Question about Whirlpool Dryers
Whirlpool front load gas dryer.when I was trying to push the dryer little bit backward some beeping noise came and the control panel light came up against where it say control locked. Question how to get this unlocked where I can get this to work agin. now I can not start the dryer.
  • 725 Answers
On the lower right hand side of the control panel, hold the bottom button in for 3-5 seconds until the light goes out.
Posted on Sep 07, 2008
My duet dryer control lock is blinking and beeping....tried pushing the end of cycle button, but still is blinking and beeping. Any other suggestions??? We have had lots of humidity this summer and...
It is not related to moisture directly by any chance. If END OF CYCLE does not work. it can be short circuit inside which can cause this. Moisture can cause short circuit or the whole control board may be faulty.
Aug 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool dryer just beeps when you try to start it. The panel is lit up the door is shut, push start and it just beeps...any idea what the problem is
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
NOTE: When the dryer is running and Control Locked light is on, the dryer can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If holding doesn't unlock the feature, it is likely a faulty interface. I am having the same problem with my Whirlpool dryer and it is the interface, but it seems that a lot of people are able to correct the issue just by pressing the End of Cycle button for 3 minutes.
Here is a link to parts, numbers, and prices from Sears:
http://www.searspartsdirec t.com/partsdirect/getSubComp.pd?modelNumber=GGW9250PW1&productCategoryId=0151200&brandId=1198&modelName=RESIDENTIAL-DRYER&diagramPageId=00001&componentDescription=TOP%20AND%20CONSOLE%20PARTS&documentId=W0508037&blt=06
Jan 09, 2010 | Whirlpool GEW9250 Electric Dryer
Can't get back panel off gas LG.
The back panel does not come off. If you have a rear control model as pictured in your post: Open the door and remove the two phillips head screws at the 5 and 7 O'Clock position just in front of the lint tilter. Next, use a putty knife to push in on the clips holding the top panel down. They are located in the seam where the front panel meets the top panel, near the left and right edges. Swing the top panel up to gain acess to the two phillip head screws holding the front panel on at the very top of the front panel. Disconect the the door switch, drum light, and then the sensor plug near the lint filter. This allows you to fully remove the front panel. The thermal reset is located on the left side of the burner housing, near the front. It is about the size of a dime, with two wires to it, and a quarter inch long pin in the center of it. Push the pin in firmly. (it will only move a little bit) Reassemble dryer. CLEAN OUT VENT AND CORRECT IMPROPER VENTING to prevent a repeat of the condition.
Jun 07, 2009 | LG DLG2532 Gas Dryer
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Mar 13, 2009 | Whirlpool GEX9868J Electric Dryer
Whirpool GGw9250Pw3 no power on Control Panel Inside light works
In my case, the problem was a dead main board. The board cost $190 and the overall repair cost $335. I will never buy another Whirlpool due to this experience.
Dec 11, 2008 | Whirlpool GGW9250PL Gas Dryer
Beeping noise at night
possible glitch from main power from house ,, or main control board failure
Nov 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer clicks when start button pushed but does not start.
A quarter was lodged on the thermal fuse , located below the lint screen on the blower exhaust housing, on our dryer. Remove the front lower panel , 2 screw, and you'll see 2 fuses. I suspect that our control board is burnt.
Aug 05, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Duet GEW9200LQ0 Dryer
can oyu oppen the door nad physically push in on the door switch( little grey switch atop the door opening). do you hear it clicking on/off??? if not you have a bad door switch.
Mar 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Open Questions:
Dryers Logo
78 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
