Question about AEG T57800 Electric Dryer
Dryer tumbles but doesn't heat
My dryer tumbles but doesn't heat. Can it be fixed?
  • 1 more comment
  • Anonymous Mar 13, 2014
    Samsung dryer won't heat and tumble
  • Anonymous Mar 19, 2014
    Please recommend some checks and diagrams of the machine on how to fix a non heating dryer.
    Thanks much!
  • Anonymous Mar 26, 2014
    There is heat, just will not tumble
    Novelist:
  • 74 Answers
When this happens, something has interrupted the heat source. Run the dryer for a couple of minutes to see if it gets hot. Be sure you don't have the dial or controls on a non-heat setting, such as "Fluff" or "Wrinkle Control." On an electric dryer, this may mean that the circuit breaker or fuse that controls the power has blown --check and replace or reset. Be aware that a dryer may have two breakers or fuses: the motor will run when one works, but the heating element requires both. On a gas dryer, recheck the control's setting to be sure it's not on a heat-free setting. Check the gas valve behind the dryer to be sure the gas supply is turned on. Also make sure the house's main gas valve is turned on. On an older dryer, make sure the pilot light is burning. If it isn't, re-light it. You can find directions HERE or in your owner's manual (pilot light instructions are often mounted next to the pilot light on the burner, too). Note: Most modern dryers have electronic ignition instead of a pilot light. If yours has electronic ignition and isn't heating, call a qualified repair person.
Posted on Jan 18, 2006
Looked simple but hazed. I found a solution from wiring diagram came with a machine. I decided an easiest and simplest one that was a themal fuse located on exhaust duck. It costed me a $15 for a fuse and my labor. That was it.
Posted on Jun 17, 2008
    Scholar:
  • 161 Answers
There is an element in back of your dryer and it may be out. You can check it out with an ohm meter to see if the circuit that goes thru it is not broken. And you can check to see if there is electricity going to it with an ac voltage checker when switched on. Also there is a sensor that tells the dryer when to kick on and kick off to keep your unit from becoming to hot and catching on fire that can also go out and it can be tested with an ohm meter or a voltage tester. You may have to have supervision as you can be subjected to electrical shock when testing electrical items not knowing how.
Posted on Sep 06, 2007
The next step is checking the themostats.
Posted on Apr 05, 2007
  • 744 Answers
SOURCE: dryer heats but won't tumble
Assuming, the timer is ok and that you can hear the the dryer motor running, it sounds like a broken belt. These kind of failures generally occur suddenly - one day it works, the next day it doesn't.
Posted on May 03, 2009
  • 121 Answers
SOURCE: dryer heats but does'nt tumble/spins, roper model
you will need to change your belt. to access the unit you will need to remove the 2 philips screw by the lint screen. use a screw driver and place it in front and pry it up. do the same thing on both the right and left side. you will then be able to see if the belt is there or not. you will need to remove the 2 5//16th screws on the inside of dryer. the front panel comes off and you will hva access to the belt. the part # for the belt 341241.
Posted on Oct 20, 2009
SOURCE: how can i fix my indesit is70c tumble dryer?
open the back panel , not the the full back just the smaller panel located near the bottom half.
the termo will be screwed onto this panel . unscrew and you will see two circles near the top one will have a small pin hole in it . stick a pin in till you hear a click replace and should work fine
Posted on Jul 28, 2010
heatman101
  • 43501 Answers
SOURCE: I HAVE A AEG LAVATHERM 500 R TUMBLE DRYER 25 YRS
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 21, 2010
heatman101
  • 43501 Answers
SOURCE: new element fitted still only top hafe of element heating
heatman101
yuyu
Posted on Sep 30, 2010
Hi. My tdvcw bush tumble dryer turns but won't heat up. There's no reset button. Also the temperature light is flashing
What To Do If Your Tumble Dryer Is Not Heating Up - YouTube
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
If your tumble dryer isn't heating up, it's likely that the heater may .... helllo, i have a bosch dryer it works ...
Dryer problems: How to fix a dryer that's not heating up ...
? 3:03
https://www.youtube.com/watch?v=aFXbYp--K5g
Jun 4, 2010 - Uploaded by eSpares
For all your tumble dryer spare parts go to http://bit.ly/1LJTuT6 In this video, Rory shows us how to change the ...
Jan 25, 2016 | Dryers
Tip
Tumble dryer not heating how to fix heater, thermostats, Ntc sensor.
We have all these tutorial guides that will help you with your Whirlpool 6th sense
How to clear error codes
How to service a pump unit on condenser tumble dryer.
How to replace belt, motor or bearings.
Tumble Dryer Not Turning, How To Replace Capacitor
We have all repairs guides on these Whirlpool 6th sense Tumble Dryers
http://www.how-to-repair.com/help/tag/6th-sense/
on Jan 21, 2015 | Whirlpool Dryers
My dryer is 4 years and the heater wont heat up but the tumbler tumbles
First check your dryer vent, make sure that it is venting properly. If that doesn't work then it is your dryer heating elements.
Apr 27, 2011 | Frigidaire Dryers
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
May 25, 2009 | Dryers
Tumble dryer
If you here motor running, you have a broken belt. Give brand and model and I can help you change it.
Nov 21, 2007 | Dryers
AEG T57800 Electric Dryer Logo
1,371 people viewed this question
Top AEG Dryers Experts
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Sal De
Are you an AEG Dryer Expert? Answer questions, earn points and help others
