A dehumidifier will often frost up if room temperatures are colder than about 65 degrees F. If your room temperature isn't this cold, airflow to the unit may be restricted or blocked entirely.
1) Be sure the unit is set far enough from the wall so that airflow isn't restricted.
2) Clean the evaporator coils. To do this, unplug the dehumidifier and take off the outer cover. Allow excess moisture to evaporate from the coils. Then, using a brush attachment on a vacuum cleaner, remove all dust buildup. If necessary, cover the motor and electrical parts with plastic sheeting and spray with water.
After ice on the coils and outside top of unit was thawed we cleaned the unit and waited 2 days then put the unit back together. After plugging the unit in and turning it on, "ON' came up in the humidity setting window,but when we activated the up or down buttons on the humidity contol the % numbers did not appear in the window-- only "ON" remained. We ran the unit for a while and again the outside top front of the unit felt very cold and we were concerned that it might freeze-up once more so we turned the unit off. We would appreciate any suggestions.
Also, another problem that could cause the unit to frost up is that it might be low on freon.
If you've ever had an air-conditioner frosting problem, then you'll understand. Freon is a strange element! I won't go into a lengthy explanation here, but if there is too much freon in your unit, it will not cool optimally, & if there is too little, it'll cool too well, causing frosting on the coils & the condenser.
A dehumidifier is basically an air-conditioner, as it has freon in it. By lowering the temperature of the unit's coils, it causes excess moisture in the air (humidity) to condense on the cools, where it can be channeled into a recepticle & removed.
Unfortunately, the cost of having the freon checked & (if necessary) replenished, would be too high to justify in a 'cheap' unit, such as a window air-conditioner or dehumidifier.
So, if none of the above 'fixes' works, then your unit is probably low on freon (has a slow leak) & your best bet would be to replace it!
Solution #4
posted on Oct 25, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Replace the auto defrost thermostat
Solution #5
posted on Aug 13, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Clean the filter. My unit had the same symptoms and my filter was completely obstructed. It slips out and you can wash it and than let it dry.
My Fedders Dehumidifier A7DH45B2A*A-R 45Quart, works great but it leaks from the bottom of the unit!...
(More)
My Fedders Dehumidifier A7DH45B2A*A-R 45Quart, works great but it leaks from the bottom of the unit! I've checked for cracks in the bucket but its fine and collects water too but the unit still leaks:( Everything else is fine with the unit but this. What is going on here? It worked without any leaks for a couple of years and now this! And how do I fix this problem?
The dehumidifier powers up and the fan runs, but no moisture is taken out of the air as the...
(More)
The dehumidifier powers up and the fan runs, but no moisture is taken out of the air as the reservoir well stays dry.
fan runs but no water is removed from the air. The room humidity display changes (lowers), but no...
(More)
fan runs but no water is removed from the air. The room humidity display changes (lowers), but no water is accumulating in the tank. I took the back off and no ice is accumulating
I have a Fedders A7DH65B2A dehumidifier and it has worked fine for a couple of years. In the last...
(More)
I have a Fedders A7DH65B2A dehumidifier and it has worked fine for a couple of years. In the last month it shut off and now won't power up. When plugged in, the control panel will not even light up. Seems totally dead. Do you have any adice? Is there a fuse on the unit? Please advise.
