Question about Haier Energy Star ESA3183 Air Conditioner
Heat pump trips circuit breaker
The heat pump in my air conditioning system trips the circuit breaker... what do I do?
I want to know the size of breaker to use.we are using a 30,30,30,30but it is kicking off.would a 40,40,40,40or higher be better if they sell them.
Posted on Nov 22, 2008
I seem to have the same problem. But when I reset the breakers, they won't stay in the on position. They go back to the off position. What gives? It is 95F inside the house.
Posted on Jul 22, 2008
The breaker for the air handler may be to small for the heat strip. Check to see the size of your heat strip (KW) and make sure that you have the right size breaker for the heat strip.
Posted on Jan 15, 2008
    Novelist:
  • 74 Answers
Most heat pumps have auxiliary heating elements that provide heat when the weather gets really cold because the heat pump's efficiency drops too low. These elements automatically turn on at a fairly low temperature: around 20 degree F. When they come on, they may be drawing too much power, which trips the circuit breakers. Just locate the circuit breaker that serves the heat pump and reset it.
Posted on Jan 18, 2006
4 Suggested Answers
SOURCE:
  • 33 Answers
SOURCE: carrier central airconditioning heat unit - breaker trips when cooling turned on
well mineswas a blowen compressor
Posted on Jul 19, 2008
SOURCE: Heat Pump/Furnace Trip Circuit Breaker
Check the set screws at the panel and the furnace. May be a poor connection. Happened to mine... probably the installer.
Posted on Dec 05, 2009
  • 288 Answers
SOURCE: heat pump kicks breaker outside in main breaker panel
the start capacitor is bad. Motors develop what is known as lock rotor amperage. requires alot of torque to turn the motor until it reaches iits rated or run load amperage. the motor is not able to overcome the lock rotor amps which is usually 5x the rated amperage and always more amps than the breaker. this is usually not a problem because the start capacitor helps overcome the LRA so quickly that it doesnt trip the breaker. If the capacitor is round and bad it will be bulged at the top, if it is oval shaped then the rupture disc on top will be blown letting all the dielectric fluid out which cools the capacitor
Posted on Dec 15, 2009
Outside unit turns on and runs for a long time by itself then shuts off. Does this all day an night long. Notice this after a circuit breaker tripped. Not breaker to unit though. Other parts of house.
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you need any other Air Conditioning Repair help. Check us out online.
Jul 25, 2016 | Celiera Celi 24000 BTU Ductless Mini Split...
Why after a loud bang did breaker trip on ac/heat unit. Wont run at all now
If its a heat pump and the compressor was running, there is a possibility that the compressor itself or something IN the compressor circuit shorted out and tripped the main breaker. It could also be something as simple as a shorted compressor run capacitor.
If its a forced air system with an electric air handler, resistance heat and central air conditioning....it could be just a shorted heating element that tripped a breaker OR it could have been a control circuit short that blew out the non-fused control transformer.
There are only about fifty scenarios that could have happened to cause the noise and to cause the systems failure....but these are the first few basics that could easily be investigated.
Apr 14, 2015 | Heating & Cooling
Any ideas as to why the panel breaker for my Goodman CPE24-1AB heat pump would immediately trip when the air conditioner is turned on?
Without looking up the specifications for this heat pump, I cannot be certain, but I expect the operation to provide cooling may require more power than when heating. You probably can find the specifications online for this unit. As you probably know, power is measured in watts and is calculated by voltage times current. This also is likely to be 240 volts operation. If you take the specified power on cooling and divide by voltage (240), that will indicate the current in amperage that will be required to start it. Your circuit breaker is set for current and needs to be a higher current than is required. If that is the problem, you can buy circuit breakers at Home Depot or Lowes. You have to remove the front panel of your breaker box and snap out the circuit breaker. To be safe it would be good to turn off the main breaker switch before you open the front panel and remove the circuit breaker for the heat pump. Should your calculation of current required be less than the rating of the circuit breaker, that implies a malfunction of the heat pump in the cooling mode and would require a service call to the local representative of the heat pump manufacturer.
May 16, 2014 | Goodman CLQ36AR49 Air Conditioner
Tempstar 2400 blows the a/c breaker when heat is on
How long before the breaker trips?,does the a/c work ok,gas heat or heat pump?,electric strip heat on auxiliary heat,if these are shorted they will trip a breaker,if the breaker trips instantly you have a dead short in the system,if it runs for a while it may be a weak breaker,you may have a bad compressor if it trips fast or a shorted out heat strip,need more info!
Mar 08, 2013 | Heating & Cooling
Have Challenger Type C 2100 circuit breaker in residential home electrical panel. Manually turned to off position and now cannot turn back on. Pops back to off position. Also says HACR type and common trip...
First HACR is heating, air conditioning,refrigeration. So in other words you could use it on an electric furnace or air conditioning.
IS this the main breaker for the panel? or for and electric furnace. I'm assuming its for the furnace, perhaps back up heat for heat pump. See if there is another disconenct on the furnace, turn it off and see if the breaker resets. IF so you have a short or overload in the furnace.
If' it IS the main for the panel, turn off all the other breakers in the panel, and try to reset the breaker. If that works, turn the other breakers back on one at a time. IF it "POPS" then it is tripping. Don't keep resetting, find the problem.
Jul 19, 2010 | Challenger Connecticut Electric UBITB-A230...
My goodman a/c unit wont turn on at all
Hi, not knowing if this is a central heat and air unit, or window unit, ect, I will say first to check the circuit breaker to see if it has tripped. If you have no power, this could be the problem, it just over loaded and tripped the breaker. If you do find it tripped, be sure you shut it all the way off hard, and back on hard. If this is not the problem, and if you have a wall mounted thermostat, get back to me and let me know what we are working with as far as if it is a heat-pump, gas fired central heat and Air Conditioning, or what ever you may have, This will be of much help in solving you're problem.
Sincerely,
Shastalaker7
Jan 29, 2010 | Heating & Cooling
My Amana heat pump model PHD60C02F1 Keeps tripping the circuit breaker
Is this kicking the ground fault on the cord or the breaker. If it trips breaker could be bad breaker. If it trips quickly it is a short in the unit. Russ
Aug 01, 2009 | Amana PTH123B25AJ Heat Pump Air...
Amana Heat Pump Tripping Breaker
My guess I would say, you either have a wire that is short to ground or if the contacter pulls in, then I would say the compresser is short to ground.There also could be some capacitors that could be short.
Apr 07, 2009 | Amana PTH123B25AJ Heat Pump Air...
My system will run for a short period and then suddenly trips the circuit breaker in the main panel for the heat pump.
I have a Goodman - 3 ton system about 8 - 9 yrs old. I'm being told that I need to replace the heat pump/air conditioner compressor?
What do you think?
Oct 22, 2008 | Haier Energy Star ESA3183 Air Conditioner
Haier Energy Star ESA3183 Air Conditioner Logo
1,911 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Dan Apthorp
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
