Fedders A7DH65B2A Dehumidifier
Problem for Fedders A7DH65B2A Dehumidifier
Dehumidifier leakage
By Guest on Jan 18, 2006
My dehumidifier leaks whater. Any suggestions?
Same Problem
Jun 10, 2008
-   My problem is when I put the water bucket back in the machine. Sometime It will not seat properly. What am I doing wrong?-   Shreckie
Best Solution
posted on Oct 26, 2007
Helpful)
Gogodesu
Rank: Apprentice
Rating: 85%, 1 votes
My dehumidifier leaked after about one year of perfect operation. I unscrewed the face plate exposing the cooling grill and found out that debris was blocking the drainage hole that fed into the water bucket. The debris came from zip ties used to bunch some wires together. Apparently they got brittle (from the constant cooling and warming?), fell apart and managed to make it's way to the drainage hole. Cleared it out and worked fine again.
You rated this solution as "Helpful".
Solution #2
posted on Jan 18, 2006
Somewhat Helpful)
nagev
Rank: Wiz
Rating: 78%, 2426 votes
Dehumidifier Leaks Water
If water drips or pools at the base of your dehumidifier:
1) Disconnect the power.
2) Check the pan or reservoir and empty it if necessary, or make sure the drain isn't clogged.
3) Straighten any kinks or bends in the unit's hose.
4) If it still leaks, check and/or replace the overflow switch. Then, if necessary, call an appliance repairperson or take the unit into an appliance repair shop.
You rated this solution as "Somewhat Helpful".
Popular Solutions for Fedders A7DH65B2A Dehumidifier
Questions and Unsolved Problems for Fedders A7DH65B2A Dehumidifier
Do you recommend Fedders A7DH65B2A Dehumidifier?
Answer
Answer
My Fedders Dehumidifier A7DH45B2A*A-R 45Quart, works great but it leaks from the bottom of the unit!... (More)
Answer
The dehumidifier powers up and the fan runs, but no moisture is taken out of the air as the... (More)
Answer
fan runs but no water is removed from the air. The room humidity display changes (lowers), but no... (More)
Answer
I have a Fedders A7DH65B2A dehumidifier and it has worked fine for a couple of years. In the last... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fedders A7DH65B2A Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
