Honeywell HCM530 Humidifier
Problem for Honeywell HCM530 Humidifier
Noisy humidifier
By Guest on Jan 18, 2006
My humidifier makes a great amount of noise. is it fixable?
Solution #1
posted on Jan 18, 2006
Somewhat Helpful)
nagev
Rank: Wiz
Rating: 78%, 2426 votes
A noisy humidifier may be the result of an unlubricated fan motor or a drive mechanism clogged by debris. Periodically clean the water reservoir, fan, and nozzle to ensure that they are clean and working properly. To keep your humidifier working smoothly and efficiently, lubricate the fan motor bearings with SAE #20 oil. Be sure to consult your owner?s manual for proper care and maintenance procedures.
If it seems loose, vibrating parts are causing the noise:
1) Disconnect the power.
2) Remove the cover and look for any vibrating parts. Tighten screws, if necessary.
3) Wiggle the fan to see if it is loose on its shaft. If it is, tighten the mounting fasteners. Lubricate the motor's bearings if suggested in your owner's manual.
4) If it still makes noise, call an appliance repairperson or take the unit into an appliance repair shop.
You rated this solution as "Somewhat Helpful".
Solution #2
posted on Nov 07, 2007
Not Rated)
dave98052
Rank: Apprentice
Rating: 0%, 0 votes
My unit is about 6 months old. One night we heard this terrible metallic vibration from the furnace unit. I tried several times to locate it but it would stop by the time I got down in the basement to find it. Finally I happened to be down there when it happened. It was the humidifier water inlet valve. When it kicked on it was vibrating against the duct making the noise. I disconnected it and I am looking for parts now..... Just another possibility.
Was this helpful?
Yes
No
Popular Solutions for Honeywell HCM530 Humidifier
Questions and Unsolved Problems for Honeywell HCM530 Humidifier
Do you recommend Honeywell HCM530 Humidifier?
Answer
Answer
valve makes a loud clicking noise and activates over and over again
Answer
Have it plugged in, have it turned on, all the way, have prescribed water in it, won't turn on,... (More)
Answer
my model 600 aprilaire humidifier will draw water even when the fan on the furnace is not blowing.... (More)
Answer
I have a Skuttle Drum Humidifier, Model 190, that operates by a humidistat. There is noise coming... (More)
Answer
I have replaced filter and cleaned base of my HM3607 humidifier and it is still showing wash filter.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Honeywell HCM530 Humidifier:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
