Back to:
Tags:
Honeywell HCM530 Humidifier
Humidifier leaks (by 2 users)
posted by Guest on Jan 18, 2006
My humidifier leaks whater. How do I stop that from happening?
1 Other User Has The Same Problem
Comment by aeea, posted on Dec 31, 2007
I am missing something. I have 3 hard pieces and 1filter. When I unpluged the cord the leaking started. Then I removed the filter and not than, but later that day all of the water leaked out. If you can, I need some directions please. When I leave home and have unpluged the cord what do I do next to keep the water in the tank.Vicks V3500
Best Solution
posted on Mar 01, 2007
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have a similar problem. Water is running down the feed tube into the right side of the humidifier housing and onto the floor. I am ordering a new feed tube and plastic frame for the element. Hope this works.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Humidifier leaks:
I don't want to Accept this solution
Solution #2
posted on Jan 18, 2006
Thanks for Trying (70)
nagev
Rank:Wiz Wiz
Rating: 77%, 2384 votes
If water drips or pools at the base of your humidifier:
1) Disconnect the power.
2) Check the pan or reservoir and empty it if necessary.
3) Be sure the wick, hose, or other water-delivery system isn't kinked or fouled.
Thank You!
Solution #3
posted on Feb 19, 2008
Not Rated (0)
skhoov
Rating: 0%, 0 votes
He had a similar problem, the humidifier was leaking. We figured it was from being on an unlevel surface. When we moved it to another location that we thought might be closer to level, the problem was resolved.
Thank You!
Solution #4
posted on Feb 05, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
Set it out with the trash — ours did the same thing right out of the box; it's not a drip but a stream!  PS, there's nothing to kink.  And, of course, if you empty the reservoir, there will be no leak, for there's no water in the thing!
Thank You!
Solution #5
posted on Feb 03, 2008
Not Rated (0)
isabel diaz
Rating: 0%, 0 votes
MY BROTHER BOUGH ME VICK COOL MIST HUMIDIFIER, CUZ I SAW HIM, WATER LEAKAG!! DANG!! FILTER WICK WET.... MAYBE I TRY CHANGE VICKS ULTRASONIC HUMIDIFIER HAS NO FILTER SOON....
Thank You!
Solution #6
posted on Jun 15, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
Not valid for a V5100. There are no hoses.
Thank You!
Solution #7
posted on Jun 03, 2007
Not Rated (0)
noely
Rating: 85%, 1 votes
Usually they leak at the top of the tank where the handle is! Check for cracks and even fill and place in stopperd sink unside down overnight to see if it's losing water. If it is, replace the tank- they run about 25.00 for the 2.5 gallon size! I just went throught this!
Thank You!
Solution #8
Not Rated (0)
wils123451
Rating: 0%, 0 votes
I had the same problem, the humidfier was out of plumb.I ended up slightly bending the top of the duct.
Thank You!
Solution #9
posted on Feb 12, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
Replace the gasket
Thank You!
Can you Help with these Humidifiers problems?
Humidifiers
how to reset bionaire bem4655 filter gauge
Humidifiers
I have this old humidifier & it needs a new filter.
Humidifiers
I lost the instruction manual. How do I get statrted...
Humidifiers
Good Afternoon I have a Kenmore Dehumidifier it worked...
Humidifiers
My holmes cool mist tower humidifier would not stay on for...
Loading problems.
Repair Service
Find Humidifier Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
