Question about Garden
String trimmer backfiring
This trimmer will not rev even on wide open throttle and backfires badly. Have tried another carburettor on it (also from a Homelite trimmer) and there is no change in performance.
  • 50 Answers
Backfiring indicates that timing is incorrect. Disassemble and check the flywheel and coil. They should be tight and alligned.
Posted on Feb 14, 2009
95 dodge dakota back fires above 2000 rpm
A tune-up is always a good idea. Is the system running rich or lean? Any applicable trouble codes? Is it back firing out the exhaust? If so, I got two thoughts, either an exhaust system problem or exhaust valves?
Jun 13, 2016 | 1995 Dodge Dakota
Why does my ATV bog down and die when I keep the throttle wide open?
If you are lucky, you might just need new fuel filter and the fuel bowl cleaned out, and maybe new air filter. If not so lucky you need carburetor rebuilt. Backfire is usaully caused by engine running too lean ( too much air for the amount of fuel present). Fuel bowls get gunk in them and the fuel needles and fuel jets get varnished up. The accelerator pump gets worn out gaskets and/or bellows and doesn't give the right amount of fuel mist when you accelerate.
Full Choke is indicative of a motor starved for fuel
Mar 04, 2015 | ATVs
Backfire carb
Urals need to be throughly warmed up before riding, old technology engine. As far as the revving, I'd Check for vacuum leaks at the Carburator with some carb cleaner while idling, and if that's not it, I'd check the choke.
May 27, 2013 | 2010 Ural Patrol 750
2001 sportster backfires when bringing the revs up
Hi Anonymous, popping, coughing, spitting, or backfiring through the carburator or induction module can be caused by air getting sucked in combustion chamber do bad intake seals leaking. Leaking exhaust gaskets can also be suspect. Remove air cleaner and backing plate, while engine is idling spray WD-40 or Brake Kleen around intake manifold to head area, if RPM's increase you have an intake leak and seals need to be replaced, also spark plugs will be burning whiter than normal. Good luck and have nice day.
Jun 12, 2012 | 2001 Harley Davidson XL Sportster 883
had a similiar prob with a triumph. It backfired at low revs, a delay between throttle opening and revs increasing and bike felt like it wanted to stall at low speeed. Got the Carbs cleaned to find out the problem was infact Failing Ignition coil. Get those checked first before commiting to replacing other parts.
Mar 21, 2009 | 1998 Yamaha XV 535 Virago DX
1988 chevy pickup 4.3 V6 that has constant backfire
bad dis cap or rotor maby a bad plug wire or valve sticking or out of adjusment
Mar 17, 2009 | 1988 Chevrolet C1500
Garden Logo
488 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
