I am trying to set up a laptop to work via router, I alredy have this laptop connected, but it asks for my network or WEP key I think, which I don't know how to find
  • 1 more comment
  • feething Sep 07, 2008
    Thanks, I appreciate the help but turns out I can't do any of it right now, when I click on anything using touch pad, it's not doing anything, can't close or open anything. Think I just ned to give laptop up as bad job. So I can't find out if your solution works as cannot click on anything
    Actually, it has been on a network before. It worked without any problem on my Linksy's router, only since changing router to netgear is it not connecting
    Sorry, me again, when I right click on LAN then properties, it does not come up TC/IP, as you said or DCP or Static IP, there is box that comes up saying Connect using Intell (R) PRO 1000 MT Network Connection
    Sergeant:
    Champion:
  • 310 Answers
First of all, need to know what OS you are using, since it will make difference as to how you connect. If running WXP or W2K, then after you plug in the computer to the network, you will need to do the following:
1. Since it has not been on a network before, you wiill need to logon as a local administrator
2. Right-mopuse click on My Network places ans select PROPERTIES.
3. Right-mouse click on the LOCAL AREA CONNECTION icon ans select PROPERTIES. Select the TCP/IP option, then select PROPERTIES. Use either the DHCP option or the Static IP option depending on what your network is using (check with your network administrator). Use the ADVANCED tab to configure any DNS or WINS options. Close back to the Local Area Connection Ico area.
4. Make sure that nothing is highlighted, then slect the Network Identification Option (this is also avaialble under the Advanced Tab in the pull-down menues). Follow the steps to add the system to the network. You will need to have permissions to be able to add a copmuter onto the domain. If you don't have those permissions, then you will need to have someone with those permissions add the system for you.
Posted on Sep 07, 2008
I cannot connect to my home wireless network provided by my new ISP, after I ended my subscription to my old ISP. Connection via old ISP was via Dial Up; connection via new ISP is via broadband. I have a...
First of all you may try to check the adapter settings on your computer.
Start>control panel>network and sharing center>adapter settings>check status of broadband(should be connected)
If not right click on broadband connetio and click on connect if still showing as disconnected
You may also check internet option settings.
open IE>tools]nternet options?>connection tab>tick on never dial a connection.
Click on LAN settings tick on automatically detect settings>ok
You may also check for the if the driver for your wireless broadand is working by checking it on device manager.
Try to check if broadband is working on the other computer.
Apr 15, 2011 | Dell Inspiron 630M Notebook
The wifi on my nintendo ds lite doesn't work even though i changed the settings to WEP ..i dont know if the wep key i type in on my DS is wrong because when i type in the wep key shown on the netgear...
Welcome to Fixya
First you need to check is if the WEP key that you are entering is the WEP key of your router. Try to connect a laptop to your computer which do not belong to the network. Say, your friends laptop. This laptop will ask for a security key if it's the first time to connect to the network. Enter your security key and see if the laptop can connect to the network. If it did not connect then the problem is your WEP key.
Have a good one!
Mar 28, 2011 | Computers & Internet
I cannot find my WEP key on Router N with Belkin.
You changed the network key.
Make sure that you will connect your computer to the router with the cable to change the wireless settings of the router.
Do not change the wireless settings of the router using the wireless computer.
open the set up page of the router and check the wireless settings.
Change the name of the wireless network also.
create a new network and try to connect to the new wireless network.]
I think you did not change the name of the network and your computer might be trying to connect to the same old network name with the old settings.
Click here for more information about router and networking.
May 02, 2010 | Belkin F5D9231-4 Router
My laptop is asking for the security key in order to connect to the wireless network. I am sitting right in front of the router, but I do not know which numbers/letters it is wanting
The SBG 1000 only supports wired equivalent protection (WEP) encryption. Did you set up the router yourself or your ISP. If the ISP set it up they will have the WEP key, if you set it up and don't remember, you can either log into your router and find the WEP key, or reset it to the factory defaults via the reset button on the back of the router
Jun 18, 2009 | Arris SBG1000 Wireless Cable Modem Gateway...
Failure to connect to wireless network
The WEP key is printed in the bottom side of the router. It is needed only the first time you connect to a router, and the PC "remembers" the settings (i you choose to). Seems like you (or someone) changed the WEP key or you didn't choose to connect automatically before.
