Hoover 24 in. DT999 Free-Standing Dishwasher
Problem for Hoover 24 in. DT999 Free-Standing Dishwasher
No draining
By Guest on Jan 18, 2006
The dishwasher in my kitchen doesn't seem to drain. Can I fix it myself by any chance?
Best Solution
posted on Jul 15, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I resently moved into a house that has a dishwasher. I've never used one before and found it would not drain.
After over looking the obvious i found a blanking plug where the drain hose connects to the sink.
Moral: DONT take things for granted!
Solution #2
posted on Jan 18, 2006
Helpful)
nagev
Rank: Wiz
Rating: 78%, 2426 votes
Following a cycle, a small pool of clean water inside the tub is typical. Excessive water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up. If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposal, be sure the knockout plug for the dishwasher was removed when the connection was made (see your disposal instructions).
1) Remove the cover from the air gap at the top of the sink (usually a short chrome domed cylinder that sits at the back of the sink) and, using a wire, clean it. Also check the entire length of the drain hose for kinks and blockages, especially at the drain connection to the disposer or drain line.
2) Once the dishwasher is cool, shut off the power to it, and--if your dishwasher is made to allow this-- remove the strainer, located under the bottom spray arm at the base of the cabinet (see illustration). Unscrew the hubcap, lift the spray arm off, and remove any clips that hold the strainer to get it out. Scrub it clean with a brush, then replace it.
3) Determine whether the sink trap or house drain line is clogged.
4) If it still doesn't drain properly, the drain hose may be clogged or the drain valve may need replacement. At this point, it's usually best to call a repairperson. You can check the drain hose for obstructions, but this sometimes involves pulling the dishwasher out from under your counter to access the hose, disconnecting the hose at both ends, and flushing it out with a faucet or garden hose.
You rated this solution as "Helpful".
Solution #3
posted on Jun 19, 2007
Somewhat Helpful)
dolittle
Rank: Apprentice
Rating: 75%, 3 votes
I have had a faulty waste water pump on this d/washer
You rated this solution as "Somewhat Helpful".
Solution #4
posted on Feb 10, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Possibly the drain solenoid?? When the cycle changes and its time for the water to drain out is it supposed to stay down throughout the process?? Mine clicks down and immediatly back up!
Solution #5
posted on Feb 24, 2007
Not Rated)
pinkmama
Rank: Apprentice
Rating: 0%, 0 votes
You have been a great help, but when we pulled the drain cover off it was covered in a gross black mold about 1/4 inch thick! how do we prevent this problem reoccurring and what is it? Thank you, the Carlson's.
Was this helpful?
Yes
No
Popular Solutions for Hoover 24 in. DT999
Questions and Unsolved Problems for Hoover 24 in. DT999
Do you recommend Hoover 24 in. DT999 Free-Standing Dishwasher?
Answer
Answer
does the upper arm in a dishwasher turn all the time it is running? Mine doesn't seem to do it
Answer
my hoover hd5 555m wont fill any ideas? please yup i know the water is working......as it is shared... (More)
Answer
Hoover DT999 dishwasher shows error code E1 - no water. Tap is on and water geting throgh to inlet... (More)
Answer
how do you get it to start. Have switched on, chosen programme - what next?
Answer
system fills and stops but spray cycle dose not occur, just keeps counting down then empties hoover... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hoover 24 in. DT999...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
