Question about Haier Energy Star ESA3183 Air Conditioner
Air handler squeals
The air handler in my air conditioner squeals. what's wrong?
    Novelist:
  • 74 Answers
Squealing sounds from a forced-air heat pump generally occur when the belt that connects the motor to the fan slips. If the blower is making a grinding noise, shut off the unit and call a heat pump repair technician --the motor's bearings are probably shot. In most cases, the belt is improperly aligned or worn and needs replacement. Follow the instructions in your owner?s manual (if you don?t have one, contact the manufacturer and ask for one). This job involves removing the access panel, loosening a couple of bolts that hold the blower motor at the proper tension, and realigning or adjusting the belt. In many cases, it?s a good idea to remove it and buy a replacement at the hardware store. When reinstalling the belt, be careful not to over-tighten it--this can wear out the motor bearings.
Posted on Jan 18, 2006
  • 30 Answers
There's no belt in these units. It's probably a warped blower wheel or bent blower housing.
Posted on Jun 12, 2007
  • 1 more comment
  • Tyboro Sep 02, 2012
    Thanks for the tip!!! Is it easily repairable or should I scrap the unit? Thanks for the info Tyler!!!
  • Tyler T Sep 02, 2012
    It's not that difficult on similar units but I've never done it on a Haier. It's definitely worth taking apart to see if it's something you're willing to tackle as long as you can get any parts you need. a Comment
  • Tyboro Sep 06, 2012
    Thanks very much for the info Tyler!! I will try an locate a manual!!!
SOURCE:
Air conditioner fan is blowing but not air coming
If you mean that your OUTDOOR AIR CONDITIONER FAN MOTOR is blowing AND no air is coming out of the vents within your house, it clearly indicates to me that 1 of 2 things are wrong.
Either (1) your INDOOR AIR HANDLER is NOT running or (2) the INDOOR AIR HANDLER is running but your PLENUM has come apart.
If your INDOOR AIR HANDLER UNIT is NOT running, it could simply be the circuit breaker is OFF/TRIPPED and simply needs to be turned OFF; then turned ON. If that does not FIX your problem, then it is most likely your 5 micro-farad run capacitor for your indoor fan motor needs to be replaced. It will prevent your indoor fan motor from energizing. Worst case scenario would be your INDOOR FAN MOTOR has windings burnt and needs to be replaced. If your indoor air handling unit is equipped with a CONDENSATE VALVE CUT-OFF SWITCH, check to see if your drain pan is filled, thus energizing the switch. If the CONDENSATE VALVE CUT-OFF SWITCH is ENERGIZED, it will prevent the AIR HANDLER FROM energizing. That is the design and the reason for this valve.
Good luck.
Aug 26, 2014 | Heating & Cooling
Need wire diagram from T-stat to Air-Handler then cond unit
green goes to g on air-handler,white goes to w on air-handler yellow goes to outside condensor, red from air-handler goes to rh-rc on thermostat, whire off c on air-handler goes to outside condensor.
May 13, 2014 | Ruud Heating & Cooling
Air Handler squeals when starting and stopping
If this unit is belt driven, the belt may be worn or slightly loose.
Jan 20, 2014 | Rheem RHSL-HM1817JA Multi-Position Air...
I need exact replacement ac air handler Weather King model RCBA4882GH21...4 ton 10 kw elec heat with the I need to replace my Weather King ac air handler unit...4 ton, W shape evap coil ,elec...
What's wrong with your current AHU? Any Ruud dealer can assist you. Most 4 ton units work with r-22 or 410a. As a side note, most parts in an air handler can be replaced unless the case is rusted thru.
Sep 24, 2013 | Rheem Air Handler 4 Ton With Rhplhm Series
Air handler squeals for one half to a second only upon startup
Time for a new drive belt. Clean the air filter while you are at it.
Dec 30, 2009 | Ruud Heating & Cooling
Inside the house I hear a loud squealing sound whenever the air conditioner comes on. It is still cooling just fine. It is a Rudd, about 10 yrs old.
alot of times that noise is coming from the orifice in the air handler it is the gas flowing through the screen could have pick up something in the lines
May 17, 2009 | Ruud UAKA030 Air Conditioner
Air handler
yes and that's dangerous as fumes and exhaust may enter the house
Mar 11, 2009 | Heating & Cooling
Need to find ac coils for RUUD ac in the Air Handler
follow the copper lines coming into the air handler.1 will be large and insulated and the other smaller and uninsulated.They attach to your evap coil.
Aug 18, 2008 | Ruud UBHC Air Conditioner
Haier Energy Star ESA3183 Air Conditioner Logo
861 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Dan Apthorp
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
