Question about Philips Magnavox 51MP392H Rear Projection Television
COLOR TUBE I WANT TO KNOW HOW MUCH COLOR TUBE COST.
  • Philips Master
  • 8,617 Answers
You can get replacement tubes for your model at the following link for about half the price they normally go for, If you dont know which ones your model uses just leave them a email with the model number and what color tube you need they respond quickly.
http://servicemanuals.vstore.ca/
Posted on Sep 07, 2008
I'm having issues with color? Every blue is now green. Can't adjust the tint. Any fixes?
You didn't say what the model number of the TV was, so I'll guess it has tubes for each color Red, Blue and Green. The blue tube is probably weak. If you really want to spend the money on replacing the tubes (costly) you may be able to buy a similar sized flat screen TV for less than the cost of the repairs.
Feb 18, 2016 | Televison & Video
CAN,YOU REPLACE PICTURE TUBE IN A G3222 TV
NO, WE CAN'T. Fixya is a Q/A forum, we, members, all we can help other members is answering questions
You can try to find the part doing a google search using terms
PARTS, BRAND of your CRT TV, PICTURE TUBE
View these videos how a CRT tube is replaced:
Replacing CRTs And Repairing RCA CTC28 Color Television
Checking...
SimHelp Advice on CRT Tube Replacement
http://www.repairfaq.org/samnew/tvfaq/tvptrep.htm
http://www.barco.com/tde/%280251960790820610%29/TDE13/00/Barco_TechnicalManual_TDE13_00__Retro-Data-808S-picture-tube-replacement.pdf
Now, just a guess: presuming you will find that CRT tube, maybe the job of buying and replacig the CRT tube of your TV might cost you more then a new flat panel TV? I don't know..
Sep 12, 2015 | Televison & Video
Sont Projection Tv colors
Your red tube is weak or defective. If weak, gain can be adjusted up on the red tube.(cheapest cost) If red tube circuit is defective that will have to be fixed by a technician.(cost between $100 to $200) If tube is worn out, it will have to be replaced(250 to 500). Any work should be done by a qualified tech. Prices will vary depending on your area.
If set is over 5 years old, I recommend replacement.
Mar 13, 2014 | Televison & Video
My samsung hl61a750a1fxza only has blue and green picture only, why?
Your red tube is dead. There are three primary color tubes that create all the colors. A new tube can cost $250 plus installation and then you will have an old, obsolete TV with one new tube. A new 46 inch TV is less than $400 these days.
May 06, 2012 | Televison & Video
1) I have a Sony KV-32FS13 that has a green tint in the picture. Does any oneknow how to access the service menu for this model? I tried other adjustments and I can't get rid of the annoying green...
Code 5 is "AKB error". AKB, or auto kine bias, is a cicuit that monitors the three color guns of the picture tube (red, green and blue) and tries to adjust them for proper color balance. If it can't, the picture is blanked (usually) and the timer/standby light blinks 5 times. When the color drives aren't balanced, you see a color tint in the picture like you're describing.
There might be a problem in the AKB circuit, or the picture tube may just be old enough that the AKB circuit has run out of adjustment range. If the tube is at fault, you should consider replacing the set. A new tube will cost nearly as much as a new 32-inch LCD TV, and you'll need to pay someone to install it and set it up. There are special tools required to perform the convergence which gets the color guns aligned with the face of the tube so they hit the right colors.
If you'd like to try tinkering with the service menu adjustments, this site explains how to access the menu and gives a list of settings.
Jan 02, 2011 | Sony KV-32FS13 TV
How much would it cost to replace a color tube in a RCA HDTV 32 inches?
The cost of replaceing a tube in a d52w23 is unfortanly high..sorry.. if you can find one the last time i replaced a tube cost about 250 for the tube and labor is extensive it takes a exp tech about 2 hours to replace. Are you sure that the tube is at fault? which tube is it. is this set 32 inches? the d52w23 is 52 inches
Nov 03, 2010 | RCA D52W23 52" HDTV CRT TV
Image is harp in center and lburred on both sides.
Readjust ur tube back to the original position.Ur convergence is dead,Must know to solders?Replaced the 2 convergence ICS and all it resistors.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 06, 2010 | Televison & Video
Red Color is not showing up.
THIS TV HAS KNOWN PROBLEMS WITH PICTURE TUBE FAILURES AND I WILL PREDICT THAT AT SOME TIME IN THE FUTURE EVEN IF YOU GET IT REPAIRED NOW, ONE OF THE REMAINING TUBES WILL START GIVING YOU PROBLEMS. YOU HAVE THREE TUBES IN THIS UNIT (RED,GREEN & BLUE) AND THE RED TUBE IS DEFECTIVE. SORRY FOR THE NEWS BUT JUST TRYING TO SAVE YOU THE ULTIMATE COST FOR REPAIRS, FOR A PICTURE TUBE REPLACEMENT AND SUBSEQUENT SET UP IS A MAJOR & COSTLY REPAIR.
HOPE THIS HELPS
Jul 07, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
No red colour in my lg lcd monitor ..red colour setting doesnt bring any change i screeen..pls suggest some solution
it is very simple, by default in monitor circuit RGB (Red, Green, Blue) tube is installed. and in combination of both of three colors we are able to view colorful image. due to non functionalty of Red color u r not able to view red color in screen, either you replace picture tube or purchase new monitor. coz cost of this tube is equal to monitor.
Jun 05, 2009 | LG Flatron F700P 17" CRT Monitor
Green color out
loss of green color indications of failure of green crt. or green crt board. replaceing the tube ussaly cost 250 for part. however tube replacement in these set are very labor intensive. involveing removing and complex setup issues. at our shop it around 500 to replace one tube. rhese set ussaly not cost effective to repair unless under warrenty
Mar 24, 2009 | RCA D52W19 52" Rear Projection Television
Philips Magnavox 51MP392H Rear Projection Television Logo
78 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
