Can not get my dlink to communicate with my computer
    Problem Solver:
  • 18 Answers
Plz check ur ip number and make sure ur dlink is no where near to any electronic device
Posted on Sep 07, 2008
How can I connect to my new WiFi using my dlink dap 1320 thru my Samsung tablet, how can I reset the old one
You need to get the Wireless Range Extender to communicate with your existing router. Instructions are attached. If you have already done this, you should be able to search for WiFi connections and connect to the SSID with your password. It should be the network that has the most strength. In Canada, you can contact Dlink at (800) 361-5265. In the US, (877) 453-5465.
http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201320/QIG/DAP%201320_QIG_US.pdf
Feb 03, 2015 | Samsung Tablets & eReaders
Netis Wireless-N-Broadband Router
If you have communication on one computer, it confirms you are making proper connection; thus the second computer was not setup correctly. Take out the Manual and start from scratch and do a step by step setup function. Write down your administrative password and codes. Make certain you type in the data correctly and when done see if the communication paralells that of the first computer.
Jan 28, 2014 | D-Link Dlink Airplus Xtreme Dwl-2100ap...
Dlink accesspoint doestnot connect with playstation3
The Dlink wireless modem is configured correctly and the computer/laptop can access the Internet wirelessly.
The PS3 needs to be configured with the Dlink modem's wireless settings so it can communicate with the wireless modem.
To configure the PS3 please follow these steps :-
1. Power up the PS3 and login then Select Network Settings and
press X
2. Select Easy then press > button
3. Select Wireless then press > button
4. Select Scan then press > button
5. Select the wireless modem you want to use, then press X button
6. Confirm the SSID for the wireless modem then press > button
7. Select the security settings (ie WAP, WPA - this is the in the wireless modem settings) then press > button
If there is no encryption I suggest you enable the encryption on the wireless modem, use passphrase to generate the encryption key.
Write down this encryption key, you will need this key for your computers and PS3.
8. Enter the WEP or WPA encryption key (from the wireless modem) then press > button
9. Check the settings then press X button
Dec 23, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
Connect dlink wireless router to cable modem
If your cable modem was operative ...here's an easy procedure:
1. Turn off all network routers, modem, computers..
2. Turn on the power to the DLink router. let it cycle up.
3. Connect your ethernet from the Dlink to the cable modem and then turn the power on to the cable modem and let it cycle up.
..this will "fool" the cable modem into finding your dlink as the "computer" ..since the cable modem is set up for only one computer, if the dlink is the "computer" that it locks in, then go ahead and turn on all other computers and etc...you should be able to get online wirelessly..
Follow the order of events above and it should be cool.
Oct 06, 2009 | Computers & Internet
How do i connect dlink dl-524 to pc without i want to set up lapt
You should be able to download the software/driver package as well as manual from the DLink website. Just click on the Support link and lookup the model # of your router. You will need to know which operating system you are running in order to download the correct package. Once downloaded you can install by following the onscreen directions. Hope this helps.
Sep 16, 2009 | Computers & Internet
D-Link DI-524 is not communicating with modem
Checklist:
* Is DHCP configured correctly?
* Connect your server and laptop to a switch (not directly with the cable)
* Can they ping each other?
* Check that the firewall is configured (or switched off if you have another FW in place)
* Default gateway should be your router, not the computers (until you have configured RRAS for example)
Here you can find more information about how to configure various roles in 2008: http://technet.microsoft.com/en-us/windowsserver/2008/default.aspx
Sep 07, 2009 | D-Link AirPlus DI-524 Wireless Router
I got d-link dir-615 wireless router and a 2wire modem 2071-a and when i set up the d-link router my desctop computer that is pluged into d-link cant get internet im 11 and got no idea wat to do oh and the...
does the computer that's directly connected to the modem connect to the internet? If not then make sure your settings are well set, your service provider (ISP) and all the other settings that your ISP supplied you have not been tempered with or modified.
Does you WDS and router communicate? Have you changed the IP addresses form the default ones that came with your devices? They usually begin with 192.. at times the default IP addresses don't work in some institutions. You can configure most DLinks using internet explorer by typing in the DLink IP address bar.
Considering your age, you need someone to show you how these things are done.
Aug 24, 2009 | D-Link 802.11g 54Mbs Cable/DSL...
Communicating my laptop with my Dlink 624 router
first, you need to make access by cable (rj45), may be has the router adreses 192.168.1.254 0r 192.168.1.1, & make configurations for the wi fi from the router
Jul 20, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Enquiry
repeater, as in a link up for wireless node to node communications?
hmmm...www.dlink.com
check your computer's warranty here FREE
Feb 25, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
Inter Vlan routing
Just For InterVLAN routing, Mark (enable) administration Access for ALL VLAN :P
Sep 18, 2007 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
