Question about Honeywell HCM530 Humidifier
Doesn't run My son's humidifier doesn't humidify well. What do I do?
My humidifier does not move off wash filter
Posted on Jan 31, 2009
    Novelist:
  • 74 Answers
If a humidifier doesn't do a good job or runs constantly, it may be undersized for the space or humidified air may be escaping from the room. 1) Check the unit's specifications to be sure it can handle the room size. 2) Be sure your home's doors and windows are closed; also check the fireplace damper. 3) Be sure the reservoir has plenty of water. 4) Be sure air movement to and from walls or curtains are not blocking the unit. 5) Disconnect the power cord. 6) Clean the unit according to the manufacturer's recommendations. 7) Lubricate the fan motor bearings with a couple of drops of light oil if the motor has oil holes (some units are oil-less). 8) If it still operates poorly, call an appliance repairperson or take the unit into an appliance repair shop.
Posted on Jan 18, 2006
    Novelist:
  • 74 Answers
When a humidifier doesn't run, it generally means it isn't receiving electrical power or the controls have automatically shut it off. 1) Be sure it's plugged in to an outlet that works and that it's turned on. Check the electrical receptacle for power, using a working lamp, appliance, or voltage tester. 2) If the receptacle seems to be dead, check the circuit breaker or fuse that serves the humidifier's circuit. 3) Check the setting on the humidistat. If it's set lower than the room's relative humidity, the humidifier won't go on; in fact, it may take several hours for the humdistat to respond to the room's changing humidity. 4) Be sure the humidifier's reservoir is full of water. 5) Unplug the humidifier unit. 6) Check the power cord. If necessary, repair the cord. 7) Remove the humidifier's cover panel. 8) Remove the humidistat and check it (as shown below). Replace it if necessary. 9) If it still doesn't work, call an appliance repairperson, take the unit into an appliance repair shop, or replace the unit. To check the humidistat, you?ll need a volt-ohm meter. A humidifier?s fan vaporizes the water in the reservoir and blows the water vapor into the house or room. If you need to check the fan, unplug the humidifier, remove the control panel, and lift the lid. Tighten the fan hub with pliers if it is loose; this should take care of rattles. If the fan doesn?t spin easily when you try to move the blades by hand or if it is still noisy, lubricate the motor bearings with oil. To establish whether power is reaching the humidistat when you know there are no problems with the plug or switches, unplug the humidifier, remove the control panel, and lift the lid. Test it with a volt-ohm meter set to the RX1 scale (or to K[omega symbol] or [omega symbol] resistance on a digital meter). Clip the meter to the humidistat terminals. The meter should jump if you turn the humidistat from high to low. If it doesn?t, you?ll need to replace the humidistat or return it to the manufacturer.
4 Suggested Answers
  • 74 Answers
SOURCE: Humidifier Gives Off an Odor
Odors are common because water stagnates in the tank. 1) Unplug the unit. 2) Empty the reservoir, mop up any damp areas, and clean the tank and evaporator belt with a mixture of one gallon water. Add 2 tablespoons of chlorine bleach to the water for stubborn smells.
machtcl1
  • 61 Answers
SOURCE: cleaning a furnace humidifier steel filter?
Most water panels are generally replaced once a year on flow through humidifiers.
Posted on Jan 02, 2009
SOURCE: Honeywell Natural Warm Moisture Humidifier Is On But No Steam?
I have the same problem and I have 2 of them fairly new. I can't seem to find out what the problem is either.
Stumped?????????
Posted on Dec 16, 2010
My sunbeam humidifier doesn't work
Do you mean Dehumidifier? A machine that takes the humidity out of the air. If this is what you mean and you hear the fan motor working with no water dripping then the problem is that the coil which holds freon gas has leaked out the gas and can be recharged again with the leak fixed of course. Depending how old the unit is you may be better off buying a new model. Repairs can be costly. Hope this helps!
Mar 26, 2012 | Humidifiers
Doesn't turn on
Hello, check to see if you have 24 volts to the solenoid valve when the blower motor is on, if you do the solenoid valve is bad if not chevk to see where the voltage stops. Also, since tnis is a fan powered humidifier, the relay that energizes the fan could be bad aswell.
Nov 26, 2011 | Aprilaire 700 Humidifier
Humidifier is full of water but the light shows it's empty. Since the humidifier thinks there isn't any water it won't run.
More than likely, the float valve in the top of the water collection bucket is broken or stuck in the DOWN position. Turn the unit OFF & unplug it. Remove the bucket for it's holder and empty any water that's in it. Inspect the float valve to see if it moves freely. Jiggle the arm of the float valve to see if it moves up and down freely. If it doesn't then it's stuck or broken. Hopefully, it's only stuck, because in most cases, purchasing a replacement bucket with the float valve installed is your only option.
Hope this helps you solve the problem. Thanks for choosing FixYa.
Sep 17, 2011 | Essick Air Humidifiers
Can I use distilled water in my Sunbeam ultrasonic sul496?
You most definitely can. In fact it's better than using tap water. As it doesn't have all the minerals and chemicals that tap water has, that cause scaling.
Sep 09, 2011 | Sunbeam Ultrasonic Humidifier
We have a kenmore humidifier on the furance model # 48945. it doesn't stop running so our water bill is twice what it should be. I've tried to find a manuel on line so i can figure out how to...
Noodles, it sounds like the float valve inside the water reservoir is stuck in the down position. Turn the water line ON/OFF valve to the humidifier OFF. Open the top of the reservoir and you will see the float valve. Gently, lift it up, to see if it will remain at the top of the water level, which left in the reservoir. It it doesn't, then the float needs to be replaced. In the mean time, leave the water line ON/OFF Valve OFF.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 07, 2011 | Kenmore Humidifiers
Need a manual for Danby PHD DHCC6020...how do I get the dehumidifier to work??
Are you sure you have a Danby Humidifier and not a Dehumidifier? As Danby doesn't make humidifiers. At least, not in the US and Canada.
Please advise. Thanks
Apr 28, 2011 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Hello! I have a 33201 Hunter Humidifier and for some reason does not run. It turns on (light comes on) and I can hear a faint hum if I put my ear to the unit... but again it does not come on. It does...
Hi, Mark! It may be clogged with a calcium scale build up from the tap water you use. Unplug the unit and empty any water that is the tank.Mix a 50/50 solution of White Distilled Vinegar and Bottled Distilled Water. Mix enough to fill the tank. Let it soak for 2 to 3 hours and turn the unit ON. If it starts functioning as it should, allow it to run until the tank is 3/4's empty. If it doesn't operate as it should, allow it to soak overnight. And try again, following the procedure above. After it has run to the 3/4 empty point, turn the unit OFF. unplug it and dump the remaining solution. Refill the tank with Bottled Distilled Water and run again, for at least 2 hours. This with flush the system of the vinegar and water solution.
To avoid having this problem again, always use Bottled Distilled Water, rather than tap water.
Hope this helps to solve the problem. Have a Happy Easter!
Apr 22, 2011 | Hunter 33201 Humidifier
Do I add salt with the water when using this cool mist humidifier
Hello
Ive been down this road before,sorry your son is sick.
Take a teaspoon of salt and add it to a full tank,it will break up the corrosion on the heating elements,a teasspoon of baking soda will help also.
This will not hurt anyone if it blows into the air with the steam.
May 12, 2010 | Vicks Healthmist 4100 Humidifier
Loud clicking and banging, A700 doesn`t work
You have a faulty humidistat
Greg Sunsetmech
Dec 13, 2009 | Aprilaire 700 Humidifier
Honeywell HCM530 Humidifier Logo
619 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
Bill Long
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
