
How to change ink on a epsom stylus 215 printer
Hi Eileen!
Use the instructions here to change your printer's ink cartridges.
(Use the arrows on top to switch pages until you get to "Remove and Install Cartridges").
Best regards,
Pelu.
May 10, 2010 | Epson Office Equipment & Supplies
I want to change my ink cartridges in my Epsom Stylus cx8400 but when I open the top of the printer the cartridge holder slides too far over to the right to open it - it doesn't align with opening..
Hi
Yes it should stop in it place for you to get at the cartridges but it not ok It up to you can try to stop it by switching the power of when it moving and hope it stops in the right place or chantilly move it by hand to get at it.
I know it say in the manual not to stop it when it moving but what can you do? It cant harm it that much it just like if there is a power cut it would do just the same.
Feb 09, 2010 | Office Equipment & Supplies
Epson Stylus CX5500- Changing/Installing Cartridge (BIG) problem
they are proper mardy machines only happy when using original epson cartridges
Sep 20, 2017 | Epson Stylus CX5400 All-In-One InkJet...
How to reset 73/91 Cartridges for Epson CX5500
SSC utility is used for resetting waste ink counter, not for ink level counter (chip at ink tank). If you wish to reset ink level counter (chip), you must use hardware resetter, or use CISS chip with autoreset function.
Oct 18, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Epsom Rx620 states use originals for ink cartridges
Try to hold down both 'stop' and 'B&W' button when you press the 'on' button to start the printer machine. This should erase the error message and let you print.
Regards.
Gordon
Sep 25, 2008 | Epson RX620 All-In-One InkJet Photo...
79 people viewed this question
jasbo
jasbo
