Question about Sony Audio Players & Recorders
SONY IN-DASH CD PLAYER
POWER TURNS ON AND OFF. UNIT WILL NOT PLAY FOR MORE THAN 2 OR 3 SECONDS AND POWER CUTS OFF
    Problem Solver:
  • 6 Answers
RJS2OO9
the possible trouble of your unit is the optical laser lens. once the lens cannot read to the disc it will automatically turn off, or maybe your disc are damage...
johnfil...
Posted on Oct 08, 2008
I have problem with CD player.
The drive tries to read the CD but fails, then "resets" to try again. It is likely the complete unit will have to be replaced even though the other functions work.
May 04, 2014 | Panasonic Car Audio & Video
Cassette Recorder play problem
It is problem in Take-up Reel section and its not sending signal to processor. How old is this unit?
Jul 24, 2008 | Onkyo TARW255 Single Dual Cassette Deck
Denon DCM-370/270 - issue playing CD's. A CD will
I would replace the audio cable from the CD player to the Denon amp, a long shot, if you have other devices hooked to the amp and plays fine, the problem will be in the CD player. However! if all sound sources have the same problem, the issue is with the Denon unit.
Mar 09, 2012 | Denon Audio Players & Recorders
How do I unlock my Sony DVP - NS330 player, bought
Codes for-
Sony DVP-NS300, Sony DVP-NS305, Sony DVP-NS400D, Sony DVP-NS700, Sony DVP-S330, Sony DVP-S335, Sony DVP-S360, Sony DVP-S336, Sony DVP-S525D, Sony DVP-S530D, Sony DVP-S535D, Sony DVP-S536D, Sony DVP-S725D, Sony DVP-S735D
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
Yours is not listed but these may be worth a go.
or try http://www.haldigital.com/hp/dvd.htm
May 15, 2010 | Sony DVP-NS330 DVD Player
Car radio/cd player cuts off radio will not play cd will not play ,hit the power button and will come back on some times it wil not. its seems like there is static sound when the music does not play on the...
Hello pinkperry,
It sounds like the wiring between the cdplayer and the dash has come loose. When the wires are not making proper connections some of the speakers or functions of the radio cut on and off.
This is just my first thought and the easiest thing to fix. You will have to remove the cd player from the dash. After which you will want to check the wiring. Chances are your cd player has a harness if it's an aftermarket cd player installed in your car. If it does there will be two sets of wires to double check.
Just make sure all the wires are securely twisted together (the sets of wires) and taped up with electrical tape.
Try that and post back if you have any further questions. Thank you for choosing Fixya!
Aug 25, 2009 | Car Audio & Video
Sony xplode cd player sub problems
Switch your blue wires around.
You have put the remote antenna wire to the remote turn on of the amplifier. The radio cuts off the power to the "power antenna" when you switch to a different mode... so your amplifier is now losing the turn on signal it requires to stay on.
Simple 2 minute fix.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 19, 2009 | Sony XPlod CD Player w/MP3 Playback...
Jvc cd power
Check connections behind dash, especially ground. Make sure no wires are crossed/touching, and make sure all connections are strong. If still a problem check grounding from battery to frame....maybe even consider running the "ground" wire from your CD player to your frame.
Aug 09, 2008 | JVC KD-G310 CD Player
Sony cd car radio
if you got the radio password or radio code..try to reconnect the battery of your car..turn on your radio,then enter the radio code you hav...:)
Oct 30, 2007 | Sony CDX-M610 CD Player
63 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
