Question about Hoover 24 in. DT999 Free-Standing Dishwasher
Dishwasher doesn't fill
Any suggestions?
    Novelist:
  • 74 Answers
Dishwasher Doesn't Fill If a dishwasher runs but doesn't fill, either something is wrong with its water supply system or it is draining water too soon. 1) First make sure the water is turned on. Check the hot water supply stop valve, normally located under the sink. Open it all the way by turning it counterclockwise. If there is no reason this would have been turned off since the last time the dishwasher worked, go on to the next step. 2) Turn off the power to the dishwasher. 3) When the dishwasher is cool, look for the float inside the dishwasher --usually a small plastic dome or cylinder mounted inside at the tub's base, near the front. When you move most types of floats up and down, you can hear them click because they trip a lever (they are spring loaded). Lift out the float mechanism and clean around the float tube; many floats must be disconnected from below--to do this you'll have to remove the lower access panel. Rinse off the float, then replace it in the tube and be sure it moves up and down freely. 4) If you're experienced with minor repair work shut off the hot water valve to the appliance. Locate the water intake valve, behind the dishwasher's bottom front panel, disassemble the valve to reveal the screen, clean debris from the screen, and reassemble. If the screen doesn't appear to be blocked, call a repairperson (they will probably need to replace the water intake valve). 5) If none of this helps, call a repairperson. Any of several parts, including water inlet valve, pressure switch, and the timer or selector switch, may be faulty.
Posted on Jan 18, 2006
Great idea thanks. The float was dirty and the door seal to my kitchenaid had com a little lose from the bottom front and was impinging upon the float!
I cleaned the float removed the offending small strip of rubber seal material and FIXED.
Thanks alot bud.
A dad.
Recall Road Less Travelled. Scott Peck MD. All problems can be solved if we take the time. And find help - thanks.
Saved alot of money in repair bill and most importantly - time.
Posted on Nov 11, 2007
The electrical controls do not tell the water intake valve to open.
Posted on Sep 19, 2007
Tip
How to repair or fix a Dishwasher if it doesn't wash well
A common cause of poor washing results is improper loading—dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home’s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20–120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn’t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn’t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn’t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren’t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
on Sep 03, 2010 | Dishwashers
Bosch dishwasher makes noise but doesn't start
When you start a wash cycle on your Bosch dishwasher and it does not work, stay calm. It could be something simple, especially if you just installed it. Make sure the power cord is connected properly and a circuit breaker did not trip. How to Troubleshoot Bosch Dishwasher That Doesn Fill With Water
Sep 25, 2017 | Bosch Dishwashers
Sanyo dishwasher doesn't fill. No error codes showing. (It thinks it is filling)
This is most likely either a broken solder joint in the control panel or a defective inlet solenoid.
Mar 12, 2012 | Dishwashers
Whirlpool dishwasher wont wash
if the bottom tub is filling with water but not washing the issues is with the wash motor, some of this model use a start capacitor that can fail, if it has a capacitor on the side of the motor it may have failed but are difficult to diagnose but are cheap to replace so worth trying, if this doesn't help or if it doesn't have a capacitor then the fault is with the wash motor.
Mar 08, 2012 | Whirlpool Gold 24 in. Built-In Dishwasher...
Hi, We have a G638 plus and have it connected to the cold water tap. When we press start, it fills the machine with water and once the machine has been filled, the program doesn't start and after 2-3...
Hi
Intake/Drain light flashing means an issue while draining. You would need to check for air gap on the dishwasher, it may be clogged. It prevents dishwasher from draining, sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections & remove motor (single screw holds motor, it is on the outside back of the machine). Try to rotate the motor (use WD40 is necessary). If you cannot rotate it, then motor will be required. If the error still appears then cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Switch the appliance off and then back on again. Hope this helps... Please post back if you need more information.
Daniel
Aug 16, 2011 | Miele 24 in. G638 Plus Free-standing...
Not filling with water. After a wash cycle, I noticed that the detergent door had opened but half the detergent was still in the door and the other half had fallen onto the utensil rack. I tried running a...
Hi
You'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 12, 2011 | Viking 24 in. Professional Series VUD141...
Bosch SHU 5302 Machine doesn,t fill with water.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 16, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Response to suggestion.
I was talking about the water inlet line going to the fill valve. The fill valve is located on the right hand side with the bottom panel removed. From the fill valve there is a water inlet line running into the SIDE of the dishwasher tub, NOT the pump in the back. The two pumps on the dishwasher are used for the cycling of wash water and/or draining the tub. Neither pump are used for the FILL cycle. Having an inlet line under the kitchen sink would make things easier. CLR would probably do the trick, but I'm afraid that gravity is going to keep you from accomplishing what you need to do.
Jul 30, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Dishwasher conitues to fill even if unplugged
If the dishwasher is filling with out the power on, you have a defective inlet water valve. If it's new, have them repair it under your warranty. If not the part number is wd15x10003. Easy fix, on the left side behind the toe panel...Catriver...post back.
Aug 14, 2006 | GE 24 in. GSD4000J Built-in Dishwasher
Hoover 24 in. DT999 Free-Standing Dishwasher Logo
592 people viewed this question
Top Hoover Dishwashers Experts
Jose Pino
Philip Postlethwaite
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
