Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Refrigerator Lights Stayed on, Melted Plastic and Stopped Cooling
We've had this LG LFC25760SW refrigerator for a little over a year. We came downstairs the other morning to find that the two light bulbs had been on all night. The plastic piece that displays the fridge and freezer temperature was hanging by wires b/c the heat from the light bulbs melted the plastic. The entire refrigerator was warm. I took out the light bulbs and the refrigerator began to cool down to normal temperature.
The doors were not left open. If they had been a) the refrigerator would have beeped as always, and b) even we didn't hear a beep, the lights turn off after a few minutes of the door being left open.
Anybody experience this? Is this a total defect? Fixable?
Luckily we have an extended warranty and somebody is coming to the house to look at it. Any insight so I have a knowledge base with the repairman?
Thanks! My LG is model #LFX25960ST, I bought it from Home Depot in October of '06. It started leaking water into the freezer and I just noticed that the lights in the refrigerator melted the plastic housing after I smelled something burning and the front doors were really warm. I read other postings and have been frantically trying to get the bulbs out so it won't start a fire. The sockets are burned. This is sooo scary I was almost out of town this weekend! If I wasn't here it would probably have started a fire and I'm still working on trying to prevent that as I type this. I will be contacting LG, Home Depot. I've already had parts ordered for the leaking icemaker line and now this.
  • 4 more comments
  • lauramjohnso Sep 07, 2008
    I contacted LG and they're sending an LG technician over here to fix everything they say and extending my warranty. I just had to fax my receipt in. We'll see what happens.
  • jsnic Sep 22, 2008
    I have the same thing going on with my LG refrigerator. No need to elaborate on the symptoms, obviously LG is quite aware of the issue. Upon descibing the symptoms to them, they immediately offered to extend the warranty. I don't like being the go between between a Service Bulletin and a product recall. Obviously a specific number of houses have to burn down before replacement is made. I live with my 80+ year old in-laws, and we came upon this problem with a warm refrigerator and a light cover that mysteriously fell off. The molding to the light box cover had melted as well as burning of the bulb receptacles. My wife and I were away on vacation for two weeks before discovering this. I want the unit out of my house, but LG was not too keen on the idea. Someone is supposed to come out tomorrow to follow up on the service bulletin and fix the 'control board' . I find it interesting that new models of LG refrigerators that have LED lighting. I'm sure that they get the most out of saying that these units are much more 'Energy Star efficient' and 'Green' rather than unlikely to cause enough heat for a fire to occur.
  • sandi7 Sep 23, 2008
    September 23, 2008. I woke up this morning to the same problem of the lights on and the cover melted and everything warm in the fridge. I unscrewed the lightbulbs. Will call about warranty. Purchased the summer of 2006.
    This is the second problem. The freezer frosted over continously until a part was replaced in the first year.
  • Anonymous Oct 10, 2008
    This thing is apiece of ****. lG sent out a techinician... it was fixed for a week or so...now it's doing it again ??? what do I do ?
  • Anonymous Oct 18, 2008
    LG LFX 25960TT Light stayed on all night and melted the fixture.
  • Misscrossy Nov 19, 2008
    Hello,  I have the same problem, the light fixture melted off and is hanging,   the food on the top shelf is warm.  I don't have an extended warranty and guess what??the warranty is just up.  Not sure what to do.  The store says it's not there problem because the warranty is up . I thought this was a sensible purchase it cost enough.
I had the same problem and fixed it by replacing the Main PC board mounted on the rear of of the refirgerator, as rstynls pointed out. Part number is 6871JB1423N, available from Sears parts direct for around $100. I see it's also on eBay for about $80.
Naturally you want to replace any melted parts like the lens shround and cover if needed, but I didn't replace the socket assembly or reflector even the socket assembly was slightly discolored. I don't see how a new socket assembly could incorporate a temperature sensor since that would require there being a wire run for it already in place, unless the original units had the wire there but it just wasn't used. Even so, if you have to rely on the temperature sensor to shut off the light, you have a problem to fix anyway, although in theory it may prevent a fire hazard.
Posted on Dec 09, 2008
  • 706 Answers
Maybe this will help.. here is a link for you to get the service manual.. Hope this helps..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Posted on Sep 07, 2008
    Problem Solver:
  • 12 Answers
The problem is with the main motherboard. It needs to be replaced along with the light socekt assembly. The new assembly has a temperature sensor that will cutoff power to the lights if it happens again.
Main board 6871jb1423n
Socket assembly 6621jk2003b
Posted on Oct 05, 2008
Had the same problem a few weeks ago. Ruined a lot of food besides the fact that it could have caused a fire. The light bulbs sockets are very, very burnt.
