Question about Toshiba RD-XS35 DVD Recorder/HDD Recorder
Remote control code
I accidentally changed the IR code in the operational settings to DR2. Now the remote control will not work. I tried pushing the setup button but DR2 shows up on the screen of the DVD recorder and I can't get access to the setup menu. Any suggestions about how to get to the setup menu so I can change it bace to DR1?
  • Emil B Sep 07, 2008
    The suggestion was to check the owner's manual to reconfigure the DVR. But, I can't find anything in the owner's manual about this. This problem is in relation to a Toshiba RD-XS35 HDD/DVD video recorder.
    Someone suggested holding the stop button down for a while. This did not do anything.
    Genius:
  • 2,035 Answers
The remote control for your DVR has the capability to control 2 additional DVRs in addition to the one that you currently have. In order for the remote control to work with your DVR, you will need to make certain both of them are talking on the same frequency. If you press the remote control and the front of your unit says DR2, that means that you need to have your remote on DR2 as well so that it can operate the DVR. To set your remote to DR2, you will need to make sure the unit is off then you will need to press and hold down the SETUP button and while you are holding this button down, press the number 2 button. Your remote is now set to DR2.
Good luck...
Posted on Sep 07, 2008
  • Hugh Terry May 24, 2012
    Brilliant! Thanks - I had the same problem. I don't know why they design them that way - at least, not without proper instructions! Cheers. Hugh
    Champion:
    Scholar:
  • 209 Answers
Press the setup button until the light blinks twice and then enter the code associated with your material.
    Genius:
  • 1,011 Answers
Dear Sir/madam,
The most important remote code, of course, that could be gleaned from all this is the discrete off (play could be used for discrete on):
- Discrete off: 900A 006D 0000 0001 45B5 936C
- Edit... Discrete on? 900A 006D 0000 0001 45B5 FE01
But I also found some interesting maintenance codes in the Cxxx range. Trying this though, I'd recommend being very careful and avoiding e.g. the code ending with xx3A. That starts some kind of update process apparently saying don't shut down. It accepts no remote commands (it shows the remote code pressed on player's screen though, which is interesting), no powerdown but is fortunately exitable by pressing Eject on the player - or at least was for me, I'm not trying that one again... Whew. Some other codes also produce error messages on video or on player screen.
These codes I found to do something interesting:
- Player display test, all the items in the player display light up and animate: 900A 006D 0000 0001 45B5 C738
- Disc tray lock (for all you folks with kids) on and off: 900A 006D 0000 0001 45B5 C639
- Time and date on players screen (sorry, only for a moment): 900A 006D 0000 0001 45B5 CB34
- Factory reset (you loose all your settings): 900A 006D 0000 0001 45B5 CD32
Try to Factory Reset with your remote
For more details click this link.....
http://www.avsforum.com/avs-vb/showthread.php?t=940909
thanks
good luck
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): remote control code - clip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
    Scholar:
  • 152 Answers
Holding the STOP button for some time may solve your problem.
  • Patrick Regoniel
    Patrick Regoniel Sep 09, 2008
    Try borrowing a universal remote controller and see if your menu is accessible.
  • 1,183 Answers
Refer to the owners manual, and reconfigure the device. The following is the link for the onwers manual.
http://www.tacp.toshiba.com/tacpassets-images/models/RD-XS35/docs/RD-XS35_om_e.pdf
Thanks
proton
  • 689 Answers
Hi
First of all try soft reset, both HDD recorder and remote control, Unplug the HDD recorder and keep unplugged about 2-3 minutes. Take the batteries of remote control out and put it back 30 seconds later (Make sure batteries are OK)
Directv remote and LG remote will not control tv, just receiver
Let's start simple first. Your TV is not responding to either remote control, but specifically if your factory original LG remote does not operate the LG TV, then the problem could be with the IR receiver in the TV itself.
Ensure nothing is blocking the IR receiver on the TV. Move anything out of the way.
Test both remotes to ensure that they are sending an infrared IR signal to the TV. Use a digital camera (such as the one on your phone) and point the remote into the camera lense and press the power/volume/channel buttons. You should see a faint flashing light in your camera viewfinder. This indicates that the remote is sending IR signal. If you don't see anything, then there is no signal. Try FRESH batteries.
If your remotes are working, and since this is an LG, look at the back of the TV by the video inputs. Look for a port called "REMOTE CONTROL IN" or similar. It looks like a 3.5mm headphone jack. This port is used for external remote control and may be dirty.
UNPLUG the TV, then use a regular 3.5mm male headphone jack to plug in and out several times. You basically want to push all the way in and all the way out several times to dislodge any dust and remove any oxidation that has built up in the port. 10-15 times should do fine.
Then plug in the TV and try your remote.
Best of luck.
Nov 05, 2017 | LG 32LG30 32 in. LCD HDTV
My 1.5 IR Dish remote has all of a sudden stopped working with our Sanyo tv. I've changed the batteries. When I push the power button it will only light up the VCR button if anything at all. Our other...
sandyannsamp
If the VCR button lights up when you press the Power button, you are not in the correct mode to operate the TV. If the remote is programmed correctly, when you are in SAT mode, you can press the large RED button to turn your receiver off/on. The RED TV button will turn your TV off/on. I have provided links to program your remote to your TV again. I have also provided codes for your Sanyo TV.
