Question about Motorola Talkabout T5420 (14 Channels) 2-Way Radio
Ring tone thingy
Do not want the little chirp to sound when I key the mike. Cannot seem to get it off one radio has it off and the other I cannot figure out. Please help. Thaks
  • Motorola Master
  • 1,654 Answers
Setting and Transmitting Call Tones
Your radio can transmit different call tones to other radios in your group so you can alert them that you want to talk.
To set a call tone:
1. With the radio on, press MENU 3 times. The current call tone setting flashes and displays.
2. Press + or - to change and hear the call tone.
3. Press MENU or PTT to set the new call tone or turn feature off.
Posted on Sep 07, 2008
Chirp doesn't list Abask radios. There are other similar appearing Chinese radios. Do you know which chirp-listed radios will work?
CHIRP is a FREE cross-platform, cross-radio programming tool. It works on Windows and Linux (and MacOSX with a little work). It supports a growing list of radios across several manufacturers and allows transferring of memory contents between them.
Jan 24, 2017 | Cars & Trucks
2003 Saturn ion. Auto started cherping when radio is on, why?
does the chirping sound seem to come from the engine compartment? if so, turning on the radio may put a larger strain on the alternator. if your belt is old or the tensioner is going bad that extra strain could be enough to make the belt chirp.
May 21, 2014 | Cars & Trucks
Roadpro rpswr
What was the radio that you keyed?
Apr 28, 2013 | RoadPro RPSWR-3C Swr Meter - 10w-100w -...
I have a 1996 3.8 liter camaro. I was driving my car down the road when the gages started jumping and i found out that problem it was the battery and aldernater well after i changed them problems i have...
Hmmm, a puzzle.
The only way to disarm these alarms is with
the factory remote or turning on the ignition.
To turn off the factory alarm.
Ok, do you have the remotes?
If so, let's ID the system.
Go to & use th fcc #s
on the back of it.
If not try this:
Programming Factory Security on GM Cars and Trucks
Instructions for programming the GM factory security systems that do NOT
disarm from the driver's door key cylinder. This programming is for the
cars and trucks listed below.
96+ Camaro
96+ Firebird
99+ GM Trucks
99+ GM Sport Utility Vehicles
Step #1 Turn the ignition on then off.
Step #2 Remove the radio fuse only (not the fuse that says acc/radio).
Step #3 Turn the key to the accessory position. When you do this you
will get two chirps from the door buzzer. Should you hear only
one chirp, your vehicle does not have factory security and these
instructions do not apply. You need to hear two chirps.
Step #4 Press the unlock switch on the door. This will give 1-4 chirps
depending on the program step. Continue pressing the unlock
switch until you get to the desired chirp setting.
1 Chirp - Security off
2 Chirps - Remote Only
3 Chirps - Factory Setting
4 Chirps - Passive Arming
Step #5 Turn the ignition off.
Step #6 Put radio fuse back in.
Jul 03, 2011 | 1996 Chevrolet Camaro
Hi my mag257 when i key the mike .the tx light up but no aduio sign on lcd .leave radio on for 5 minutes key mike again .all working .your roger
Hi sounds like bad caps in your radio.. also if your running a power mike, check the battery.
i suggest you post your problem on the radiomods forum, where there are loads of radio technicians browsing the forums.
Sep 01, 2010 | Magnum 257 CB Radio
Midland 5001 40 channel cb radio all is fine with the radio except I question one thing there is a chirp that occurs just before the key down it chirps first then keys up and talks fine. Is this something...
Hi Tom
Ya know I have that same radio with the same chirp. I have asked many to tell me if they hear the chirp on the air and no one has heard it but me. I know what it is but i wont fix it due to the fact it is the only radio that does that to me and i think its kinda cute for it to do it. Now to let you in on the secret is that for the radio to go from rx to tx is handled by transistors plus the computer has to give final say so to tx. So the chirp is developed by the switching and computer turn around times to allow you to talk. I hope this helps.
Jun 13, 2010 | Midland 5001 40-Channels Base CB Radio
3300 240-Channels Base CB Radio: intermitant when key mike /works for a bit then st...
sounds like you have a bad soilder joint on the board. If it quits and you hit the case and it starts again is a sure way to find out.
May 07, 2010 | Connex 3300 240-Channels Base CB Radio
Chirping noise from Freezer and Refrig
Simple fix. Unplug refrigerator, locate fan, wipe clean from collected dirt etc. and spray a little WD-40 on the shaft. Spin the fan. Plug in and voila, chirp is gone.
Permanent fix, replace motor.
Nov 21, 2008 | Refrigerators
Cobra 29GTL Won't Transmit
if the red ant light comes on this means that you have antenna trouble either in the antenna itself or the coax but this should not have anything to do with the radio not transmitting. it sounds to me that you have a bad audio chip or a bad power output transistor. in either case you should really take it to a cb shop and let the professionals solve your problem, good luck!!
Aug 16, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Motorola Talkabout T5420 (14 Channels) 2-Way Radio Logo
192 people viewed this question
Top Motorola Radio Communications Experts
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
