Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Dishwasher won't work
I've had this kitchenaid dishwasher for 3 years. We have had this same problem 3 other times and have had the control panel replaced each time. When I push the normal cycle and then start, the normal light is supposed to blink once and then start. Nothing is happening and the dishwasher is not stareting. Please let me know what you think.
Thanks,
    President:
  • 1,314 Answers
I think they been charging you for the control panel and replacing the fuse there is a fuse in the control panel go to appliance parts store and tell them you need control panel fuse for your model get two or three then remove the panel and replace the fuse
Posted on Sep 09, 2008
Brand new KitchenAid KUDE40FX door won't latch any more and thus won't start.
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Jan 11, 2013 | KitchenAid Superba KUDE40FX Fully...
Kuds02frss01 blinking normal light
The electronic control board is the part you should have replaced. it is not the control panel with buttons you push that were malfunctioning, but the computer that receives the input from them. If you replaced a part starting with 857 ending in four other numbers like 857xxxx, you need the part number 8559824 or W10084141 instead. hope this helps.
Aug 26, 2012 | KitchenAid 24 in. KUDS02FRSS Stainless...
Start button not activating my kitchenaid sculptura dishwasher
Yes the control panel (also called switch panel) can be replaced.
Refer this site for details. You are probably referring to item 3 in the diagram.
Oct 30, 2011 | KitchenAid KUDS24SE Built-in Dishwasher
Kitchenaid dishwasher Kudio1il 24'stainless steel. Problem with control panel. Dishwasher will not start. Only NORMAL button, HI-Temp button, Energy Saver Dry button, and cancel button light up when...
I'm having similar problem.I uploaded video of my attempt to reset and problem that I have after.I've already tried replacing my board... but have the same problem. The board was a refurb... so not sure if the board sent was defective - or if the problem is the control panel or something else?? thoughts?https://www.box.com/shared/ef486b70331cd4462ed6
Oct 05, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
I have a KitchenAid dishwasher model # KUPDO1DLBSO, S/N FM4003050. There is no power to the control panel, no lights and won't start. It stopped in the middle of the cycle with water left in the...
what most likely is going to be the problem is a blown thermal fuse that attaches to the control panel housing. gain access to the control panel and use should see the thermal fuse,the housing for the control board is grey and this part is white.Remove the wires to it and check for contininity on it using a ohm meter set to a low ohms setting. If it turns out to be good the next thing to check is the switch(s) on the latch asm using the same method to check them as the fuse.BEFORE CHECKING EITHER OF THOSE BE SURE TO DISCONNECT POWER TO THE DISHWASHER
Good luck, i hope that i 've helped you to figure out what is wrong with your dishwasher,
Gene
Aug 06, 2011 | KitchenAid Dishwashers
How do I turn off the childproof lock on my KitchenAid Superbua dishwasher?
This depends on the exact model of the KitchenAid Superba dishwasher. There is a button on the control panel that will indicate the Control Panel Lock. Usually this is labeled Control Lock (Hold 3 sec) or 4 Hour Delay (Control Lck 3 Sec). The phrase in parentheses is below the key in a smaller font.
Press and hold the button to toggle the lock on and off. Sometimes you have to hold it for more than the listed 3 seconds.
I hope this helps.
(my reference was the manual for the KitchenAid KUDE40FXSP . Other KitchenAid appliance manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . Just enter the model number and the type of person researching the documentation (consumer).)
Jul 14, 2011 | KitchenAid Dishwashers
Kitchenaid kud101tj "cancel drain" light and "Rinse Only" lights are falhing and DW won't start???
Don't know if this will help, but when I had problems with my control panel (lights blinked and nothing worked) I fixed it by disconnecting the power completly from the dishwasher at the fuse box. Leave it off 10 or 15 minutes and then repower. That reset mine and it worked again...has happened several times and each time I could fix it by cutting the power. If that doesn't work, you may need a new control panel.
Sep 11, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Dishwasher lights are all flashing
If you do have the Touch Control Electronic Pad, then you do have a problem, moisture related. You need to open the panel, use a Hairdryer to dry the panel properly and replace. This sorts many of these Touch Control Electronic Pad.
Nov 23, 2007 | KitchenAid 24 in. KUDI02IR Built-in...
KitchenAid kuds24se dishwasher DOA
We had same problem - took dishwasher out from counter and found it to be unplugged way way in the back 1
Sep 21, 2007 | KitchenAid KUDS24SE Built-in Dishwasher
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
576 people viewed this question
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