Instructions to program your remote to your TV (begin with step 6):
http://www.dishnetwork.com/SupportSection/remote-setup
Here are the TV codes: 590, 683, 589, 542, 652
I hope this helps.
Ray Calo
DISH Network
Nov 18, 2010 | DISH Network IR Remote Control
I have a Nexxtech IT009 remote and a HTS Dish Network converter box. What is the remote's codes and how do I program them?
http://www.tivocommunity.com/tivo-vb/showthread.php?s=&threadid=128743
Above are all the codes for the HTS box,one of these should work with your remote.
Nexxtech codes below.
www.jascoproducts.com/support/download.../RemoteCode-4-digit.doc
Try using the code search to programme your device.
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the P (Program) button until the red indicator stays on. Release the P button.
3. Press and release the desired mode button (TV,VCR, etc.). The red indicator blinks, then stayslit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device to be controlled changes channels. If you accidentally overshoot the desired code, press the Channel Down button to backtrack through the library until the device changes channels. Pressing Channel Up changes the direction to forward again.
5. Press and release the Enter button to set the code.
If you still need a code list email, support@orbyxelectronics.com or call 1-866-363-3059.
Aug 13, 2010 | DISH Network IR Remote Control
Tv will not respond to remote, changed batteries, still doesn't
Check for a TV service company or store near you with service available. Ask if they can check your remote for operation since there is an inexpensive device that will reveal if any IR is being emitted although it is too simple to determine whether the codes it emits are the right ones. If the remote checks out bad, you can get an original from the mfr. or from:
Remotes
I suspect however, the problem is at the other end of the IR path, in the receiver of your set.
Try using any controls you find (other than Power) that are available on the set itself. Those controls share some of the same circuitry used by the remote so if they work, the remote may be sick. If the set-top controls don't work, the problem is within the set.
The internal receiver for IR is often mounted on a separate small board and attached to the main board with cables and in some sets, this could be replaced by the user with some care.
Mar 13, 2010 | Vizio GV42L 42 in. LCD Television
Need remote code for DVD player
From my searches I don't think you will find it. Try going to http://www.sony.ca/view/cic_contact.htm and asking them directly for it. I can't see them saying no.
Sep 11, 2009 | Sony SLV-D360P DVD Player/VCR
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Need Tivo IR code for Magnavox ZV450MW8 DVD/VCR
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device..
Mar 10, 2017 | Televison & Video
Harmony One remote won't input channels very well
Most DirecTV receivers are able to be controlled with IR (infrared) or RF (Radio Frequency) signals. DirecTV receivers are usually set to be controlled by RF.
To control a DirecTV PVR / Satellite, it needs to be set to respond to an IR Remote:
1. On the original DirecTV remote press the Menu button
2. From the Menu press Select on Settings
3. Select Remote from the left menu
4. Press Select on the IR/RF Setup button
5. Use the Up or Down arrows to change from RF to IR
6. Press Select to save
Note: Some models of DirecTV may have different steps to enable IR. You may need to refer to your user manual
Harmony Remotes only control IR signals. so this is not the issue. The Harmony Remote should control the tv. the original remotr needs to be tested for IR or RF.
The device we are working on that is not being controlled by the Harmony Remote could be operating on RF (Radio Frequency) signals. Harmony Remote can only control the devices that operate on IR (Infrared) signals. Most devices that work on RF signals can be changed to operate on IR signals, and this usually could be done by changing the remote control command mode to IR from RF.
Please follow the steps listed below to test to see if the device is being operated on RF or IR signal:
1- We need to use the original remote for that device to complete this task
2- Using your hand or a thick and wide object (wall, pillow, book...), cover the top part of the original remote. In other words block the direct positioning between the original remote and the device.
3- After you cover the top part of the original remote (or used an alternate way to block the direct communication of the original remote and the device), try pressing the buttons on the original remote to see if it can still send commands that can be received by the original remote. You can try powering on/off your device using the original remote when the original remote is being blocked by your hand or another object.
4- If you still can control the device using the original remote without a point of sight, your device is being operated on RF signals. If you cannot control the device without a point of sight, then it is IR operated.
5- If the device is RF operated, please change the command receiving mode to IR rather than RF and test the Harmony Remote.
6- If the device is IR operated, please contact us again by replying to this email and let us know if none of the commands or some certain commands are not working for that device.
You can usually find the information on how to switch the device to be operated on IR signals rather than RF signals, through the user manual for your device, or by contacting technical support of the manufacturer for that device, or even sometimes reaching the information simply by doing a basic research over the internet.
Mar 31, 2009 | Logitech Harmony One LCD Touchscreen...
Need Dish DVR ViP722 remote code.
If you are looking to have the Dish remote operate your TV, just do a random search for your tv. First, hold down the tv button on the dish remote until all the rest of the light up. Next press the tvpower button on the dish remote. Next, press the channel up button (this is the up arrow button) until the set turns off. When it does turn off, press the # key at the bottom right of the remote. The tv button will light and flash twice. That's it. Your done. Hope this helps.
Feb 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Remote control problems
Answering my own question,Switch on recorder manually then hold down SETUP KEY and No 2 key at the same time.As this is a common fault with this recorder would advise taking note of this solution.
Oct 21, 2006 | Toshiba RD-XS34 DVD Player/HDD Recorder
Toshiba RD-XS35 DVD Recorder/HDD Recorder Logo
613 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
