Question about Baby Gear
Avalon 3 wheel stroller
Model A29 RMS, front wheel fallen, bearing broken,
The bearing to my Front swivel wheel broke on my My A29 RMS Jogging Stroller broke, it is a very easy fix if you know what part your looking for. I was able to find the part number off of the good bearing and found it here on Amazon for under $5. Hope this Helps http://www.amazon.com/gp/product/B00634W44W/ref=as_li_ss_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B00634W44W&linkCode=as2&tag=intemarkexpei-20
Posted on Sep 26, 2013
    President:
  • 2,712 Answers
You can actually get this repaired for very cheap at your local bicycle repair shop. Should you wish to contact the company, their toll-free number is 1-888-742-9899
Please take a moment to "Accept" this response if you found it satisfactory..
Cheers!
IrishDruid
Posted on Sep 08, 2008
    Brigadier General:
  • 5,158 Answers
Click on contact us and they should be able to help you find a wheel
http://www.zooper.com/index.html
Robert
Please rate this solution
P&t front wheel sticks
Dear Jo B,
Have you made sure that none of the fixing bolts or bearings that hold the wheels in place are stuck or seized? If they are not, then you might need to adjust any of the retaining springs that also fix the wheels to the rest of the stroller assembly (if these springs are indeed fitted).
Any bearing grease, or even car axle/ CV joint grease will do fine.
Some of these strollers also have a clip that you push down with your foot and it locks the wheels in certain positions. Check that this clip is not broken or misfitting, also check the brake bar too.
Hope this helps and do let me know how you get on.
Yours sincerely
Ouszen
Feb 07, 2012 | Phil & Teds Baby Gear
GRACO STROLLER FRONT WHEEL BROKEN
you can get the wheel here
http://www.amazon.com/Graco-Quattro-Deluxe-Stroller-Renaissance/dp/B000CEXO0C
Jun 18, 2008 | Hauck Infinity Umbrella Stroller
The front wheel shaking if i go faster than a very slow walking speed. Apparently it needs to be locked in order for it not to shake. And i found a small ball from the bearing i think.
The lock for the front wheel is a little plastic clip that should be just above the wheel itself if you push that down it should stop it from shaking
Hope this helps
Mar 02, 2011 | Baby Jogger City Elite Stroller
My Phil & Teds Vibe shakes in the front wheel uncontrollably. Do I need a new front wheel?
Hi!
Assuming your tyres have the correct pressure, uncontrollable shaking in 3-wheeld swiveling strollers is usually caused by bearing slack.
Please check the front wheel bearing. It should allow the wheel to rotate freely but it should not be loose on the axle. (ie. It should not slide sideways on the axle.)
In this case you would need a new front fork/wheel assembly.
Please let a dealer have a look at it. As the Vibe has not been around for very long, you may still have warranty.
I hope this helps.
Erwin de Raad
www.babycare.nl
Oct 13, 2010 | phil & teds Vibe Stroller
Need front wheel bearing
From the same place where you bought the stroller. Or, any good pram and stroller shop would do.
Sep 23, 2009 | Bertini Bidwell 905 Horizon Standard...
Remove Rear Wheel on Phil and Teds Stroller (Dash)
There is a little push button on the metal bar that runs the length of the stroller.  good luck, my bearings have gone bad on my phil and teds and they told me that I had to replace the entire wheel at 40 dollars a pop.
May 01, 2009 | Regal Lager Phil & Teds Vibe Jogger
Our Valco Runabout pram (about 3 years old and a 3 wheeler)does not steer properly. The front wheel does not pivot when trying o turn
I have just removed the front wheel and liberally greased the inside top to bottom with specific aluminium lubricant (which the bike shop told me was good for bearings) and immediate improvement. fingers crossed that it lasts. looking at other posts, make sure that you put the front wheel back on securely.
Aug 18, 2008 | Valco Runabout Single DLX - Ebony Check...
NEED NEW WHEELS
I have the same problem, one of the bearings are broken on the front wheel and one on the back.
I managed to remove one of the good bearings to go and get replacements, but I can seem to get the outer bearing on the back wheel (the one thats broken) away so to fit replacements.
If I can get if off I will let you know.
There are some wheels on ebay but don't think they will fit the Mac 3, still looking
Aug 03, 2008 | Maclaren Mac 3 - Silver Jogger Stroller
I have the same problem, the airline broke ours the last time we flew. I just found on Graco's website that you can order replacement parts. Here is the link, http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
You'll need the model number and serial number. I found ours on a sticker under the footrest. For our stroller it's $19 plus shipping for the front wheel assembly.
Hope this helps.
Jan 13, 2008 | Baby Gear
Baby Gear Logo
572 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
