Question about Kenmore 72802 Gas Dryer
Kenmore Serios 80 Gas Dryer - Replacing Gas Valve Coils
I knw my problem is the gas valve coils but I do not know how to replace them. Can You Help?
    Novelist:
    Champion:
  • 261 Answers
I haven't done coils in a while, You will need to remove the top and front panel to access the coils. The top should have catches that allow you to grasp the top by the back corners and pull forward slightly releasing the catch for left an right sides, other will have to have the top console removed to reveal 3 hex screw to pull the top off. Once done get a 5/16 and remove two hex screws left and right on the inside edges holding the front on, also unplug the harness to the door switch, by now the machine should be unplugged. the coils have a flange over them held on by some phillip screws. the orifice is preset so dont mess with adjustments, they should pop out and pop in
Posted on Sep 15, 2008
Kenmore Series 80 gas dryer, clothes take 3 hours to dry
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Nov 04, 2009 | Kenmore Dryers
Gas will not stay lit on my Kenmore series 80 dryer..
If the ignitor is working properly (glowing visibly) and the burner will not light, then I would suspect faulty gas valve coils. These electrical coils are right above the gas valves and when energized, these solenoids open the gas valves and permit gas flow to the burner. If faulty the gas valves will not open and the burner cannot light. It is recommended that if any are suspected of being faulty, that both (all) be changed at the same time and they will likely come from the parts supplier as a set. Really sorry for your trouble and I hope this helped. Best wishes.
Oct 01, 2009 | Kenmore 800 7983 Dryer
UNIT IS KENMORE M#417.94072300 UNIT WILL START
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 5303931775.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
The disassembly procedure is covered beginning on page 57 of the manual listed at the link below. Operation and replacement of coils is covered at page 68. Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Reverse process to re-assemble. Good Luck
Click on the link and print out the manual below or refer to it. It should give you all you need to know to disassemble and repair the gas valve coils.
Dryer Service Manual
Sep 14, 2009 | Kenmore 72622 Gas Dryer
Kenmore 80 series gas dryer has not heat
most of these dryers have a little plastic plug on the front, left side. pop that plug out and look inside after turning it on. you should see a red glow. if not, then your ignitor has broken. if you see a glow, then the problem is probably one of the two little coils on the gas valve. these coils will sense if there is something to light the gas [the red glow] and open the valve - if the coils are bad, they won't open the valve
Aug 17, 2009 | Kenmore Dryers
Kenmore 80 series, flame goes off after a few minutes later. igenitor trys to relight but dose not
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim. And please don't forget to give me your rating for my help. Thanks
Jun 26, 2009 | Kenmore 74602 Gas Dryer
Gas dryer will not heat up kenmore 80 series heavy duty 72822
Hello Friend, Your problem is very simple to fix. You're dryer needs a thermal fuse and or gas valve coils, both are very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Now, if this don't solve the problem you will need a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Jun 21, 2009 | Kenmore 72822Gas Dryer
Kenmore 80 series gas dryer w/ no heat
Hello Friend, Your problem is very simple to fix. You're dryer needs a thermal fuse and or gas valve coils, and maybe an igniter all three are very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Now, if this don't solve the problem you will need a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new, if it doesn't then you will need to check the igniter. The igniter is attached to the end of the burner assymbly by one screw and a simple two wire plug. Inspect for breakage, and replace if needed. Happy to help, Tim.
Jun 15, 2009 | Kenmore 72062 Gas Dryer
Kenmore series 80 gas dryer will not heat up
Hi. this dryer has a set of coils that sit on top of the actual gas valve assembly. these coils activate the main and secondary gas valves and if the coil assembly is malfunctioning or, the wires and clips are corroded, the coils will not activate the gas valves to open and close. this malfunction will affect the heating process within this dryer unit.
I recommend inspecting the dryer coil assembly. use a mulitimeter to test for Resistance. you should get a reading of some type of current flow through the wires and, if this is the case, the coils are bad and they will need to be replaced.
This test is actually not needed. the non existing heat is a red flag on its own and, it greatly confirms a major failure within the coil assembly. replacing the coils will fix your dryer.
PLease rate and god bless:)
Apr 20, 2009 | Kenmore Dryers
Kenmore 72802 Gas Dryer Logo
1,097 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