Jun 04, 2009 | ASUS Eee 4G Notebook
WEP key fro netgear DG834G v3 WIRELESS ROUTER/MODEM
Okay, first you will need to access your router (usually 192.168.0.1 or something like that) you will be asked for a user name and password. (admin password respectively if you never set these up previously)
From there you would click on Wireless Settings and scroll down to WEP Key. Whatever is typed in Key 1 is your WEP key. Write that down. Plug in those numbers for your printer and you should be go to go.
Mar 21, 2009 | NetGear DG834G 802.11G Wireless ADSL...
I just got a laptop, and i am trying to connect it to tthe router, it's says i need a wep/wap key. where can i find that key?
The wep key has to be created on the router so if you didn't set it up then you need to ask the person who did what it is. Assuming that it is your router and you lost or forgot the key then you can get into the router with a computer that is hardwired to the router. So you plug your laptop into the router and open up internet explorer. In the address bar you need to put in the router's address (Ex: linksys is 192.168.1.1) this will pull up the router menu default login is admin and password admin or root. (if these have been changed then you can push in the reset button on the back but this will wipe out everything and you'll have to set it up again,not preferable.) If you have another router then you can get online on another computer and look these default codes up for your router. If these work then you are in the menu and you can go to security section and create a new wep (or take it off completely again not preferable) make sure to save the changes you have made before getting out of the menu and write down the wep you created or save it in a word doc. Now you can unhook your laptop and try to connect wirelessly when it asks for a wep put in the key you created,reenter it and hit connect and you should be good to go.
Jan 16, 2009 | Computers & Internet
Cannot get wireless connection through router
Hi MistiShay,
You did mention that it was working fine for several weeks suddenly your wireless computers stopped functioning and your getting a message that the security key in incorrect. This only means that its either your entering the wrong encryption key or someone changed the previous security key to something else. By the way what type of wireless security did you configured on the router initially was it WEP or WPA, if its WEP(64 or 128 bit) and your using a bulit-in wireless adapter on your laptop you need the default WEP key because the passphrase only works with a Netgear WLAN Utility.
Know if your having difficulties accessing the setup page of the router you may need to check on your browser settings, turn off the pop up blocker and firewall temporarily, also try another computer. Now if all fails you may need to press that reset button on your router and set it up again.
I
Jul 28, 2008 | NetGear RangeMax WPN824 Wireless Router...
Cant Aquire IP Address Wirelessly
try this... connect the laptop directly to the router using a cable. get into the router interface and disable the wep security. Once it is disabled try connecting the laptop. your computer will ask you that network is not secured and ask if you want to connect anyway. just connect your laptop without the WEP key, if it connects, just go ahead and enable the security again. hope this helps.
Feb 09, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Connecting Ipod touch 8(GB) to Wi-fi
After fighting with this for the last couple of hours I have my ipod touch working with the netgear DG834G(v3) router. The fix is a bit odd and I am not entirely sure why it works but I thought I would share and hopefully it might help you out …
First I think that the WEP encryption simply does not work between these two devices and causes some very strange behaviour – the WEP 'authentication type' setting I had on the 'wireless settings' page was set to 'shared key' – I flicked this to 'automatic' & strength to ‘128 bit’ - hit apply and finally I found I was able to connect without an error message (after inputting the correct WEP key). Unfortunately the DHCP did not work correctly after this and I kept receiving IP addresses in the range of 169.254.x.x (an internal default) rather than my networks expected 192.168.0.x range. The Ipod touch couldn’t find any DNS servers or connect to the internet.
To get round this I set the router ‘security options’ to use WPA instead (WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)) instead of WEP. Set the new WPA password at the bottom of the wireless settings page - again hit apply - and configured the ipod to use the new password and WPA PSK instead of WEP. This worked fine – although it does mean I have to change the settings on all my other wireless devices around the house!
The weird thing is that although the router isn’t using WEP encryption changing the 'authentication type' setting back to ‘shared key’ in the WEP menu breaks the WPA connection again – very odd? I blame netgear and their obviously crazy wep code :)
Nov 04, 2007 | NetGear DG834G Router
Computers & Internet Logo
David Payne
David Payne
