Question about AEG T57800 Electric Dryer
Dryer smells of natural gas
Our driyer smells of natural gas. What can be done to stop this?
    Novelist:
  • 74 Answers
Of course, this applies to gas dryers only. If you smell natural gas near your gas dryer, do not light matches or a lighter and don't operate electrical switches or anything that might spark, igniting an explosion. Immediately shut off the gas valve that serves the dryer. If the smell is mild, ventilate the area, wait until the air is clear, and re-light your pilot light. If the smell is strong, move everyone outside, leaving the doors open to ventilate the house. Turn off the gas supply valve --located by the gas meter on the gas inlet pipe-- by rotating the valve one quarter turn with an adjustable wrench. The valve's oblong stem should be perpendicular (at a right angle) to the inlet pipe to stop the flow of gas. Call your gas supplier (or the fire department) from a neighbor's phone or a cellular phone outside the house.
Posted on Jan 18, 2006
    Novelist:
  • 74 Answers
Problems with a clothes dryer normally involve the heat source or the motor that tumbles the clothes: clothes don't dry because it doesn't get hot enough or the drum doesn't rotate.
Vehicle smells like natural gas after stopping when vehicle is hot
I think you are getting a rotten egg smell,not natural gas. I would check for exhaust leaks from the catalytic converter for starters. Have you checked the grill at the base of the windshield and on top of the firewall? folks have been known to drop eggs down there as a prank.
Dec 04, 2013 | 2010 Lincoln MKX
GAS Odor? Gas dryer smells of gas after it runs a cycle, just replace ignition gas valve assembly, still has gas smell?
Did you also replace the coils on the valve assembly?
Which parts did you replace exactly?
Nov 07, 2012 | Dryers
Our Maytag Neptune gas dryer is exhausting a natural gas odor now... This smell only occurs when it has been running for awhile and never when it's turned off. Also, it ONLY smells outside the house via...
The burner is not lighting right...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool Gas Dryer (ggq9800pw1) - No Heat
You have a leak somewhere in your gas system, Either from the gas valve or some other tubing. In this situation unless you understand how it works I would recommend getting a tech out to look at your system. That way you know that it is being done properly.
Jan 02, 2010 | Whirlpool GGQ9800L Gas Dryer
Convert propane hook up for dryer back to gas
the oriface size for propane and natural gas is the same it only has to be changed if you will be useing butane it should hook up and work the same but the propane will have a stronger sulfer smell than natural gas always connsult you gas provider if you are concerned they usualy will send tech to inspect if youhave questions for your safety
Nov 17, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Dryer has gas smell inside.
i would not play with this problem , the lines and the seals in the dryer must be checked .. by a proffesional ... hope u dont get a spark , get this checked imediatley
Sep 26, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Whirlpool mod # WGD5300SQ0 gas dryer gets hot but does not stay hot Is it a thermostat or radiant sensor or something else
by all means when dealing with natural gas consult only trained professionals....as natural gas does not have an odor..the odor that you smell is an actually additive that has been place for just this reason.
May 03, 2009 | Whirlpool GGQ8831L Gas Dryer
Natural gas smell
then checkout the tubing that goes to the burners and pilot flame tubing too,
Jan 11, 2009 | GE DBVH512GFWW Dryer
Maytag dryer smell of gas inside and venting
hi thanks for the question you don't have a problem if you smell the air going out of the house it will have that smell thanks the appliance doc
Sep 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
AEG T57800 Electric Dryer Logo
1,457 people viewed this question
Top AEG Dryers Experts
John Tripp
John Tripp
DROPNDEAL
DROPNDEAL
Are you an AEG Dryer Expert? Answer questions, earn points and help others
