Question about Haier Energy Star ESA3183 Air Conditioner
Water pools next to air conditioner
There are water pools next to the air conditioner in my room. can yu tell me what causes this?
  • scarletjo1 Aug 23, 2008
    Our Frigidaire portable air conditioner is doing the same thing. How do you get to the inside to solve the problem?
  • 80 Answers
THEY SAID IN MY ROOM ITS PROBABLY A WINDOW SHAKER AND IN THAT CASE REMOVE THE FILTER AND PUT WARM WATER ON THE METAL EVAP COIL BEHIND IT TO FLUSH YOUR LINE
Posted on Nov 29, 2007
It is common on many air conditoners for water to come out of them however it should not come into your room if installed properly and working properly sometimes water can enter into a room of an air condtioner due to incorrect installation per the servive manual for your model air conditioner the back of the air conditioner should be about one half of an inch lower then then the front of your air conditoner this specific model shoud have a couple of leveling adjusters to adjust the level in some cases the leveling adjusters may need to be removed or the sill changed or modified so the correct angle of installation may be obtained I will send you the entire service manual if you will help me obtain information on the bracket for the rear filter of your air conditoner is there any writng and or numbers on such bracket what all does and does not this say on the rear bracket please send to me all of your contact information such as name address and telephone number to me please reply to me at my email address. Sincerely, Steven Bolin wizard24672000@yahoo.com I am pasting with this a portion of the service manual below.To prevent vibration and noise, make sure the unit is installed securely and firmly. 2.Install the unit where the sunlight does not shine directly on the unit. 3.The outside of the cabinet must extend outward for at least 12" and there should be no obstacles, such as a fence or wall, within 20" from the back of the cabinet because it will prevent heat radiation of the condenser. Restriction of outside air will greatly reduce the cooling efficiency of the air conditioner. CAUTION: All side louvers of the cabinet must remain exposed to the outside of the structure. 4.Install the unit a little slanted so the back is slightly lower than the front (about 1/2"). This will help force con-densed water to the outside. 5.Install the unit from the bottom about 30"~60" above the floor level.
Posted on Jul 24, 2007
When I Bought mine the drain plug was missing and the water leaked unto the floor. The people I bought it from were unresponsive, so I tried various plugs, all leaked. Finally, I siliconed the drain hole shut. It has not leaked since.
Posted on Jul 08, 2007
Make sure your unit tilts AWAY from your window, to make water drain out the back.
Posted on Jul 03, 2007
    Novelist:
  • 74 Answers
Air conditioners and high-efficiency combustion furnaces create significant condensation, which exits through a plastic drain tube. This should go into a floor drain or be carried away by a small "condensate pump." If water is pooling at the base of the appliance, something may be blocking the water's flow or leaking, or the pump may not be working. 1) Look to see if one of the tubes is leaking. If it is, replace it. 2) Test the condensate pump by pouring water into its pan. If the pump doesn't start, either it isn't receiving power, or it is broken. Be sure that it's plugged in and test the circuit. If it's broken, either get it repaired or replace it. 3) If the pump runs but doesn't empty the pan, the ball-like check valve just before the discharge tube is probably stuck. Unscrew the check valve and loosen the ball inside it. Look for an obstruction. If it appears that a condensation drain tube is clogged with algae, remove it if possible (you may have to cut it and replace it later with a coupling). Run a wire through it to clear it. To kill algae, pour a dilute solution of bleach (1 part bleach to 16 parts water) through the pipe. 4) With an air conditioner, ice may be blocking the tube. If this is the case, be sure the filter isn't dirty. If the filter appears to be fine, the air conditioner's refrigerant supply is probably low. This is when it's time to call an air conditioning technician.
Posted on Jan 18, 2006
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Unit is 12000 btu and leaking water
it has a hook up on the back,there is supposed to be a plug covering it and also supposed to be able to hook a hose onto it to drain the water,you have to drain them every day or 2
May 27, 2015 | Haier HPRD12XC5 Portable Room Air...
I have a waterco titanium pool heater water is pouring out of drain holes in the bottom of unit.I have to keep filling up the pool every other day.what do u think is causing the water to puor out like...
in which area do you live, as if the air temp is colder than the pool water it is evapoartion most likely, Test the water coming out of the heater against the water in the pool, if your pool is salt water and the water coming from the heater has no salt then your pool is not leaking, as the heat pump is like an air conditioner it will produce condensate Water from the air. in steamy weather there will be alot of water. David PoolWerx Brisbane
Mar 09, 2013 | Waterco Baker Hydro 80K Btu Titanium...
Our air conditioner9 which is only about 2 years old) just pours out water. It soaked the bed which was next to it.