Posted on Sep 23, 2008
I had the same problem with mine last Spring, same model, also bought from HD in Oct '06. After checking online and finding I was not the only one with this problem, I made numerous calls to LG, suggesting there should be a recall. As you said, someone's house could burn down! I was given the old brush-off. I even had to pay for my own parts! I contacted the Consumer Products Safety Commission on this, and all I got was "we are understaffed, under-budgeted, so we can't investigate most of the claims we get". Meanwhile, I decided to replace the bulbs with cooler CFL lights in case this happened again. Just the other day, I noticed things in the fridge are starting to freeze. Upon investigation, I found the lights are staying on again. They are warm enough to make the fridge run more, but not hot enough to melt the plastic shroud. I am trying to find what causes this to happen. Some forums say it is the computer board. I will remove the lights before I pay for that!
Posted on Sep 14, 2008
Hello, We have a Whirlpool Gold bottom freezer
I don't know about Whirlpool refrigerator freezers, but my Amana has a temperature control in the freezer that regulates the overall cooling, and then the control in the refrigerator compartment controls how much of the total cooling is sent to the refrigerator section. My advice would be to lower the temperature setting of the freezer, and see if the temperature lowers in the refrigerator as well. Also, you can go to the Whirlpool website and they can help you further.
Aug 02, 2013 | Refrigerators
The LG refrigerator door lights do not come on when I open the door every thing else works. French doors #LFC25760SW Hepl!!!
Were the doors left open at anytime? If so it has a thermostat that will shut off the lights to keep from getting too hot, If they werent left open, could be bad bulb or stuck or bad light switch on the door, all very easy fixes.
Sean
Mar 26, 2011 | LG Refrigerators
We have a Lg LFC25760SW fridge and the lights stay on in side the fridge
LG had a circuit board malfunction with many french door models with fridge lights staying on with the door closed. the bulb lens usually overheats; deforms; and falls off. the plastic frame surround is warped too. the bulb sockets are darkened too. if this is the case, call LG and they will usually repair this overheating issue for free. you can just unscrew the bulbs for the meantime.
Jun 15, 2010 | LG LFC25760TT Titanium Bottom Freezer...
Lights stay on inside Sears (really LG) french door refrigerator
That should be a covered repair. There was a safety bulletin on that. Call Sears and complain. Tech should have known that.
Dec 10, 2009 | LG LRFD25850 French Door Refrigerator
REFRIGERATOR LG LFC25760SW WILL NOT TURN LIGHT OFF. AREA WHERE BULB IS OVERHEATED, MELTING PLASTIC SURROUNDING IT. HOW CAN I SOLVE THIS PROBLEM? THE DOOR EVEN WHEN HELD OPEN AND THE BUTTONS THAT TURN THE...
Turn the unit off so the bulb can cool and just take it out. Sounds like there is a problem with the switch, as to the melted surround if it is part of the liner there aint nothing you can do, save patch it with fiberglass and resin.
Dec 01, 2009 | Dishwashers
Our 3 yr old LG Model LFC25760SW French door refrigerator over freezer is forming ice on the bottom of the freezer compartment, beneath the drawer. The ice maker switch is off. The water is coming from the...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 25, 2009 | Refrigerators
LG Design defect - Light stayed on and melted the fridge.
yes, contact LG for this known problem. it's a circuit board defect. the tech should replace both bulbs w/lower wattage, plastic bulb lens, lens surround and bulb sockets themselves. be sure to have your fridge model # and serial # handy.
Jul 12, 2009 | LG LFC25760 French Door Refrigerator
Tried to replace the filter and after that the upp
I don't think replacing the filter had anything to do with your problem.  If the ice maker is working then the freezer is OK since they have the same cooling source.  I had the same problem with this model refrigerator six months after I got it (in 2/2007).  The cooling in the refrigerator section failed.  The refrigerator fan and the air duct as well as the mother board were replaced.  A year later the ice-maker fan froze up. It and the housing were replaced with improved models.  The mother board was also replaced again due to software changes related to the ice maker.  This model is also part of an Energy Star/LG case agreement to modify the circuits and provide a lifetime annual rebate payment.  Check it out and register on the LG web site.
May 19, 2009 | LG LFX25960ST Stainless Steel French Door...
The control board relay switch for the light bulb stuck in the on position and needs to be replaced along with the light cover and housing.  There is also a replacement light harness that has a high limit switch to shut off the lights if this happens again.  LG knows about this problem and if you call LG customer service, they will grant a one time warranty extension to take care of this problem.
Jun 09, 2008 | LG LFC25760 French Door Refrigerator
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
995 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
