Question about Adcraft 811E Sandwich Maker
Repair adcraft panini grill model sg-811E
The top grill do not stand up by itself; it has to be hold by hand
  • tate_kevin Mar 05, 2009
    The Adcraft panini grill has a spring loaded hold bar with two set screws on each end. I need the part # or get a parts manual for this unit to order the part. Can anyone give me that information?
    Thanks,
    Kevin
There is a brass block with 2 allen bolts on the hinge bar. Tighten those screws.
Posted on Apr 02, 2013
2 Suggested Answers
SOURCE: Adcraft panini grill top will not stay open.
i have the same trouble... i finally undid the screw that holds the cover, but not sure whether the spring is sprung or the clamp is loose..
What did you do, Kevin?
Posted on Nov 09, 2010
I need a manual for a Delonghi cgh800 panini grill
De'Longhi has the instruction manual for the CGH800 Panini Grill on the product support page. Click on the Support tab from the product page: http://www.delonghi.com/en-us/products/kitchen/kitchen-appliances/indoor-grills/cgh800-0179415002 . Look on the right hand side of the page. The direct link to the manual is http://www.delonghi.com/Global/InstructionManuals/EN/CGH800%20ENGLISH.pdf .
I hope this helps.
Jul 21, 2015 | DeLonghi Kitchen Appliances - Others
Manual for Breville BGR200XL Variable Temperature Panini Grill
Hello Kevin, I have a link to the manual online. It can be downloaded in pdf format or you may view online. Here is your link.
http://www.breville.ca/media/mediaappearance/4528/BGR200XL_IB_B13_FA_LowRes.pdf
May 15, 2015 | Breville BGR200XL Variable Temperature...
BREVILLE PANINI LOCKED AND I CANNOT OPEN IT...HELP
there is a small sliding lock on it I used to have his model, I think its on the side but look closely you should see the clip holding it closed.
Nov 26, 2012 | Breville BGR820XL Stainless Steel Smart...
Have a Breville Ikon Panini Press ... doesn't work
First point of call would be to check the microtemp, which is the small heat regulating fuse inside. If that has blown, you most likely will have no power.
Otherwise call you local Breville Service Centre. If you're in Australia you'll find them at http://www.breville.com.au/care_agentsearch.asp
NOTE: In Australia, this model has a Two year product guarantee. Check your receipt as it may be under warranty!
May 19, 2010 | Breville 800 Class 800GR Indoor Grill
The top piece is not heating up
If you feel confident opening the appliance (while disconnected from the mains of course!)
1. Check the internal cable between the bottom part of the unit and the top part. If this is damaged or tests to be open circuit, it will require replacing.
2. If the cable is OK, check the continuity on the heating element in the top half of the machine. If it is open circuit, then the element will require replacing.
Mar 25, 2010 | Adcraft 811E Sandwich Maker
Need replacement parts. Two bolts that secures the top plate to the rotation bar both broke (snapped) and I cannot remove the remains. Need new bar and bolts.
You will have to use a screw extractor to remove the broken off pieces that are still in the grill. You have to drill a hole into the remaining bolts and then tap or screw in the screw extractor. Turn counterclockwise and they will come out. Home Depot may have the allen head screws that hold down the bar.
Sep 04, 2009 | Adcraft SG-813
Do you have a instruction manual for Adcraft SG-811 Sandwich Maker?
Hello there:
if you go to the manufactures web site for this appliance you should be able to download a copy of the manual . There may be a number that you will be able to call also for further assistance ok?
best regards mike
Jul 31, 2009 | Adcraft SG-811 Sandwich Maker
Mar 05, 2009 | Adcraft 811E Sandwich Maker
Top Plates Do Not Stay Up As They Should
Follow Up From Postee: Determined that by simply removing the back cover (phillips Head Screw) that there is a brass clamp over the pivoting bar that has an alan head screw on either side. Simply tighten both sides and the lid will stay up. Done.
Feb 11, 2009 | Adcraft SG-813
Instruction Booklet Breville SG820XL Panini Press
I forgot how to reassemble the panini press coil /heater
Jun 04, 2008 | Breville 800GRXL
Adcraft 811E Sandwich Maker Logo
809 people viewed this question
Top Adcraft Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Adcraft Kitchen Appliances - Other Expert? Answer questions, earn points and help others
