Question about HP Photosmart C4180 All-In-One InkJet Printer
Paper Jam When I start up the printer it makes loud noises and the error message reads paper jam and press ok but as far as I know there is no paper left in the printer
  • 1 more comment
  • Anonymous Sep 22, 2008
    Get the same message but there doesn't seem to be any paper stuck in there.
  • Anonymous Oct 27, 2008
    I have checked everywhere for the paper jam I do have the clean printer options but the printer won't allow me to as wants me to clear paper jam first help!!!!
  • Anonymous Dec 10, 2008
    yeah!!! same with mine it won't let me do anything and keeps saying that there is a jam when there is no paper in the printer from what i can see. Help!!!
  • 97 Answers
My printer have an option to clean printer head.. If you too have the option please try it and see..
Posted on Sep 07, 2008
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Open door cariadge jam
this error generally comes in when there is actually a paper jam or it gives a false paper jam.. so first of all make sure that these should not be any paper stuck inside the printer.. clean all the paper rollers with a little moist lint free cloth.. then plug the printer directly to the wall jack for the power supply if not connected..
if it doesnt resolve the issue.. we may have to perform a reset as well ..
Oct 22, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Error Message - Paper Jam
I had a paper jam. I removed the offending sheet of paper which unfortunately tore into 4 pieces as it came out. Upon piecing the sheet of paper back together - there is a small piece missing. I've checked the printer thoroughly - nothing can be found!
Feb 25, 2009 | HP Officejet Pro L7680 All-In-One Printer
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printerjam
A paper jam error message will appear if the printhead is not correctly installed. Try removing and reinstalling the printhead again, but make sure it snaps into place. Try loading a sheet of plain paper and press at the same time copy+cancel; hold them down until the printer feeds the paper. The paper will go through the rollers and come out blank.
Apr 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Paper Jam error message
try this
alternative :
Apr 02, 2008 | Dell 942 All-In-One InkJet Printer
Try cleaning the rollers, it's the maintenance tab on the printer's properties. Maybe this will help.
Feb 28, 2008 | Canon PIXMA MP130 All-In-One InkJet...
HP Photosmart C4180 All-In-One InkJet Printer Logo
118 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
