FixYa.com
Tags:
Fedders A7DH65B2A Dehumidifier
Dehumidifier Doesn't Deumidify Well (by 2 users)
posted by Guest on Jan 18, 2006
It's just not dehumdifying properly and I'm at a loss.
1 Other User Has The Same Problem
Comment by kennedyclan, posted on Dec 10, 2007
green light does not come indicating dehumidifier working...coils were cleaned, filter washed. very small amount of liquid in catch basin. Used to fill up in 2 days...not even close to filling up in a week.
Best Solution
posted on Jan 18, 2006
Helpful (85)
nagev
Rank:Wiz Wiz
Rating: 76%, 2346 votes
If a dehumidifier seems incompetent, it may be undersized for the space. Check the unit's specifications to be sure it can handle the room size. If you don?t want to replace it with a larger one, try closing doors and dehumidifying your space a section at a time.
You can also:
1) Disconnect the power cord.
2) Remove the cover and clean the condenser and evaporator coils, as discussed above.
3) Lubricate the fan motor bearings with a couple of drops of oil if the motor has oil ports (some units don't need to be oiled). While you?re at it, make sure that the condenser isn?t clogged with dust or dirt.
4) If it still operates poorly, call an appliance repairperson for advice or take the unit into an appliance repair shop.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 22, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
How do I get the cover off?
This Problem Also Relates To: GE General Electric AHK65LK Dehumidifier GE AHG50LB / AHG50LD Dehumidifier DeLonghi DE500P Dehumidifier DeLonghi DE400P Dehumidifier Dehumidifier DeLonghi DM40ULSRB Dehumidifier DeLonghi AR15552 Dehumidifier DeLonghi DE400 Dehumidifier Dehumidifier
Can you Help with these Dehumidifiers problems?
Dehumidifiers
Hampton Bay Dehumidifier Power...
I have a Hampton Bay... Answer This...
maytag dehumidifier
does not collect water Answer This...
Ge Dehumidifier E1 error
My new 65 pint Ge dehumidifier... Answer This...
old ge dehumidifier
I have an old dehumidifier,... Answer This...
fedder 65 pint dehumidifier...
I can't get this unit to work.... Answer This...
Repair Service
Find Dehumidifier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
