Question about Zenith Televison & Video
The picture is not all the way across the screen it has a big gray line on each side and I have pushed the pip button but that is not fixing it
No the problem is not fixed and I do not want to join the premium assistant plan cause it seem to be a rip off when you know how to fix the problem and as easy as sending a email to help someone but you always want money .God don't like ugly especiallly all people don't have money so sometime recieve your blessing in another way other than money.
God speed
Big Bertha
Posted on Sep 07, 2008
Cable input
Hi
I think the problem is in the tuner, a small metal box near the antenna input and can be removed and serviced. But first you should check the DC supply line to the tuner. The circuit has a big limiting resistor (15K/3W) and a 33V zener diode and a small filter electrolitic capacitor). The zener is prone to be leaky and unstable.
Sully
Sep 27, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Toshiba 27A40 has single colored line across enter
Vertical output has cracked soldering. Around $150 to fix.
May 01, 2010 | Toshiba 32A33 32" TV
Picture is too big for screen
You will have a button on the _original_ remote that says Format, Aspect Ratio, Zoom, Size or just AR. It will cycle through Normal, Stretch, Partial Zoom, Zoom, Gray Bar, or the like. You are not in Normal but in one of the Zooms. Stretch is used to make 4x3 movies fill a 16x9 screen, may not be desirable. Zoom is used to fill the 16x9 screen with movies that have been letter boxed. Gray Bar fills the sides of a 4x3 picture on a 16x9 set with gray to "avoid" burn in. Use normal except zoom on LB. -Ken
Oct 04, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Sony videoscope XBR - Side by Side screens can't change it back.
Sounds like your TV has a PIP (picture in picture) that allows your AVI (audio visual input) to be viewed simultaneously with your cable input. Check the manual for the correct buttons, but the one you're looking for says either PIP or AVI or something along those lines. Hope this helps
Jun 11, 2009 | Mag Innovision InnoVision XJ 717 Monitor
53UDX10B
Good Day, peterferd;
Try resetting the TV by unplugging from A/C outlet wait 3 to 5 minutes then plug back in. No fix? Call service company.
Good Luck, big IRISH.
Apr 16, 2008 | Hitachi 53UDX10B 53" Rear Projection...
4 Scrolling black boxes with the picture showing in the background
PIP DISPLAYED IN ALL FOUR CORNERS OF PIX. UNPLUG UNIT MOMENTARILY TO RESET. or the pip modual has failed.
Mar 16, 2008 | Televison & Video
Pltv-4250 pip & pbp issue
yes, PIP allows you to view 2 channels at one, one being the analogue picture another being a cable/freeview or sattelite picture, if you only use one of these to view programmes, you will se a blank screen.
Nov 29, 2007 | Protron PLTV-4250 42 in. LCD Television
Picture has horiz. lines
There is no vertical hold in the tv circuits now adays. You may find a vertical center or a vertical height. Your problem sounds like (if it has PIP Thats Picture in Picture) its in the PIP module and its a small module that stands up and most models of Mistubishi this module is no longer availabvle. The problem with the module is the small pana caps are leaking and ruins the PC traces. I have heard that theres a kit available on E-Bay to jump out this module. Now if its not the PIP model then it could be a few capacitors in the vertical sweep circuit. Also the B+ feed off the Flyback that supplies voltage to the vertical output IC could have a bad or leaky capacitor in the circuit. If your not a tech or solid state troubleshooter theres not much you can do and SHOULD take this set in to a repair center. Good Luck
May 21, 2006 | Mitsubishi VS-45605 50" Rear Projection...
Televison & Video Logo
55 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