Go outside where the air conditioner is. You will find several holes on the bottom of the unit. Clean the hole out and you should see water start dripping out of at least one of the holes
May 30, 2011 | Kenmore Single Room Air Conditioner
We also have a unit that will not drain out the back, but pools in the front compartment instead. It builds up until the fan sprays it into the room, and drips into the living room floor. It doesn't seem...
the reason is probaly an easy fix the water flow sometimes builds up scum from bacteria and dust buy a 12 oz bottle of rubbing alcohol take out the reusable filter so that you see the coil behind below the coil is a small pooling tray that water empties into from the coils when its operating.pour the entire contents of bottle into that collection tray that will dissolve the scum and kill the bacterial build up that can block the drain tube also try removing a blockage in drain tube with a pipe cleaner or a scredriver but be careful you dont damage the coils with it so try to use something bendable that won,t cause damage..
Oct 03, 2010 | LG LWHD1200FR Wall/Window Air Conditioner
I have a new GEAEM08FM 8,000 BTU ac in my window. (around 7/2010). There has been a mildew smell in my room, and when i looked inside the air conditioner (from the vent at the top), i can see the pipes...
If it was me I would mix a strong Clorox/water solution and spray everything down leaving the Clorox water in the tray...this will kill and fungi/mold and make it smell good...
heatman101
Sep 27, 2010 | General Electric AEM08FM Air Conditioner
The unit is not cooling the room. Water is not draining out the water hose.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 17, 2010 | Alen C400H Portable Air Conditioner
Sears Plasmaire spits water into room
It's probably just holding water somewhere and getting thrown out. I've seen people drill holes on the bottoms to drain water quicker.
Sep 03, 2009 | Kenmore 75085 Air Conditioner
Black particles coming out of the room air conditioner
dirt, dust, or mold. could also be the tubing insulation flaking off. either way, open it up and clean it out. the dirt, dust, and flaking insulation can restrict air flow through the coils and cause the ac to not function properly. if it is mold, it's can cause sickness (legionaire's disease). do not use chemicals on the coils. it might be best to replace the ac alltogether. to prevent mold: when installing the ac, make sure the unit is slightly tipped towards the outside. any condensation that collects on the coils will drain out. failure to do so will result in water pooling inside, and this can cause mold.
Jul 30, 2009 | Kenmore 73259 Air Conditioner
Water Leaking
Dear Customer,
The likely reasons for a leaking AC are...
1) Improperly installed.
A window air conditioner must be slightly lower at the rear than the front. This allows the water being removed from the room to drain to the back of the machine. A difference of one inch is sufficient. This is always the first thing to check. Many are improperly installed in the haste to get relief from the heat. If installed too low at front the water will flow into the room rather than outside. If installed too low at rear, water can roll out front edges before has chance to exit towards rear drain.
  1. Icing up.
    Water being de-humidified can turn to ice if there are problems with the cooling system. There are many reasons for an air conditioner to produce ice. Remove front grille while machine is operating. If ice is present on the cooling coil you will probably need service. For more information see our other article: Why window Air Conditioners Ice up.
  1. Air leakage around air conditioner.
    If warm air is able to enter around the air conditioner it will encounter cooler, dryer air. When they meet condensation will occur. If water leaking from front of air conditioner inspect to see if dripping from body of machine, or water droplets clinging to front area. To test, operate machine for 30 minutes and then use flashlight to check under front edge of base. Small water droplets here indicate an air leakage problem. Add foam insulation to stop warm air from infiltrating.
  1. Drain hole blocked.
    Rear of air conditioner base has a drain hole or groove to allow water to escape. If becomes blocked water can back up. To test, operate machine for 30 minutes and then inspect if draining properly. If appears blocked use a small piece of wood to open drain hole at rear of metal base. CAUTION: Never be tempted to drill holes into the air conditioner body to relieve water pooling. Severe damage can result.
  1. Internal drains blocked.
    There are small passageways that allow water to drain from front of air conditioner to the rear. If they become blocked water will pool at front of machine and overflow onto floor. If this happens the air conditioner will require removal from window and servicing.
  1. Outside temperature too cold.
    This occurs at end of cooling season. If outside temperatures drops below 60 degrees Fahrenheit at night the cooling coil may ice up. If no leakage at bedtime but water in front of machine in morning, suspect this problem. If this problem suspected turn off machine before bedtime and restart as day warms. Alternately, operate machine at night with selector switch in ‘fan only’ position. This will circulate room air during night but not allow cooling.
Hope u find this useful. I'll be thankful if u could rate this. thank you.
Jul 10, 2008 | Samsung AW0505M Air Conditioner
Haier Energy Star ESA3183 Air Conditioner Logo
942 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Bonded Repair
Dan Apthorp
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
