Sanyo Ds19350 television 12 volt relay - Televison & Video
  • music007man Sep 09, 2008
    I did not recieve any information on my problem with Sanyo ds19350 buzzing relay please answer
    Master:
  • 638 Answers
Replace the relay it would not be to costly not more then $20.
Posted on Sep 09, 2008
    President:
  • 1,952 Answers
Relay is an switch..it ll triggered durin fault current..can u explain pro clearly...
  • mohammed marika thambi
    mohammed marika thambi Sep 09, 2008
    wen fault current occur in ur system...the relay gets open and terminate the flow of current in it..
  • 4,234 Answers
The replay is part number 6100095540 and is available for $19.73 from tritronicsinc.com
Dan
Posted on Sep 08, 2008
    Genius:
  • 2,035 Answers
You need a service manual which is useful to get the part number of the components ,and also you will need a service manual to guide you. You can find one here:http://servicemanuals.vstore.ca/
Good luck...
    Brigadier General:
  • 6,966 Answers
This is a known issue with this particular brand/model. I am assuming that you are familiar with electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
The relay is typ[e DH1U 12VDC (RL001). Result is mechanical buzzing sound, no picture and no sound. Often, fault is an open/leaky capacitor 470uF/25V (C022), test and replace.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Sep 16, 2008
    Any updates?
    Sergeant:
    Champion:
  • 310 Answers
Can u explain me clearly..
Then only we can say exactly..
  • 535 Answers
Can u expain whats the problem with your relay or u need to buy a new
30amp auto shutdown fuse blows is it alternater
The ASD relay supplies battery voltage (12+ volts) to the fuel injectors and ignition coil(s). With certain emissions packages it also supplies 12-volts to the oxygen sensor heating elements. The Fuel Pump Relay is a separate relay controlled by the ASD relay input to the PCM. Fuse #12 (10amp) provides 12 volts to the coil side of both the relays and the ignition switch. Fuse #6 (30 amps) supplies 12 volts to the output side of the relay. Fuse #16 (15 amp) from the relay output to the Oxygen Sensors and Fuse #26 (15 amp) relay output to the PCM. Fuse #24 (20 amp) is Fuel pump relay output to fuel pump. Fuse #19 (10 amp) supplies 12 volts direct to the PCM.
look for burned or melted wires in the offending circuit.
sounds like you wiggled a wire while installing new relay.
Mar 06, 2013 | Cars & Trucks
I have a Sanyo ds19350 tv. It sometimes suddenly loses its signal or goes to snow. No sound. If I turn the tv off then turn it back on it will play for a few minutes then goes to snow again.This sometimes...
High voltage failure. Take off the back cover and look for the high voltage transformer. The transformer has high voltage at about 380 volts with low current, but it will give you a shock. Usually, there is a capacitor or two, hopefully, there is only one capacitor. Check the DC voltage across it - should be about 390 to 400 volts. If not, change this high voltage capacitor. Buy one bigger than the current one by three times.
Nov 24, 2017 | Sanyo DS27910 27" TV
Sanyo CLT2054 - power cord has light but when I plug it into the
OK you need a volt meter to check the voltage output of your power pack as two things cause this now enough power out the pack to run your unit or the unit has a short both problems will unlight the light so you need to know if the power supply is working right first as it should say like 120 volts AC in and 12 volts DC 1000 ma out so you will need to mesure this with a volt meter. this is a common problem loading the load of the curcuit as in your TV is mor the the power pack is giving out thus shorting out the power pack of any voltage present, as the little LED light your seeing only takes 5 volts at very ittle current to light and dose not repersent the total voltage output of the power pack itself
May 16, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Missing power cord 12v
go to radio shack get a 12 volt 1500ma power supply with I belive it is a N% plug end but any how 800 ma to 1500 ma should run this and the plug end is standard plug with plus 12 volts on the inner side and negitive on the outer case side look at the back of the TV or the old power supply it sould have info on voltags and amprage, and the plug as to inner voltage and outer voltage on the plug any old time radio shack or electronics shop should be able to help you bring in the flat screen if need be as if you know its 12 volts then It wont mater weather you use a 1000ma 1500ma 12 volt ubnaversale power pack as the tv will only use the current needed so more MA is good the only concrn you have is the right mini barrle plug and the right side of +/- voltage on that mini plug being most use + voltage in the inner most circle and - 12 volts on thje outer
Apr 05, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Screen went black
Check the power supply for 12 volts dc, it must provide at minimum 3 amps of power to trigger the on circuit. If not, replace the adapter... if you need one, please contact me.
Jan 12, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Sanyo DS19350
Sep 08, 2008 | Televison & Video
HUMMING/CHATTERING NOISE ON SANYO TV
Confirmation: Lee2fixit's solution also worked on a Sanyo 19" TV Model DS19580with 'buzzing relay'. Chassis carriessimilar relay (Type DG1U 12VDC II TV-5 8A 250V~ also by DEC) at location RL601and a 25VDC 470uF electrolytic cap at C622. After confirming the relay was sound and finding no obviously faultedcomponents tied to it, replaced the cap. Bingo, normal operation and a quiet relay. Will post a follow-up ONLY if the fix failsbefore the rest of the TV .. it's almost10 years old after all. Thank youLee2fixit and FixIt.com.
Jul 05, 2008 | Televison & Video
Power cord
DON DE PUEDO COMPRAR UN ELIMINADOR DE 24 VOLT
Apr 29, 2008 | Televison & Video
Sanyo dp42746 low volt power problems
The power supply is failing, or there is another circuit area that is pulling too much current, and the supply is going in to protect mode.
This would require proper troubleshooting by an experienced tech. If the problem is very involved, or the tech is not familiar with the set, he will require the service manuals and service information.
Jerry G.
Apr 25, 2008 | Sanyo DP42746 42 in. Plasma Television
12 volts plug in for my TV
Sure. These are called power inverters. Here's a link to one that should work. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=422932&CatId=237 Make sure you look at the wattage rating of the electronics you wish to run on the inverter and make sure you don't exceed that wattage rating on the inverter. You can get larger inverters but they have to be usually hardwired into the battery system of your vehicle.
Jun 23, 2007 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
