Question about AEG T57800 Electric Dryer
My dryer doesn't run
It just doesn't seem to turn on! What can be done?
  • mamaw gee Jun 12, 2008
    My dryer won't start at all. It's not making any noise when i hit the start button. From reading I am assuming it's the thermal fuse Maybe?? where is the thermal fuse located and how do I get to it? Model number DBXR463ED1WW HELP PLEASE
My dryer ran for a few rotations,then made a thump noise then stopped. if i press the start button and hold it the house lights dim a little.
Posted on Aug 15, 2007
Disable the "control locked"
Posted on May 28, 2007
    Novelist:
  • 74 Answers
If the dryer doesn't start or make any noise: 1) Be sure it is plugged in and turned on. If necessary, check the receptacle it's plugged into for power, using a working lamp, appliance, or voltage tester. Be aware that most electric dryers don?t plug into standard 120-volt receptacles?they operate on 240 volts. Make sure the door is closed completely, the timer is advanced to the proper position, and the correct cycle is selected. 2) If the receptacle is dead, check the circuit breaker or fuse that serves that circuit. 3) Unplug the dryer and check the power cord and the terminal block. If necessary, replace the cord. 4) Open the door and check the door switch. Press and release it: it should click each time. If it doesn't, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service. 5) If the dryer still doesn't work, a thermal fuse or other electrical or electronic parts may be faulty. Call a service person.
Posted on Jan 18, 2006
My 1991 Mazda b2600i doesn't seem to be getting
Have a fuel pressure test done on the fuel manifold to check for pump, filter and fuel regulator problems. Run fault codes to check for evap canister solenoid problems
Sep 14, 2013 | Cars & Trucks
Mini cooper 2003
Have a pressure test done on the cooling system. Check for blown head gasket or cracked head
Apr 24, 2013 | Cars & Trucks
Engine is not firing,motor turns over but doesn't seem to be firing
what year make model engine etc.................................
Feb 01, 2013 | 1994 Honda Accord
Car doesn't seem to get fuel
have you checked the fuel filter?It should be located on the frame on the passenger side, if you've already done this then its time for a fuel pump
Jan 01, 2013 | 2001 Ford Escort ZX2
My 93 lexus ls400 keep turning off ever since i had a tuneup done. I notice that the ac condenser fan is not working but i dont run the ac.It doesn't read that it gets hot But it seem if the car g
Be sure you check engine oil level often. The low oil sensor will disable the ignition. If you turn A/C on the cooling fan should run continuous, Check the fan relays. Make sure coolant level is correct at recovery bottle, never open radiator cap. A scald hazard exist, be careful. This car is old and complicated, and is beyond your skill level to repair. Try to inquire here for advice, whenever possible. Don't throw good money at bad money
May 27, 2017 | 1991 Lexus LS 400
2002 Pontiac Grand Prix - I put the key in and turn to start, I hear a click, then it doesn't start - in fact the entire car suddenly goes dead and the key gets stuck in the ignition. I can press the...
The first thing I would do is clean your battery connections very good. you may have to remove the plastic covers off the cable ends to get them cleaned good. Also make sure you get the connection bolts tight.
Sep 04, 2011 | 2002 Pontiac Grand Prix
TURNING ON CAMERA ZOOM LENS DOES NOT COME OUT AND SCREEN SAYS 'TURN OFF THE CAMERA AND TURN ON AGAIN' WHEN THIS HAS BEEN DONE NOTHING CHANGES. COVERS DO NOT COVER LENS COMPLETELY AND ZOOM...
Here are some troubleshooting steps that you can try that may correct the problem. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 04, 2011 | Cameras
Jeep makes a whining sound when I turn left sometimes. Doesn't do it when turning right ever and only seems to do it when driving forward. Only happens at low speeds and doesn't seem to affect...
It MAY,,,,,, be the start of a power steering pump problem.Just maybe.The pumps can moan and groan without leaking,so keep an eye on it.Hope this helps.
May 19, 2011 | 2004 Jeep Grand Cherokee
I have two Behringer Eurolive B415DSP speaker, one of them stopped working out of no where. To my best knowledge, the problem is that it doesn't turn on. I had the Fuse check already and thats not the...
This is alimentation fault of the amplifier inside the box. Dismount the amplifier block and take a look first if there are some burned pieces. If it seems all ok, better bring it to a electronics/ tv service center.
May 18, 2011 | Behringer Eurolive B415dsp 600w 15" PA...
TIMER LIGHT BLINKING AND POWER IS NOT COMING ON CD-SW330
i have the sharp cd-sw330, it has no display and won't turn on but the timer just keeps flashing, i have done the bit it says about pressing the timer button then arrows and memory but that doesn't seem to work help?
Jan 09, 2011 | Sharp CD-SW330 Shelf System
AEG T57800 Electric Dryer Logo
968 people viewed this question
Top AEG Dryers Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Sal De
MightyMikeJr
Are you an AEG Dryer Expert? Answer questions, earn points and help others
