Question about Alpine Type-R SWR-1242D Car Subwoofer
Type r subs
I have had my type r's hoodked up for months. Just acouple days ago when I am listen to my music they will hit but then just stop and **** up into the box and the cuts off then it starts working again. I have tried rewiring them. then I unhooked one while it was playing and the one that was hooked up would hit then stop and push out. I have no idea what is wrong.
Your amp mine be going in to protection mode
Posted on Oct 24, 2008
Kicker 12L5 blew from a kicker zx750.1
MY BEST GUESS FROM WHAT YOU HAVE SAID IS THAT THE BOX WAS TO SMALL. BUT YOU ARE OVERPOWERING THE SUB RUNNING IT AT 2 OHMS ON A 750 WATT AMP WITH A SUB THAT IS ONLY RATED FOR 600. NO MATTER HOW FAR YOU TURN YOUR SETTINGS DOWN, YOUR STILL PUSHING TO MUCH POWER FOR THE SUB TO HANDLE. IT IS ONLY RATED 600 WATTS FOR A REASON. ESPECIALLY IF YOU LISTEN TO MUSIC THAT HAS A REAL LOW END AND THEN A HARD HIT. REMEMBER A HARD HIT WILL SPIKE YOUR AMPS OUTPUT THEREFORE PUSHING MORE WATTAGE TO THE SUB.
Nov 19, 2013 | Kicker Car Audio & Video
I turn my player on and hit folder to open up my songs and nothing is coming up it just goes back to folder it was working a few hours ago i finished listening to a song then it stopped working i thin
You'll need to check that the files in the folder are MP3 or WMA (Windows Media files). Unfortunately, no other file types are supported so you will need to avoid iTunes and use Windows Media Player or similar to manage your library and the Eclipse.
Oct 21, 2012 | Eclipse CLD2 MP3 Player
WHAT SIZE AND TYPE BOX DO I USE FOR ONE PIONEER TS-W304C SUBWOOFER
You have a lot of choices for this. First, unless you are tuning the sub to a specific frequency you have options. You didn't specify the size of sub so it's difficult to say specifically, but if it's a 12 inch sub, you need about 1.5 to 2 cubic feet. Of course the performance of the sub depends on the music you listen to. If you listen to rock, pop, classical, or country, I recommend a sealed box. A sealed box gives you better control over your sub. The air acts as a cusion and decreases the return time of the cone to rest position. This gives you tighter bass. If you listen to rap or hip hop, I recommend a ported enclosure. This type of enclosure allows for more cone excursion, thus allowing the sub to recreate lower frequencies. Hope this helps.
Aug 12, 2011 | Pioneer TS-W304C Car Subwoofer
Two 10" Rockford Fosgate P1 subwoofers stopped making sound
Sounds like you've blown them.
When you were playing back to the friend, were you playing louder than usual?
Was the old box ported, and the new one sealed? The lack of ventilation may have caused the blow...
Jan 12, 2010 | JBL GT150 Car Subwoofer
I have a older poulan chainsaw it ran good acouple months ago. i tried to start it today it would not hit.changed plug still nothing
Remove all fuel and discard. Use fresh fuel. Clean the air filter or replace.
Make sure you keep the chain tensioned properly and wear good chaps.
Aug 29, 2009 | Garden
I had my subs installed a month ago and a few days ago the subs are working,everythings connected but not working and my subs aren't blown out because i don't have my music that loud so whats the problem?
what model kenwood speakers do you have? what head unit do you have? do you know how they hooked up the rca cables to the back of the deck? if this deck has got 3 pre outs you may have lost the sub pre-out. are you amp lights coming on? if you are still having problems you can take a 9v drill battery or bigger and touch the wires from the speaker to the battery, make sure positive to positive and neg. to neg. the speakers should pop if they are ok, that should re-assure you on the speakers. let me know and ill help where i can. good luck
Feb 27, 2009 | Kenwood Car Audio & Video
I purchased an acer aspire 5920 notebook a few months back my wife said that the sound just stopped working a few days ago. I have checked through the control panel device manager and both are functioning...
Can you hear sound through the headphone port? If so then it's possible the speaker wire came loose on the inside. If not, then it's most likely a motherboard problem and you should contact ACER for warranty service.
Jul 03, 2008 | Computers & Internet
Sub-Zero 532 (About 18 years old)
First do the simple things like cleaning the condensor coils and turning the defrost timer a few times, also check the evaporator motor or just listen to the fan by opening the freezer door. Also check the light switch, make sure it turns the light off every time you close the door.
Jun 26, 2008 | Sub-Zero 632 / S
My amp turns on then the music cuts in and out
check your main ground, if possible try to read voltage across making sure 12-14v present with load and some signal.
Aug 08, 2007 | Verge VGA285 Car Audio Amplifier
No bass at higher volume
Your battery should be fine! Although the amp might not be strong enough for the sub. All you can do is check the RCA cables from your radio to your amp as these might vibrate loose when you get to 17 volume and also check the monster cable from your amp to your sub asit might have vibrated loose as well.
Oct 21, 2006 | Pioneer GM-5200T Car Audio Amplifier
Alpine Type-R SWR-1242D Car Subwoofer Logo
62 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
