Question about Sewing Machines
Singer Sewing Machine Model 4620C.
My Singer is 5 years old but has never been used. First time to use it stitches a basting stitch and can't find out how to adjust the stitch so it's normal. Can't find the manual. Can you help?
  • 192 Answers
SOURCE: Husky 165 - won't do a basting stitch
Set the machine to its longest stitch length, put it in the warmest room in your house and in the sun if possible. If the stitch gets longer when the machine is warm it needs to be cleaned and lubed so that the stitch length mechanism moves freely.
If the lube in the machine is getting old or is nonexistent, the reverse button may be depressed and appear to return to its original position, when released, but the mechanism inside the machine only returns part of the way causing the length to be shorter than normal. Heat often masks this problem allowing the mechanism to move.
Posted on Nov 14, 2007
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 43 Answers
SOURCE: reverse stitching on a singer 514, HELP!
In the center of the stitch length knob (at the right side of the machine) is a button. You would push that button in to get the machine to reverse.
Posted on May 08, 2009
bargainbox
  • 1388 Answers
SOURCE: singer 237 stitches loose on bottom of fabric
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Sep 02, 2009
Zenqi
  • 208 Answers
SOURCE: singer machine needle won't do width in zigzag
It sounds like it needs lubrication on the needle bar frame and linkage.
Posted on Oct 01, 2009
Singer 29k71 stitch length on the longest still not enough about 2 mm..! What can be done..!?
If that is the maximum stitch length and you do not have a basting stitch, then you can't make a larger stitch. You could try free motion stitching where you drop the feed dogs, use a darning foot and manually move the fabric, but getting the stitches even would be quite difficult.
Aug 15, 2017 | Singer Sewing Machines
How do I set the machine to do a basting stich
if the machine can do a basting stitch the information should be in the sewing machine manual, if you don't have a manual, add a comment with the name and model number of the machine and someone should be able to help you find one.
or you can also try youtube for a video
May 11, 2016 | Sewing Machines
How to baste?
Basting is simply using a long stitch that can be pulled out after you put the main stitch in. It holds fabric in the right place till it is sewn.
Sep 07, 2015 | Singer 9960 Quantum Stylist Sewing Machine
Singer sewing machine is stitching every half inch how to fix this
I had a singer machine that had a basting stitch that was like that. Make sure that you have chosen regular straight stitch.
Feb 12, 2013 | Singer 2639
I have a mORSE 6500 WHICH WAS MADE BY TOYOTA AND i have no idea how to install cams nor what tension setting or stitch length I would need
The tension will depend on the material (knit, heavy denim, etc). See this pdf for a description of testing and setting the tension: www.ca.uky.edu/HES/fcs/FACTSHTS/CT-MMB-213.pdf . Most of my sewing is on double knit fabric and I start with the tension on 4. (Turn the knob to the right to get a higher value and tighter tension). The stitch length depends on the material if you are basting (for test fitting or prior to installing a zipper, for example) or if you are sewing the seam. Basting uses a long stitch, about 5-6 mm (4-5 stitches per inch). Most seams for a mid-weight fabric use a stitch length of 3-3.5 mm (8-9 stitches per inch). See Table 1 here: http://www.dummies.com/how-to/content/making-machine-stitches-work-for-you.html for more details.
To insert the cams, open the top of the machine and identify the fixed cams in the machine. If another specialty cam is installed, you may need to remove it to put in another cam. My machine (a Singer) only has space for one specialty cam at a time. The cams are labeled with the stitch that they provide and the stitch indicator faces up on the cam stack. (For my machine that means that the tall ring of the cam is up.)
A You-tube video of using the Morse 6500 is available: http://www.youtube.com/watch?v=ksfZZyqO1eE .
I hope this helps.
Mar 31, 2011 | Toyota Sewing Machines
Just bought a singer 8280 and as a first time sewer find it great. Can I get a ruffler foot for it and are they a universal fit or do I need a particular one?
Usually universal, just be sure that it is a low shank because that is what your machine looks like to me. I looked up your manual online at www.singerco.com and here is a little bit of advice. Go there and download a copy to your computer. That way, you will always have a copy when you need it. You can make ruffles by using your machine stitch length, just make it the longest stitch, loosen your top tension, then pull on the bottom thread. Or you can do a basting stitch by hand and pull the thread and distribute evenly, then machine stitch to lock it down. I haven't used a ruffler in years. Try it first and see if you like that idea before you invest in a ruffler. They can be pricey, try ebay for a used one but be sure that it is a low shank . I am also sure that Singer sells them too, 1-800-4singer. Good luck and happy sewing.
Oct 30, 2010 | Singer 8280 Mechanical Sewing Machine
What settings do I use on my singer 6038c to make simple basting stitch and a simple ruffle
Use the longest stitch length and loosen top tension,. Practice on a piece of scrap material until you are satisfied with the results. Good luck
Oct 24, 2010 | Singer 6038 Mechanical Sewing Machine
Reverse stitching on a singer 514, HELP!
May 08, 2009 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
580 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
