Question about Haier Energy Star ESA3183 Air Conditioner
Air ducts are noisy
The air ducts in my central air coditioning system are noisy. I'd like to know why and if there's a way to fix it.
  • 50 Answers
Most folks when talking about noise means it's coming from the return air or intake. Is this correct? Please advise. RepairUSA
Posted on Aug 28, 2007
    Novelist:
  • 74 Answers
Many heating/cooling ducts are metal, so they conduct noise quite readily from the air-handling unit to your rooms. To break the conduction of sound, you can have a heating contractor insert flexible insulation ductwork between the heating/cooling system and the ductwork runs. If you hear a pinging or popping sound coming from the ductwork, this may be caused by thermal expansion or by air blowing past a loose flap of metal. Track along the duct runs, listening for the sound. If you find it, make a small dent in the sheet metal to provide a more rigid surface that?s less likely to move as it heats and cools.
Posted on Jan 18, 2006
    Scholar:
  • 161 Answers
If your air ducts are metal then there will be a certain amount of expanding and contracting because of the temperture constantly changing as the unit kicks on and off. Even if you had your metal replaced with plastic or fiber there is still expanding and contracting as the unit kicks on and off. Insulating your attic and your ducts with heavier insulation can reduce noise somewhat. Not to mention giving you more protection.
Posted on Aug 08, 2007
2 Suggested Answers
SOURCE:
  • 1033 Answers
SOURCE: We have a 2.5-ton 13
Hello, does the compressor come on? When the unit is running after a few minutes touch the pipe with insulation on it, it should be cold and have some c ondensation on it. Let me know if the pipe is cold or not
Posted on Jun 09, 2011
Central air unit very noisy. Any quick fixes? Lubricants?
Some are inherently very noisy - seems to vary from brand to brand.
Jul 16, 2016 | Heating & Cooling
Sweating duct work and pipes
high humidity will cause sweating on cold lineset and ductwork,,, insulate both and it will solve problem
Jun 03, 2014 | Ruud Central System Air Conditioner
Eddfx24fa2 model # on furnace of central air unit in my basement I am trying to calculate wattage of this central air unit On compressor outside: 220 volts, 60 amps??? Does amps sound correct? amps x...
It is a two ton system. and without doing a heat load Calculation and not knowing the heat load It would not be anything but a guess. But if everything is working properly and the system is clean and with good duct work, than it should be big enough for the size of your house.
Jun 06, 2011 | Airtemp B6Y12F2A Air Conditioner
I have an HRV system and want to know if it is possible to run a heat pump through my HRV ducts in the ceiling?
Hi, can you tell me what kind of heat recovery ventilation system you have? Is it a Honeywell, Lennox, ect.? Also tell me about how you have it set up as far as the duct work you are talking about and what kind of heat pump system you plan to install. If you tie your central air heat-pump ducts into the HRV ducts, it will interfer with the air flow. If you will, please tell me what you plan on doing as far as installing what to your home? New duct work for a new central air heat-pump unit, or what, so I will have some idea on what you are doing. Thanks so much. Contact me through my user name below.
Sincerely,
Shastalaker7
Apr 13, 2010 | Heating & Cooling
Position of ceiling diffusers for a ducted warm air heating syste
You want the air to distribute through the room as evenly as possible. You don't want the air to blow down in one spot. In a room where a thermostat is located make sure the air doesn't blow toward the thermostat or this will make the unit turn off before the desired temp is reached.
Nov 15, 2009 | Desa International CBN30T Central Heating...
We have a fairlynew 5 ton Central Ruud or Rudd unit that it is so noisy in the yard that we can not stay out there. We thinkit is the compressor. Help
I have a new 13 seer rheem or ruud same thing. I can not here it run. Uou must have a bad compressor. Ruud put schroll compressor in and when they start to go out they will drive you nuts they are so loud. Get it changed before your warranty runs out. Ruud will change your compressor if it to noisy. No problem. Russ
Jul 20, 2009 | Ruud Central System Air Conditioner
I have an old 1985-86 coleman central heat and air need manual
The filter is located before the blower if your Coleman is in a mobile home it will be in the door facing. If it is a standard ac/heat application and a regular residential furnace the blower in the cabinet on down flow (ducts in floor) will be above it and possible in the duct connecting in the top. If its the other way (ducts in ceiling) it could be right under the blower. Either of these could have a filter cabinet on the furnace or could have a filter grille at the end of the return air duct (where the air is sucked in).
Mar 10, 2009 | Coleman Heating & Cooling
Ductless minisplit in old mobile home
ductless mini split units are a very good choice!  they are obviously quieter, more efficient and easier to maintain than window units. the downside is the initial expense of buying the unit, but this is paid back in eletric savings and peace of mind. Good luck Peyton
Mar 07, 2009 | Soleus KFR12GWD 12,000 BTU Heat & Cool...
My hvac duct work on one of my central air units has a lot of condensation and causing puddles of water throughout my basement. Do you know what the problem is? The drain lines don't seem to have any...
could be just not insulated enough is this a new instalation? the humidity is too high around the ducts is their a return air vant close by that you can open? you need to lower the humidity or seal the ducts so it cant get to them dan
Jul 23, 2008 | Heating & Cooling
Ruud central air system
Install a condensate pump if you don't have one. Check to make sure it works if you have one and clean it out.
Jun 08, 2008 | Ruud Central System Air Conditioner
Haier Energy Star ESA3183 Air Conditioner Logo
936 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Marat Brikov
juan mendez
juan mendez
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
