Question about Denon Audio Players & Recorders
Display on Denon AV-887 receiver does not show anything anymore...
    President:
  • 624 Answers
This is most often caused by a bad power transformer. The power tranformer has several different secondary outputs and one of them is the supply voltage for the display. There are several other things that can also cause this problem, but all of these would require some knowledge of electronic troubleshooting and the proper equipment to test it.
I work at an authorized Denon service center and have repaired many Denon receivers, so I do have hands-on experience with these.
If you have the proper test equipment, like a multi-meter at minimum, I could help you to figure out what is causing your problem. If not, you really should just take it in for service. The model number of your receiver would indicate that it may still be under the manufacturers warranty. It has a 2 year warranty, so you can probably get it repaired for free. If it has been more than 2 years since you made the purchase it would still be worth it to get it repaired. This is a very expensive receiver and even if it needed the power transformer, which is very expensive, it would still be cheaper to pay for a repair than to buy a new one of equal quality. Even the very best electronic equipment breaks down at some time, it is just unfortunate that yours took a turn for the worse this soon.
If I can be of more help feel free to post a reply and ask.
Dave
Posted on Sep 07, 2008
Denon avr-887 code for comcast silver remote, red key. The 2 codes comcast gives me do not work. Any other codes known?
These are the codes that I have from a few extra sources. They are for ALL Denon receivers/tuners: (3 digit = 262,307)For the AVR all numbers consisting of a 4 number code, all begin with a "5". Here they are: 5006, 5048,5054,5085,5129, 5130, 5131, 5132, 5133, 5134, 5152, 5159, 5160, 5168.I was able to get my 529 rc to program some of the features but I will go back and try other codes that may have a better "fit" and operate more features. Hope this helps!
Sep 05, 2012 | Denon AVR-887
Where is the fuse in a denon AVR-887
It has to have one---follow the power cord inside the unit--if fuse is good consider taking it to a shop for an estimate.
Jun 17, 2012 | Denon AVR-887
Denon AVR-887 turns itself off in 5 secs, any one know why?
You might have the polarities on the speakers crossed, check all speaker connections to make sure the pos and neg are connected correctly. If they are crossed, this will cause the receiver to short out, thanks
Apr 05, 2009 | Denon AVR-887
Denon AVR 2802
if the display did not lit and power indicator is flashing rapidly------you will have short circuit in speakers cables -----turn it off and remove short circuit cable-------or you have block in ventilation holes---------turn power off and leave it to cool down and remove anything block ventilation holes---and turn it on again after cooling---------another solution-------on screen display is set to off on system setup------turn it to on in system setup.
Aug 04, 2008 | Denon AVR-2802
Denon AVR 887 Upconversion With Wii
I have this hookup and it's working almost perfectly:
Wii --component--> Avr-887 --HDMI--> Sharp LCD TV
Sometimes the pictures don't show up during start up, but I figured it was (probably) due to Sharp's HDMI handshake issue, so I turned the TV off and then on, everything works.
Mar 20, 2008 | Denon AVR-887
Denon avr 887 input problem
Sell it on Ebay and buy a new 2309.
Mar 04, 2008 | Denon AVR-887
Protector flashing
first check speaker connections for a short.Something usually is touching either at the reciever or amp.The receiver goes in protect mode when there is a short.If that does not work the receiver may be trying to push more watts than capable
Jan 01, 2008 | Denon AVR-887
Denon AVR-887 and Wii
I'm dealing with the very same frustration. Best I can tell, the problem with my setup is that this model (avr-887) can't pass component video input out through HDMI. Can anyone confirm that?
Prior to setting up the Wii, I'd only been using a single HDMI output from the denon to my tv/monitor.
The only solution I've found is to add a component video output to the monitor -- which is unfortunate. I'd much rather have only the single HDMI out.
Would love to hear if there is a way to set this up without having to add the additional component output...
Dec 26, 2007 | Denon AVR-887
My Denon AVR-887 Keeps turning itself off
I have one and the same thing happened. try resetting your microprocessor and if that does not work, then check the wiring of the speakers. if that is working fine and no wires are touching then I unplugged everything and was still having the issue. took it in for service and it was found that the transmitor was shorted as the speakers that I was using was too high in ohms. it is possible that it could be your caps also if resetting the microprocessor does not help. You can find out how to reset the microprocessor from your manual. If you have the Denon avr 887 with the system turned off hold the power on button and the speaker A and B at the same time for a few seconds. This is compatible to rebooting your computer. Hope this works for you as this was and is my husbands favorite past times.
Dec 01, 2007 | Denon AVR-887
109 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
