Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2003 DYNA STARTER WON'T ENGAGE IF RUNNING 10 MIN+TURNS OFF AND ON WHEN DRIVING AFTER 10 MINS
JUST PURCHASED TODAY AND AFTER DRIVING 10 MINS THE IGNITION TURNS ON AND OFF MULTIPLE TIMES THEN BEGINS RUNNING AGAIN....THE STARTER MAY BE RELATED???ALSO THE LEFT TURN SIGNAL SWITCH NEEDS PUSHED SEVERAL TIMES TO TURN ON OR OFF>>>>>DARN EBAY PURCHASE!!!
  • 216 Answers
This is going to be a great opportunity to learn about your bike. Whenever I buy a bike, I always buy a service manual for that model. This doesnt sound too serious, but may require some time. My guess is a loose connection, These things happen now and then. I would just trouble shoot the whole electrical system, staring at the battery. Make sure the connections are all tight and clean, including the battery cables. Put your hands on em and see if they move, and torque em up. If you dont have one - get a charger as well, your gonna need it eventually anyway
Posted on Sep 07, 2008
Starter spins but won't engage
The starter on your bike uses a solenoid that also manually engages the starter gear. Try lubricating the solenoid mechanism and verify that the mechanism does not bind or stick. Once you have the mechanism freed up, check the starter again. If it does not engage, replace the solenoid (or, while you're at it, just replace the entire starter assembly).
Jan 21, 2013 | 2003 Harley Davidson FLSTCI Heritage ...
I have a 1999 Gilera Runner 180FXR, New bat 12V 9 amps. Starter turns and spins pinion gear but won't engage starter ring. If it does it turns ver slow or won't turn engine over. In manual it
Yep, not enough amps to engage the starter clutch, and when ti does engage, not enough amps to turn the engine. You need a 12 amp battery.
Nov 17, 2012 | Motorcycles
1996 softail starter turns but will not engage
Hi Anonymous, you need a new starter drive, for more information about your question please visit the websites below. Good luck and have nice day.
Harley Heritage Classic with Evo motor starting issues
2005 Harley Dyna FXDX starter replacement
Apr 07, 2012 | Harley Davidson FLSTC - FLSTCI Heritage...
Dyna starter just spins
The starter has a centrifical clutch. It works by using small roller bearings that sling to the outside and tighten up as the starter turns. Some models might be a bit different in design.
Feb 18, 2012 | 2003 Harley Davidson FXDL Dyna Low Rider
2003 dyna starter turns but wont engage, new battery fitted
Hi Anonymous, lift up rubber boot on positive cable to starter, unplug starter relay wire usually green, with a jumper wire connected to positive battery cable starter stud, touch blade connecter on starter where starter relay wire was removed. If starter engages and turns over engine then your starter relay is bad. If starter activates but does not engage then your starter drive/clutch is bad. Good luck
Jan 22, 2012 | Cars & Trucks
Car died and wont restart
If the starter turns but doesn't engage then the starter relay is defective. Have it replaced.
Dec 12, 2011 | 2003 Kia Spectra
2003 Chrysler town & country limited
First try and change the fuel filter. this also happened on a van i worked on. I cahnged the filter and it runs fine now.
Nov 16, 2011 | 2003 Chrysler Town & Country
TV turns on for about 10-15 min then turns off
Sounds like a tuner section problem. When you are playing a DVD. You are only using the audio video circuit of the TV. Something like a monitor. But when you go back to TV mode... You are now in the tv tuner circuit. And your problem lays there. I had a mouse **** on my tuner section of my tv and it caused the same problem. Yes mice do ****...
Aug 18, 2006 | Panasonic PT-47WX53 47" Rear Projection...
Lands Phones Logo
112 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
